    New question here. Little help, can a Hope pro2 front hub axle adapter work on a chris king hub..??
    In short I want to run my 20mm king front wheel on my DUC32 and got a line on a Hope pro2 axle but I'm not sure if it will work on the kind hub, so I'm looking for your advice...
    Not sure about the Hope pro2, but King makes a 24mm axle and their website says the ISO 20mm TA hub is convertible to 24mm axle - that is most likely your best bet.
    And somewhere in the back of mind, one of the gripes I heard about the King 24mm hub is that it creaks because the axle ends are not gnurled (spelling?) like the Maverick hub. I believe I read somewhere in this forum that Ethan can gnurl a Kink axle to take care of that, and if you get the conversion kit it shouldn't be too much to send him the axle before you install it. Just my .02
    Reputation: ragetty's Avatar
    i used a hope pro 2 with a maverick 24/7 for a while, using the hope adapter. i had a friend 'knurl' the axle ends (which also increased the effective diameter of the perhaps slightly too small axle ends - this is also in a thread here somewhere), and i used some blue loctite on the axle threads. it actually worked fine both before and after treatment ...
    i would be very surprised if the hope pro 2 maverick 24/7 adapter fits any of the king hubs.
    Quote Originally Posted by g_henrys View Post
    I think the metal on the KING axle is too soft, so thats a no go.
  1. Chris King SS hub or Hope Pro II SS hub??
    By vindiggitydog in forum Singlespeed
    Last Post: 03-27-2013, 09:02 AM
  2. Replies: 3
    Last Post: 03-16-2013, 11:48 AM
  3. Quick help - Hope Pro2 Front Hub 9mm TA conversion cap
    By BigGK in forum Wheels and Tires
    Last Post: 01-22-2013, 07:36 PM
  4. Hope pro2 evo rear hub axle conversion
    By mint355 in forum Wheels and Tires
    Last Post: 06-23-2012, 08:15 AM
  5. Chris King or Hope BB?
    By Raybum in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2011, 11:44 PM
