Results 1 to 7 of 7
    T.W.O.
    Reputation: mimi1885's Avatar
    Kings Inset headset
    Can I put Kings Inset on ML8? Thanks
    Schipperkes are cool.
    Reputation: banks's Avatar
    It will not work.
    Maverick frame is designed or the Campy 45* headset where the bearings rest onto the frame.
    King headsets have cups that press into the frame.
    I have been using the same FSA Orbit Carbon since 2004 and it has outlasted many King headsets.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    T.W.O.
    Thanks Banks, I'll stick with my FSA then.
    King does not have a compression ring for the upper bearing for support. FSA & Cane Creek do which allows less adjustment and wear.
    Umm, Correction good news from King for longer forks
    T.W.O.
    Quote Originally Posted by banks
    CC 110? or how about the new adjustable one, Thanks
    Reputation: Denis's Avatar
    The FSA get my vote too. 5000+ miles on mine, a couple of re-grease with waterproof grease and they work like a charm.
    Cane Creek Angle Set: Nope as it's a press fit.
    Cane Creek calls the Campy spec, (Campagnolo Hiddenset frames with 41.8mm headtube ID (stainless steel 45x45 degree angular contact cartridge bearings) "Italian Integrated (ISi) Threadless" so there is "something": http://www.canecreek.com/component-h...product=IS-3-i
