Results 1 to 2 of 2
Thread: Fork Offset
    Crosley623
    Mar 2006
    Fork Offset
    I just purchased a set of I9 wheels mounted to a sc32 converted 29er. After the long awaited build I noticed that the wheel offsets from the center of the fork. I really do not undersand this and you can really tell the problem when you ride it. Do any of you have any suggestions on this fix.
    Reputation: Ethan F's Avatar
    SC32 offset
    You will need to redish the wheel. The conversion is from a 20mm Thru axle design and the fork is designed around standard 100mm spacing. Just doing the conversion will offset the rim torwards the disc side. Simply redishing the rim will solve the problem.
