Results 1 to 2 of 2
    Durance top out o-ring
    Hello Maverick experts,
    the top out o-ring 2x9mm Urethane of my 2007 Durance damper is destroyed.
    (it is not unnormal!!)
    Can I use instead a normal black 2x9mm o-ring or must it be this special Urethane o-ring??
    Banks should know it ?!!
    Problem is that I donīt have any of this f...... Urethane o-rings in stock and the german distributor runs out of them as well.
    Thanks for help !!!!!!!!!!!!
    Schipperkes are cool.
    Reputation: banks's Avatar
    yes, you can sub a black version for a short time, as it will get smashed/chewed up faster and clog the rebound ports. Best bet is to purchase the Hydro-top out damper assembly.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
