Results 1 to 3 of 3
    DUC32 Travel reduction
    Has anybody ever found a way to reduce the travel on their DUC32 while also lowering the axle to crown measurement?
    I'd love to run one on the front of my trek Fuel but the rear end is 120mm, and the front is currently 130mm. I like the way the bike handles, so I'd like to keep it that way, and I don't feel that I need 6" of travel for XC/trail riding. I know there's the 29er setup that will give me the travel I want, but it keeps the A2C high. I know the A2C measurement is already pretty low, but how does it compare to a 130mm fox Float? Pretty similar?
    Thanks in advance...
    Schipperkes are cool.
    Reputation: banks's Avatar
    Simple!
    Buy a pair of Maverick 29" bottom out kit, measure twice, cut once and install your custom cut down spacer (to get the travel you want) Under the Air side seal head above the negative coil spring.
    A-C on the DUC is 521mm
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Reputation: ragetty's Avatar
    ... a2c for the float looks to be 500mm
    ragetty
  1. Replies: 4
    Last Post: 05-27-2010, 02:02 PM
  2. Travel reduction (All Travel) for RS Lyric Solo Air?
    By G-AIR in forum Shocks and Suspension
    Last Post: 07-17-2009, 09:11 AM
  3. Van 36 travel reduction possible?
    By cobym2 in forum Shocks and Suspension
    Last Post: 08-06-2008, 08:52 AM
  4. Z1 BAM travel reduction- possible?
    By CabRider in forum Shocks and Suspension
    Last Post: 12-25-2004, 10:07 PM
  5. '05 Z1 fr travel reduction?
    By tuggy in forum Downhill - Freeride
    Last Post: 11-26-2004, 01:45 PM
