    Jan 2009
    Duc32 on a short headtube....advice needed.
    Just bought some duc32s with a view to converting them to 29er and putting them on my Krampus.
    However, the headtube & headset come to a tiny 110mm, and according to the Maverick docs the minimum you can fit it to is 130mm.
    Does anyone know a way around this?
    Cheers, Tom
    Reputation: ragetty's Avatar
    i remember someone else mounted the DUC32 onto a small klein palamino (90mm head tube), so i guess it's 'just' a case of getting the 'right' spacer above or below the headtube and perhaps also a longer bolt to fix the stem ...
    Your bike sucks
    Reputation: Carl Mega's Avatar
    Depending on application: You can do it safely by adding either the "Externalizer" from RWC/Enduro Seals:
    REAL WORLD CYCLING HEADSET ADAPTER/EXTERNALIZER
    Or piece together a CaneCreek setup using their (depending on ID/OD) lower cups + special matching race to raise up the stack height. That's what I did.
    Just adding spacers is a little dangerous.
    Hit me up if you need P/N to get you started.
    cheers.
    Jan 2009
    Sorted, with a bit of machining and fettling
    So I had to machine up an extension to the steerer nut. It was a tight fit (I knurled it) and it was epoxied in place. So far it seems pretty sturdy. But in future I may machine and tap a longer one piece steerer nut.
    I then checked to see how much I had to reduce the travel by to make sure the tyre cleared the crown. The standard Maverick travel reducers are 35mm long, but I machined up some 48mm long to take into account the larger tyre diameter.
    The fork had come with a 26" wheel on a Maverick hub, but luckily my existing wheel has a Hope Pro2 hub, and they do a Maverick axle. Having read on here of some problems people have had as the finish on it is smooth, I knurled the ends of the axle - a solution suggested by an ex-Maverick employee.
    Here are some pics of the bike built up. I've been out for a couple of rides so far, and it's working great
    Loads of room....
    And with my mates Karate Monkey for comparison....
  1. Bike advice needed for short girlfriend
    By Nate3510 in forum Women's Lounge
    Last Post: 02-10-2013, 06:56 PM
  2. Help needed identifying my DUC32
    By Jon Richard in forum Maverick
    Last Post: 05-30-2012, 05:21 PM
  3. Replies: 2
    Last Post: 03-13-2012, 10:01 PM
  4. Bike Advice for Super Short Girlfriend
    By joytron in forum Beginner's Corner
    Last Post: 02-23-2011, 07:51 AM
  5. Colorado high, a much needed short vacation (pic heavy)
    By kosayno in forum Colorado - Front Range
    Last Post: 01-24-2011, 10:00 PM
