DUC32 - More Plush with Travel Reduction Function Removed?
Good Morning Everybody,
I seem to remember a thread from a while ago mentioning that removal of the travel reduction function on the DUC gives you even better plushness and small bump compliance. Can't find that thread anymore.
Does anyone know if this is accurate and what exactly I would need to do to perform this Mod?
Reason:
I never ever use the travel reduction feature. My ML8 and DUC climb so well even the steepest pitches. Soooo.....if I can get even more buttery smoothness by removing that function, I'm all for it.
I just read that thread, and the author said he removed the O-ring from the damper piston to reduce stiction. The result was the travel reducer function would no longer work. The thread is "Shim stack Duc32."
More plush = change larger shim in 0.15mm thick by a 0.10mm. Tested by Ethan, me too
Maverick ML7.2 / SC32
Maverick ML7.5
Maverick Durance / Duc32
Maverick ML8 / BOS Devile
French Maverick Breeder
I can't imagine my Mav being more plush than it is, as-is. Hell, I set it up looking for something akin to stiction, though! Coming off of Manitou Minutes, Fox FX-80, etc... this seems to be a super-plush, super-smooth fork. You guys can feel a pea through all those mattresses?
Gentleman Loser
If you remove the piston glide ring, the damper will bypass oil around the entire piston assembly.
I can't in any way imagine that being a good thing.
- You may not post replies
- You may not edit your posts
Forum Rules
