Results 1 to 5 of 5
    Aug 2010
    DUC32 / ML7 Headset
    I've changed a Fox Fork with a DUC32 and now wondering about the bottom Headset. The Headset is a Cane Creek IS and fixing well at the top side. As I've read in another threat, there must be a crown race befor installing the bottom bearings! I didn't have one! The inner diameter of bottom bearings (TH Industries 1-1/8" ACB36x45) is 30.1mm. But lower Crown steerer shaft is 30.0mm. So there is not enough space for a crown race, right?
    What would be the right headset for DUC32 / ML7?
    Reputation: Alpamayo's Avatar
    Cane creek is not the good standard for Maverick, wrong angles, doesn't fit well the front tube. Campy standard works well. Buy a new one, FSA, Ritchey and you will have a crown race + good angles bearings.
    Maverick ML7.2 / SC32
    Maverick ML7.5
    Maverick Durance / Duc32
    Maverick ML8 / BOS Devile
    French Maverick Breeder
    Which model of fsa or Ritchey is compatible? I know FSA CE
    Quote Originally Posted by stamatis View Post
    All the models in campy standard 45/45
    Maverick ML7.5
    Reputation: ragetty's Avatar
    if you have a cane creek, it should be from the IS42 series, e.g. 40.IS42 Short Cover
    i have an older model, the IS 2i ( I think there were 3i and 8i models too, where the 'i' specifies 'italian' (campy). it does need be tightened up a little more than the FSA in order to stop the bearings fidgeting in the head tube, but otherwise mine seems to be working fine ...
