Results 1 to 6 of 6
    Reputation: nineracerxer's Avatar
    DUC Adjustable Stem Manual or Setup Pics?
    I was looking to switch my stem from 95mm to 85mm just to try it out and wondered if there was a one page write up on adjusting the stem. I am guessing it is a simple adjustment but wanted to know if anyone had pics or diagrams before I get all the pieces laying on the counter....
    Schipperkes are cool.
    Reputation: banks's Avatar
    the middle piece, where the big steerer shaft bolt goes through is reversible and the holes will line up. Flip the stem over and you will see the etching on the bottom.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Fortes Fortuna Iuvat
    Reputation: Datalogger's Avatar
    Yup, just as Scott said. It will only take a few minutes to adjust.
    Maverick Durance Ano-DUC32/C KING/XTR
    Mav ML8 Ano-DUC32/X0
    Mav ML8-DUC32/I9/XTR
    09 Spec. Demo-Totem-Ti DHX
    Norco Team DH
    great!
    thanks for the quick response! Is there some trick to get the 75mm position out of the stem where something has to be flipped or rotated in addition to moved, or is it all just as easy as moving the thing out 10mm at a time? Something about the two adjustment screws and three positions has me wondering...
    Quote Originally Posted by nineracerxer
    Quote Originally Posted by banks
    got it.
    thanks, you're right, that was easy. I got from 95 to 85mm by removing only the screw through the hole on the side of the stem and moving from the orange arrow hole to the green arrow hole. The numbers on the bottom were right where you said, thanks!
