Results 1 to 9 of 9
    New question here. DUC 32 - is it worth the trouble?
    Hello
    I got a DUC 32 lying around in the attic from a Whyte 46 (2006 I believe). The bike was unused when I bought it back in 2009, since it was keept stored and forgot about in a bike shop basement. The DUC 32 is grey, and I believe it is the first model – which is more prone to problems if I’m not mistaken.
    Well, the fork was leaking oil after 3 months use and I removed it and put in storage for later upgrade.
    I have sold the Whyte 46 now and I think something is got to be done with the DUC 32.
    1) 29’er conversion and used for a Niner Jet 9 2013.
    2) 29’er conversion and used for a Fat Bike
    Either way something has to be done about the leaking seal, and by reading this forum it seems straight forward. But from my recollection riding the Whyte the forks has more faults as:
    1) Climbing mode not functional - may not be necessary in 29’er mode?
    2) Rebound adjustment made no difference to harsh rebound riding roots
    3) Brake dive was very bad! – but Internal Floating Pistons may solve this?
    Putting the fork on a new bike:
    4) Different head tube length on future frames – how is the fork adjusted for that?
    5) I need a new wheel, but I got the old maverick hub, so no problem there. But is it possible to fit other standard hubs in a DUC 32 or by doing easy modifications? I read once about a HOPE hub that could do the trick…
    So all in all this may sum up quite a bit, but a new nice FOX fork is also quite expensive so I might consider to upgrade my DUC 32.
    Biggest problem – I am based in Denmark… and no parts are to be found. I may be able to find the seals in a webshop in Europe but the rest is probably to be found in the States.
    So, do you guys think it’s worth the trouble?
    Kind regards, Lui
    Attached Thumbnails Attached Thumbnails DUC 32 - is it worth the trouble?-whyte46001.jpg
    Schipperkes are cool.
    Reputation: banks's Avatar
    Needs to be rebuilt. When the damper cartridge looses it's charge, climbing mode & rebound will not work and it will brake dive. Keep the Maverick hub, easy to replace common bearings, wide spoke flanges, knurled axle. Head tubes use different top crowns and headset spacers.
    MAVERICK - Manual PDFs
    Easy to service, easy to modify air and damper settings. If you need more help email Scot@absolutebikes.com in Colorado.
    ps, don't buy the Fox
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Ps: Fat bike tires will not fit on the DUC fork, do to the "Baseball bat" shape of the legs, you need the SC32 for that.
    Almost no clearance with a Nate tire.
    I am currently running a DUC32 on my 2013 Jet 9 RDO and I love it. Ethan can connect you with a complete rebuild or any parts you may need.
    mavericksuspension@gmail.com
    Quote Originally Posted by patineto View Post
    OK, I'll ditch the Fat plan then
    Quote Originally Posted by banks View Post
    Seems legit.
    OK. I found different top crowns on Ebay so I get the idea. That's great
    Well, yeah... I think I'll try a complete rebuild then and do future service on my own.
    Customs and import tax is a hassle when buying from the States, even sending gear for service is a hassle and quite expensive.
    Is it possible to get a complete rebuild in Europe? With a 29'er conversion and Internal Floating Pistons?
    Regards, Lui
    Reputation: voob's Avatar
    Jan 2011
    Contact Alpamayo
    alpatech@free.fr
    Quote Originally Posted by voob View Post
    Contact Alpamayo
    alpatech@free.fr
    Yup Done that and got an offer for a rebuild.
    I think I'll do that.
    One thing that I forgot to ask is the behavior of the fork:
    From my recollection is was very soft when pedaling hard while standing up and rocking the handlebars from side to side, witch basically made me sit down most of the time. My Talas 36 on my Covert tend do the same while my Reba 29 on my hardtail stays firm. Both forks are running at same amount of relative pressure = sag, but the do have different characteristics.
    How is the DUC 32 gonna behave with the IFP installed? Will the fork firm up will doing standing pedaling?
    Reputation: Alpamayo's Avatar
    Quote Originally Posted by Lui V View Post
    Definitely !!!
    Maverick ML7.2 / SC32
    Maverick ML7.5
    Maverick Durance / Duc32
    Maverick ML8 / BOS Devile
    French Maverick Breeder
  1. drcv worth the trouble?
    By drivengsxr1000 in forum Trek
    Last Post: 04-26-2015, 06:48 PM
  2. Trouble with e*13 TRS+ hub
    By JTeezy in forum Wheels and Tires
    Last Post: 09-04-2014, 12:58 PM
  3. Replies: 50
    Last Post: 06-22-2013, 07:46 PM
  4. 4x4 Trouble @ 909
    By pedaler845 in forum New York - New Jersey
    Last Post: 06-03-2012, 04:59 AM
  5. Im having some trouble
    By dpugh5 in forum Wheels and Tires
    Last Post: 11-02-2011, 12:19 PM
