Results 1 to 3 of 3
    JWB
    JWB is offline
    DIY Rear Shock Rebuild ??
    My rear shock has lost its top out O ring (again...) It clunks really badly when returning to maximum extension.
    Rebuilding looks a simple nut and bolt job especially with the 3mm hole modification to pressurise instead of using the hyperdermic needle.
    Which O ring disintegrates? And what is the dimensions? I need to check I have one or can get one before I start rebuilding.
    Is the hydro top out a part (or parts) I can retro fit into my old shock?
    Thanks,
    John
    In the UK.
    Crazed Country Rebel
    Reputation: iheartbicycles's Avatar
    Quote Originally Posted by JWB View Post
    Thanks,
    John
    In the UK.
    Just do it! What's the worst that can happen? You get stuck and have to pay someone to rebuild it.
    See my threads in the foes forum on learning to rebuild my curnutt shocks. It aint rocket science.
    Stupid, but sometimes witty. Occasionally brilliant. Slow and fat though.
    Mike Vandeman Sucks Dong
    Schipperkes are cool.
    Reputation: banks's Avatar
    John,
    The top out oring is urethane, but what you should consider is buying the hydro damper unit from Maverick as it has a hydro top out system; no more oring to get chewed up.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
  1. Rear Shock Rebuild Quandary?
    By murd in forum Downhill - Freeride
    Last Post: 05-23-2011, 02:54 PM
  2. RCR T1 rear shock rebuild
    By njracer in forum General Discussion
    Last Post: 04-15-2011, 11:38 AM
  3. {WTB} Fox Float R Rear Shock Rebuild Kit - HELP
    By neosaint99 in forum Shocks and Suspension
    Last Post: 11-30-2009, 02:36 AM
  4. How to know when rebuild the fork/rear shock ?
    By seaman in forum Specialized
    Last Post: 09-09-2007, 09:37 AM
  5. M1 Rear Shock - Rebuild or Replace?
    By imridingmybike in forum Intense
    Last Post: 06-29-2005, 05:42 AM
