Hey does anyone would know if the the Blackspire Stinger E with a front derailleur will fit an ML8 frame instead of using the standard Maverick D mount and R773 combo?
Cheers
**Pic shows ISCG but comes in BB version as well**
i imagine this is designed to be stable enough on its own.
maybe you have to be more worried about interference between the d-mount thread and the front der locating assembly on the guide that prevents you mounting it at all ...
Yeah i think so to, maybe have to bust out the Dremel.
I have emailed Maverick as well to see if they would know.
Did you e-mail Maverick or Ethan? In case you were not aware, Maverick is no longer in business. I rather doubt anyone is monitoring any e-mail sent to their website. Now Ethan, who used to work at Maverick, is likely to know; I would suggest you contact him if you haven't already.
You should definitely reach out to Ethan, he has helped me with front derailleur fitment issues/questions. His email is mavericksuspension@gmail.com.
Also, remember to take into account cable routing requirements - not sure if what is pictured is top or bottom pull, but that may make a difference, too. If the cable noodle on the Monolink is not properly aligned you'll have another problem besides fitment.
