    Bearing Upgrade for Maverick 24/7 Hub
    Has anyone jumped on the ceramic bandwagon and upgraded the bearings in their Maverick 24/7 Hub? I am getting ready to replace my five year old neglected original bearings and was wondering if the extra $$$ to go ceramic would be worth it. If not, I plan on going with SKF 6805-2RS as I have heard these are excellent replacements.
    Any input is welcome.
    This is a little late in the day i guess...
    I had a conversation with Tim Flooks of TF Tuning a while ago, he had changed the bearings on a 24/7 hub to ceramic but couldnt discern any advantage. If youre a weight weenie then they save a few grammes and of course they dont rust, both plus points.
    I use SKF bearings when i replace and can whole heartedly recommend them, top quality and worth the extra cash for smooth long lasting use and accurate tracking. Cured a problem with run-out on a hope hub with SKF(run out= a sight wobble due to bearing misalignment).Not stainless though so need to be serviced if you run in the wet a lot.
    Reputation: Alpamayo's Avatar
    Quote Originally Posted by g_henrys View Post
    Take the SKF, forget the ceramic, no interest, just empty your wallet
    Maverick ML7.2 / SC32
    Maverick ML7.5
    Maverick Durance / Duc32
    Maverick ML8 / BOS Devile
    French Maverick Breeder
    Thanks for the input! I have SKF bearings in my monolink and they are still going strong after three years so it makes sense to stick them in the front hub as well. Hopefully I'll get to this before winter sets in. And Alpamayo makes a good point... I certainly don't need to part with any unnecessary $$$
  1. palomino maverick upgrade
    By carbonone in forum Maverick
    Last Post: 11-26-2008, 04:04 PM
  2. Where online in UK to get a maverick upgrade?
    By thomasali in forum Maverick
    Last Post: 06-20-2007, 03:47 AM
  3. Maverick ML-7.2 to 7.3 Monolink upgrade?
    By dobbs in forum Maverick
    Last Post: 09-22-2006, 03:28 PM
  4. Maverick announces Palomino upgrade kit
    By bustamove in forum Maverick
    Last Post: 05-05-2006, 12:41 AM
