Results 1 to 3 of 3
    Reputation: nathanbal's Avatar
    90mm v 105mm stem rise on DUC32...
    Hi all,
    Can anyone who has either flipped between these two or has seen them, tell me whether the 105mm stem has a similar rise as the 90mm and will therefore increase the height of the bars?
    I need a little extra length but I dont want any extra height.
    Thanks.
    Schipperkes are cool.
    Reputation: banks's Avatar
    25.4mm stem or 31.8mm stem?
    # 25.4mm stem: 25 degree rise relative to mounting plane (comparative to 0-5 degree rise of steerer mounted stem)
    # 31.8mm stem: 10 degree rise (standard comparison)
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    its the 25.4mm stem I was looking at. I guess from your post the 105mm stem is the same rise as the 90mm which means the bars will sit higher... I didnt want to get the 31.8, adjustable stem because of the weight but looks as though I may have to...
