Results 1 to 2 of 2
    wolf ridge / attack trail frame size?
    I'm 6'2 or 188cm tall with 34,5 inch ( 88cm) inseam and I'm having trouble pulling the trigger on a used wolf ridge size Large. The top tube length sounds short to me and I assume the bike works better with short stem. Any thoughts? According to Marin size chart I'm within the frame size, but I'd rather hear your input!
    Dec 2009
    I'm 188 as well with a large. I'm finding 80 to 90 mm stems best if you don't want steering to slow. I'm using 720 to 740 mm wide bars which effectively give you more reach as well. Keeping bar height at least 20 to 30mm higher than seat also helps comfort when fitting in to a smaller top tube.
  1. Shock size for 2k9 marin wolf ridge?
    By philridebike in forum Marin
    Last Post: 01-11-2011, 01:09 PM
  2. 2007 Wolf Ridge size???
    By Fatsweaty in forum Marin
    Last Post: 07-31-2008, 12:38 AM
  3. Wolf Ridge Frame
    By Glow in Dark in forum Marin
    Last Post: 11-06-2007, 08:31 PM
  4. What size Wolf Ridge.......
    By Plan 9 in forum Marin
    Last Post: 02-17-2007, 07:58 PM
  5. Marin Wolf Ridge / Attack Trail Sizing
    By mb300 in forum Custom Builders & Other Manufacturers
    Last Post: 08-20-2006, 10:29 PM
