Results 1 to 2 of 2
    Dec 2009
    tappered fork on 2009 Mount Vision?
    Who has installed a tapered fork on a 2009 Mount Vision with 1/18 headtube?
    I was told to be able to run run a 1 1/8 - 1 1/2 tapered fork on my 2009 MV I need to install a 44mm bottom cap. Will it work / fit? Is it that easy?
    Any incite / advise would be welcomed.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    If your headtube is 1 1/8" and not tapered then no, it won't work. You'll need a straight 1 1/8" steerer. Head tube needs to be 44mm minimum at the bottom to fit that bottom cap.
  1. Replies: 3
    Last Post: 08-29-2013, 04:35 AM
  2. 2009 Marin Mt. Vision 5.8
    By Black Earth in forum Marin
    Last Post: 01-04-2013, 07:23 AM
  3. 2011 Mount Vision
    By Hallett6103 in forum Marin
    Last Post: 10-16-2012, 09:08 AM
  4. Marin Mount Vision shock mount - what size?
    By rekrutacja in forum Marin
    Last Post: 05-16-2012, 06:28 AM
  5. Replies: 2
    Last Post: 07-02-2011, 04:33 PM
