    Red or Blue Loctite on replaceable dropouts?
    The Marin manual say compound 638 for the rear replaceable dropouts for my Marin Wolfridge maxle rear. The manual says also coat the outside of the female nut before installing.
    My concern is where it says you have to heat to break it loose to replace the dropout. The only equivalent I could find to 638 is red loctite and it says to heat to 500F to break free. That sounds dumb on a heat treated aluminum frame.
    Would blue loctite work as good? What does everybody else use?
    Nov 2006
    When I changed out the drop out on the drivetrain side on my 2008 Mount Vision it had a bit of blue locktite on it. Thus I used blue locktite for the the new dropout.
    Red loctite sounds like overkill, I'd try the blue one first.
    Dec 2009
    Generally the red loctite is considered "permanent" and the blue loctite is considered "removable"
    So blue is correct for the application in question.
    Reputation: simplysimple's Avatar
    Just pulled the dropouts off the malformed rear section of my Quake loctite was on the threads.
    '04 Titus Switchblade LT ~ '08 Marin Quake Custom ~ '09 Fisher Mullet
  1. X-12 replaceable dropouts for RIP9?
    By Trond in forum Niner Bikes
    Last Post: 09-26-2010, 06:52 PM
  2. replaceable dropouts?
    By jethaze in forum Urban/DJ/Park
    Last Post: 04-11-2010, 06:58 PM
  3. HCR replaceable dropouts?
    By gauncher in forum Titus
    Last Post: 02-02-2010, 03:20 PM
  4. replaceable dropouts
    By Bizarro in forum Knolly
    Last Post: 02-25-2009, 10:40 PM
  5. replaceable dropouts
    By huckSTAR in forum Diamondback
    Last Post: 06-29-2005, 08:22 PM
