• 11-22-2012
    Betzel
    Waiting for SRAM XX1. Part for my new wheels are coming in. Will be Hope hubs, WTB Frequency i23 rims and DT spokes and nipples.
  • 12-02-2012
    skidad
    XX1 on the Mount Vision :thumbsup: Except for the price tag which should come down in time this will be a awesome setup IMO. Can't wait to try it myself.
    Has that bike even been ridden it's sooooo clean :confused: Love the XM9
    Betzel...check you PM's I asked a question.
  • 12-03-2012
    HoboBob5
    2008 East Peak. Close enough right? :)
  • 12-16-2012
    Betzel
    Now including XX1. See link:
    http://forums.mtbr.com/9976833-post6909.html
  • 12-16-2012
    skidad
    Betzel, that's really a sweet bike. XX1 is icing on the cake. More info on the ride report please.
    Did you get a weight of the whole bike before getting it all dirty?
  • 12-16-2012
    Betzel
    The Marin is a sweet riding bike. It just fits me. Best bike i have ever had (had a 120mm Mount Vision pro before). 140mm are just perfect for my kind of riding. Netherlands are really flat but 140mm do-able and flat out in the Alps :D So i had X0 2x10 on the bike and now XX1.
    On the XX1 I can say that it is sweet also. Gearshift is bang on. Even in muddy conditions like today. Never missed a front shift possibilty. The 32 chainring is perfect for my riding overhere. I have a 28 on order for the Alps. I have a biketrack around the corner with some short steep uphills. Using the 32 will let me use 9/10 of the 11 cogs behind. So allround enough. 28 on front would leave me at a low top speed. Maybe good trained people overhere could even try a 34.
    To be short: You need to take a ring that fits otherwise you will be losing out on one of both ends (speed vs climbing). The range is just less compared to 2x10 and 3x10. For someone who takes a lot of different tracks maybe an issue. For me: 32 for The Netherlands, 28 for the Alps. And in the Alps i won't miss the heavy gears.When it goes downhill i will take the flow rather than pedal as much as possible.
    Drivetrain is compelety quiet. Haven't had a Alps downhill ofcourse! Cleaning is also nice with a single chainring.
    Love it!
  • 01-02-2013
    hmorsi
    Some action shots on my XM8:
  • 01-02-2013
    Betzel
    Sweet!! How is riding over there? No forest around? Just rocks and desert?
  • 01-02-2013
    hmorsi
    There is a small but rapidly growing mountain biking community in Egypt. Riding is actually pretty good on hilly and mountainous desert trails. Very rocky and unforgiving but fun to ride terrain. As you guessed, there are no trees on our trails :)
  • 01-04-2013
    longbeachmd
    09 mountvision 5.8 build. medium.
    what front derailleur?
    rear?
    bottom bracket?
    Shimano or sram?
  • 01-04-2013
    longbeachmd
    All very sweet! Im building the same frame. Was wondering exactly which componets were used for front, rear derailleur and bottom brackets. Would like to do 2x10 drive train. Thanks for any responses.
  • 01-04-2013
    hmorsi
    I ran a full XT 3x9 drivetrain on my 2009 MV 2009 5.8.
    Sent from my S3 using Tapatalk 2
  • 01-05-2013
    longbeachmd
    Which front deraileur did u use? Rear? Hollowtech 2? Hope You dont mind all the questions, new to picking parts are there are a ton of options and I want to avoid trial and error as much as possible. That is the exact frame Im building. Ps, good looking bike!
  • 01-05-2013
    hmorsi
    Rear derailleur was Shimano XT shadow M770. Front was XT low clamp 34.9. BB is hollowtech II.
    I also built up a size small 2009 MV for my girlfriend and you should know that SRAM low clamp front derailleurs will not fit size small frames of this model without filing down a bit of material from the clamp.
    Feel free to PM me with any other questions and I'll be glad to help!
  • 01-30-2013
    skidad
    Love it!
    Betzel, what Q Factor did you get for the XX1? 156 or 168? If you have the 156 what's the clearance like on the swingarm?
  • 02-04-2013
    Betzel
    I have the 156 mounted. Clearance is about 3mm each side. So very little clearance compared to the 168 X0 cranks.... But i haven't have any problems with it yet. Cranks did not hit the frame and my feet also didn't touch the frame.
  • 02-04-2013
    skidad
    Thanks for the answer. After some research I've ordered a 168mm version for the safety/versatility factor and the fact I'm still undecided if I should get an Attack Trail or the new Banshee Spitfire frame. The kit wasn't supposed to be in stock until late Feb and now my dealer say's it's already shipped and will be here this week.
  • 02-28-2013
    Kiwiplague
    My XM8 MV - Attachment 776410
    Finally gone 1x10 :thumbsup:
    WIll be going out this weekend to see if the hype around the shadow + derailleur is justified.
    And I did manage to get rid of the ghastly red stickers off the Rev! Did rather clash with the rest of the bikes colour scheme.
  • 03-01-2013
    hmorsi
    Handsome ride (but I might be biased ;)). We're running almost the same drivetrain setups.
    1x10 with a clutch derailleur is fantastic. You will not notice much less chainslap since this is already remedied by the Quadlink II's elevated chainstays, but what I did notice is far fewer chain dropping. I didn't drop my chain much with the XCX guide and a non-clutch XT derailleur anyway, but it did happen on larger drops or when backpedaling on technical sections.
    I still can't get behind the fact that Marin ditched the Quadlink II platform. The design just worked very, very well and was rather unique.
  • 03-01-2013
    Kiwiplague
    I would have to admit that your bike's setup was the inspiration for my build:thumbsup:
    I'm hoping, and from what I've read everywhere, that the clutch derailleur should stop 99% of any chain drops.
    Oh, and I got rid of the horrible red stickers off the Rev as well! The pic made me realise how much it clashed with the rest of the colour scheme of the bike.
  • 03-04-2013
    hmorsi
    Glad I helped inspire your upgrades :)
    The clutch derailleur will prevent this from happening:
    Attachment 777521
    This was a medium-size drop and I was running the (non-clutch) 9-speed XT shadow. With the new derailleur this doesn't happen.
  • 03-05-2013
    Kiwiplague
    From the lack of noise I got on my 1st ride with the shadow I'd say you are spot on in that observation! I'd read about how quiet it could be, but was a bit sceptical about the claims, but wow, it was absolutely amazing how little noise there was. No chain slap, no derailleur clanking into the frame and most importantly, no dropped chains whatsoever.
  • 03-05-2013
    Betzel
    Nice bike Kiwiplague! I'm sure without the re stickers the green color look absoluty stunning! And if you don't want to drop your chain....just try XX1. I'm loving it! No noise at all, no chaindrops.
  • 03-31-2013
    somanygoodbikes
    This weekend I took my Marin Mount Vision to... Mount Vision, in Marin!
    [Cross posted this to the "bikes and trail markers" thread in the Passion forum but thought it might have a different audience here.]
    Most of Mount Vision (the place) is designated federal wilderness now and the trails are hiking only. Too bad. We rode some pavement and the one bike legal trail to the summit and snapped the above pictures on the way down at the first sign we saw with the name on it. There's some bike legal trail in the non-wilderness parts of Point Reyes park in the surrounding area. It is more a place to enjoy the scenery though.
    It was fun to go and see what was there though.
  • 04-01-2013
    Betzel
    Wow, that's cool! I would want a pic with that sign!
