Results 1 to 3 of 3
    marin wolf ridge 6.7 2009 rear shock
    Hey,
    I was wondering if any Marin wolf ridge 2009 or quad link users use a 7.5 x 2.25 rear shock?
    What are your thoughts on using this shock on a 2009 marin wolf ridge?
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    I believe that the stock is 7.5 x 2 I believe you can get away with having .25" of extra shock travel. You will probably have to get it dialed in at a different compression.
    Dec 2009
    There isn't a 7.5 x 2.25 are far as I'm aware? A 7.5 x 2.0 is all you will fit on there. From memory the bottom end of the shock will hit the frame with a 7.875 shock.
    A high vol can L tune RT3 works good if your looking for a new shock. Get someone to tweak down the IFP pressure is even better.
  1. 650B Marin Wolf Ridge
    By Waterat Pat in forum 27.5
    Last Post: 07-23-2013, 09:01 AM
  2. Replies: 16
    Last Post: 10-28-2012, 12:42 PM
  3. 09 marin wolf ridge
    By sra1218 in forum Marin
    Last Post: 04-23-2012, 12:53 PM
  4. 29'ering a 2002 Marin Wolf Ridge !
    By Dr Feelygood ! in forum Marin
    Last Post: 03-01-2011, 09:21 AM
  5. Shock size for 2k9 marin wolf ridge?
    By philridebike in forum Marin
    Last Post: 01-11-2011, 01:09 PM
