    Creaky wolf ridge pivots
    Hi, i was out on a wet ride a bit ago and ever since the pivots are creaky, how do i fix it? will it damage the bike if i continue riding?
    thanks, Jonty
    Reputation: Spik Boy's Avatar
    Dec 2009
    Make sure the pivots are clean, dry and the bolts have the correct torque settings.
    Stuff coming undone or dirt in the pivots/bolts/etc can make that kind of noise.
    If that dosen't sort it, take it down your lbs to check the bearings.
    Take it to a shop.
    I had the same prob with my 07. When peddling with force it made the worst noise. I spent 3 nights removing every bolt, cleaning every pivot, repacking all bearings, and when i was finally done I took the bike out and....same damn noise.
    After all that time I figured out it was the peddles. I worked over the peddles and jammed a ton of grease inside the body and now the bike doesn't make a noise.
    I did find thru all this that the last time i had overhauled the bike I had installed the front link upside down. The bike is SO much plush'r now.
