Results 1 to 7 of 7
    Building new Wolfridge......wheels?.....components?
    I am building a new 2009 wolfridge and wanted to know what wheels y'all are using for the 12mm Maxle.
    Also what front deraileur (top swing), thinking SLX cranks with the 36-22 double.
    Considering Sektor 150mm solo-air?
    Any inputs and other suggestions. Thnx
    NWS
    NWS is offline
    Jun 2010
    I have Transition Revolution 32s on mine, with Nevegals. Mine came with WTB wheels, I'm not sure which model. I put Big Apple street tires on them and they haven't seen much use. (I learned that I am too lazy to ride to work.)
    Mine came with a Deore FD but I'm planning to replace it with a chainguide. I'm using a triple-ring crank (Truvativ Blaze, came with the bike), but the outer ring is a bash and the inner ring gets no use. I have no plans to change that. The middle ring is 32t and the cassette is 11-34.
    I have a 140mm fork, and I'm sure 150mm would be fine. Marin says the bike has a 67 degree head angle and 34.5cm BB height. Yours would get a little slacker and taller, but not enough to really matter.
    Dec 2009
    I've had Hope rear hub for 12mm maxle. I also have spare set of Marin QR drop outs and usually run them as I can swap out with my 650B wheels.
    My terrain allows me to run 1 x 9 [ 28 x 11-34] .
    I've run 140 and 150 forks. For general trail riding I like the 140 as it is just a bit crisper in the single track. I just find myself pushing harder and faster in these conditions on the 140. If your doing All Mountain then 150 would be good.I usually run a Fox 140 as it allows me to run 650b.
    A 150 is not a problem , there's no wheel flop and no negative affect on the rear suspension. Just a bit more fork dive, less small bump compliance[ off loading the front] a bit slower steering and wander on the climbs.
    Pics
    Hey gvs,
    What is your headtube length. I'm trying to see if a pike with an 8" steerer tube would be ling enough on a medium frame. Can get a good deal in fork, but don't want tube too short.
    Also, looking to buy a wheelset. If you got an extra that fits, would be interested if you don't need.
    Dec 2009
    Quote Originally Posted by wolfbeast View Post
    Hey gvs,
    Marin Bikes | 2009 Collection | Mountain FRS | Quad Trail | Wolf Ridge 6.8 - Bubba Green
    Dec 2009
    No sorry. I think QR dropouts are about $40 from your local Marin Dealer. That would be the cheapest option.
  1. LBS building wheels
    By htfu_aaron in forum Wheels and Tires
    Last Post: 04-27-2011, 10:20 AM
  2. Replies: 1
    Last Post: 06-07-2010, 03:35 PM
  3. Replies: 39
    Last Post: 09-29-2009, 03:36 PM
  4. building a DH hardtail (components choice)
    By Y-rider in forum Downhill - Freeride
    Last Post: 10-02-2008, 06:55 AM
  5. Building an '06 Salsa Dos Niner - Need Components!
    By KurtisFreeRider in forum Salsa
    Last Post: 10-05-2005, 09:16 AM
