    Reputation: ciocc's Avatar
    Dec 2005
    New question here. 150/160mm fork on 2012 Mount Vision, bad idea?
    Just wondering if it's going to mess up the geometry of my 2012 MV when running a 150mm or 160mm Fox Float Fit.
    I know it's a different design and geometry, but since a Santa Cruz Blur LT can take anything from 140-160mm, can a MV do the same?
    Anyone out there has tried this?
    Dec 2009
    Shouldn't be a problem with the 32 Float. I've seen a few with Rev 150's which have a taller Ac than the 32 Float. The 34 and 36 set at 150 have a taller AC than the 32 Float though.
    I've run a Rev 150 on my WR with out any problems. i had to add 5 psi more air in the shock to balance it out. I've seen ridiculous size forks on other WR's but they were for Shuttle runs only. Anything more than a 150 would unbalance the rear suspension to much for general trail riding IMHO.
    Reputation: Kiwiplague's Avatar
    I have a 150mm Rev on my 2012 MV and it handles fine, the higher AC (axle to crown) has (in theory) only slackened the head angle by half a degree or so, so you should be fine with running a 150 Fox fork.
    I don't crash, I just have slightly uncontrolled dismounts!
    You also slackened the seattube-angle. And were you want to slacken the headtube-angle you don't want to mess with the seattube-angle. But moving to a 150mm would not cause a major change. 160 would ruin it unless you don't climb but only ride downhill.
  1. misaligned swing arm on marin mount vision 2012
    By jackovo_joe in forum General Discussion
    Last Post: 07-25-2013, 12:05 AM
  2. 2012 Stumpy Evo & 160mm fork?
    By bb47 in forum Specialized
    Last Post: 06-07-2012, 11:13 AM
  3. Marin Mount Vision shock mount - what size?
    By rekrutacja in forum Marin
    Last Post: 05-16-2012, 06:28 AM
  4. Just won a bid for 2010 Mount Vision 5.7 L
    By socalscott in forum Marin
    Last Post: 01-03-2011, 04:50 PM
  5. Mount vision pedal bob
    By richwales in forum Marin
    Last Post: 01-03-2011, 03:47 PM
