Results 1 to 3 of 3
    Sep 2004
    '08 Marin Mount Vision suspension question
    I received an '08 Marin Mount Vision today that I bought on Ebay. The seller said the suspension and whole bike had a service recently.
    When I sit on the bike and the rear suspension sags it feels like something is sticking. Is this the nature of air shocks or is there another explanation?
    Reputation: TB2005's Avatar
    Nov 2008
    Did you set the air pressure to your weight? Do you have between 12-15mm of sag on the shock? If it's sticking, the rear shock may need to be serviced, even though they say they did it, maybe they didn't? The rebound could be turned down way to slow as well, try speeding it up a few clicks.
    ...in Redmond,OR
    www.trinitybikes.com
    Make sure the rebound is not turned all the way in. It's the red knob on the shock behind the lockout knob. It should not be sticking at all.
