Results 1 to 2 of 2
    Sep 2004
    05 East Peak rear shock problem....
    on my rear shock the part that bolts to the rear swingarm is real loose,looks like the bushing in the eyelet of shock is worn out.can you get new bushings for these?
    its a fox float i think.also it has started slowly loosing air,do they make a rebuild kit for them?
    2009 Marin Mount Vision 5.7....a great everything bike...
    don't tread on me
    Yes, your mechanic can get Fox DU bushings. If they're shot enough to knock, it's usually a sound idea to replace the reducers as well. If you're loosing air, it could be that the can is unthreaded oh so slightly, or you need a rebuild - not that bad.
