    merlin works 4.0
    Stem Fsa Carbon Os 99
    Cranks Shimano Xtr
    Shift Sram Xo
    Rear Derealliers Sram Xo
    Whells Notubes, Dt Swiss 240 Front, Hadley Rear, Spokes Revolution
    Pedal Crank 4 Ti
    Handelbar Fsa Carbon
    Cable Nokon
    Brake Formula Oro Puro 180 Mm
    Seatpost Thomson Masterpiece
    Saddle Selle Italia Xc 180 Gr.
    Fork Fox F 100 2009
    Rear Shox Rp23 2008
    Nevegal 1.95 Whit Stan`s
    Front Derealliers Shimano Xtr
    Chain Shimano Xtr
    Total Weight 10900 Gr- 24 Lbs
    wow
    timan
    Reputation: sasquatch2's Avatar
    dream bike- can I have it's hand(-lebar) in marriage??? I'm assuming you race in some harsh terrain, where do you race? Your part spec is crazy awesome, probably worth more than my entire bike! How 'bout the frame- is the ICT rear suspension as efficient as they say, how about frame strength during out of the saddle efforts? Can ya give us a frame weight?
    Kick some hardtail out there!
    -S
    Work 4.0 with Fox F120
    Hello I`m from venezuela, the frame weight is 2392 gr (5,37 lbs). yes is so hard and nice to drive, the rear triangle is in aluminium (made by ellsworth), is very important to put the rear shox fox RP23 (The fox R is so bad), now I update the fork, i use fox F120, and is much better than F100, the geometry change a little but the new performance is amazing, i`m not race, i use in every place, i use it sometime in light down hill, (No jump, of couse) and the frame strenght, you dond feel anything is so strong. (i have , a ellswort epyfany too and is so similar the feeling when riding, (the ICT is not the difference) the difference is you multiple use that you make it.... (excuse me my bad english)
    Bye, Bye.
