Results 1 to 3 of 3
    Feb 2006
    LS obed FS help please...
    I am needing to replace the rear shock on my obed. But it seems it is hard to find one that fits. Any one know of a company that makes a replacement? Thanks, TIM
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by firebike
    Risse Racing Shocks in Redding, CA.
    I had that bike 9 years ago, my first FS. If you are using the stock shock, you won't believe the improvement from a Risse shock. Be sure to get rebound adjustment.
    Pretty bike. Smooth ride.
    - ray
    Reputation: itsdoable's Avatar
    I thought AMP was still supplying parts, you can probably get a rebuild from them.
    But... I would recommend the Risse Racing shock http://www.risseracing.com/amp.shtml. I used the Genesis shock on a LS Obed-FS - I thought it performed better than the original AMP shock, and went longer between re-builds.
