Results 1 to 2 of 2
    Sep 2004
    Litespeed Ocoee: rear tire clearance and fork travel
    Hi
    I can buy a 07 Ocoee but as I've never seen one and donīt have the chance to see any around here, I'd like to know if I can run 2.2-2.3 rear tires, and if is it OK to use my 120 mm Marzocchi Marathon fork.
    I would say that you should be alright with the tire size. I have a conti leader 2.1 on mine and there is at 1/4 to 3/8 of an inch on each side of the tire. I didn't remove my wheel, but it looks like there is about 2 3/4 inch where the widest part of the tire would be.
    I can't say much on the fork other than that the recommended travel is 80 to 100mm. The Ocoee is the race geometry, I think the travel that you are talking about is better suited to the Obed.
