Results 1 to 31 of 31
Thread: Yinding sources
    Yinding sources
    I'm going to begin biking to work a couple days a week here soon. Going to need a light for the early morning hours.
    I'm going to attempt the clone route (yes I know, I may be in for an interesting venture).
    Are there any sources for the Yinding 2x U2 in the US? If not I'll just snatch one from DX or Fasttech. I think I'm grabbing one of the 2x U2's first then adding a solarstorm for the bars later on.
    I'm always eager to hear thoughts on the setup as well?? Any other clones folks might think would be a better fit?? My commute will be short, about 6 miles.
    I like turtles
    Reputation: TiGeo's Avatar
    I assume you have spent some time looking through the Yinding thread(s)? I suggest going through Wallbuys..mine came in 3 weeks, was $45 delivered, and seems to be of sufficient construction. Its the XM-L2 version. There are not any U.S. sources that I have ever seen; its China or bust on these. The risk is low for $45. Another option for a nice light from a U.S. source would be one of the Magicshine 808s from action-led-lights.com for about $40 more. I can't see how the Yinding wouldn't be a good choice; you can geek out on the spill/throw blah blah blah but at the end of the day, its a bright light that will work fine for your application.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Alright. Mulligan.
    I'm almost certainly going with the yinding. What would everyone's recommendation be for another light, say, under $75 (on top of the yinding). And which would you run bar and which helmet. So total under $125ish.
    My riding is a combo, commute with the mtb in the am in the dark and occasionally mtb at night on a trail.
    I like turtles
    Re: Yinding sources
    Quote Originally Posted by carguy4471 View Post
    Alright. Mulligan.
    I already gave you a good choice. 808 from action with the Yinding will be $130ish. Amazon has the Securitying brand clones which would be ok too.
    Sent from my SCH-I545 using Tapatalk
    Quote Originally Posted by TiGeo View Post
    From fast tech I could get a ms brand 808e and the yinding for just about my budget. What's your take, 808 on the bars, yinding helmet? Should I get a wide angle lens for it?
    I like turtles
    I would do Yinding on the bar as it is more of a flood-type light; the 808 sans wide-angle is v. spotty and great for a look-around helmet light.
    I like turtles
    Here you go.
    Amazon.com: SecurityIng® Waterproof Super Bright 3 Modes 1200 Lumens CREE XML T6 Bulb LED Bicycle/ bike HeadLight, HeadLamp Flashlight, LED Light Cree T6 Headlamp Suitable for Cycling, Climbing, Fishing, Hunting, Camping and Other Outdoor Activities:
    Its $22....and with Amazon..you can return it if it sucks. So $22(+shipping for orders under $35)+$45=~$75. Seriously..how can you go wrong with this Yinding/Securitying combo meal deal?
    discombobulated SuperModerator
    Jun 2005
    my old MS was a pretty good light, I bet this amazon one is a bit better still....!
    Yinding on helmet and amazon 808 for bars it is then. I think I'll need a helmet mount for the yinding. ActionLED has gemini helmet mounts if that's the case.
    Any other items I should be picking up at the same time??
    Thanks for all the input!! I really appreciate it!!!
    I like turtles
    Yinding on bar 808 on helmet.
    Lol, that's what I meant.
    Oct 2012
    a yinding on the helmet with 10 degree spot lenses would be the way to go.
    So, two options.
    Stock yinding on bar, 808 on helmet.........
    or
    Yinding with spot on helmet (I found this one Action-LED-Lights — Gloworm X2 Spot Optic) and 808 on bar with flood (found this Action-LED-Lights — Wide Angle Lens).
    Thoughts??
    I like turtles
    Sure, the 808 with the wide angle works on the bars too. The one issue I have with it (I have this setup) is that it also decreases the light output quite a bit.
    I like turtles
    That is more of a flood light suitable for the bars...lots of info here (mega-thread I believe) about that light. You can analyze this to death. Get the Yinding, get the 808, ride.
    I like how you think. Ordered the yinding from fasttech and the 808 securityling (808) from amazon. Now I should just need a helmet mount which it looks like actionled carries. Any other nick-nacks you'd suggest??
    I really appreciate your input. I was on information overload and had a bit of paralysis happening.
    I like turtles
    Won't need anything else but a proper helmet mount. You can take the one that will come with both (it's set up to use on your head), cut off the straps, get a regular velcro strap with a buckle and make the existing one work. Will post a pic shortly.
    I like turtles
    Re: Yinding sources
    That looks easy enough. I guess I'll save an additional $12 on top of the couple hundred I just saved. Some days being a budget minded (see broke and underpayed) chap is sort of fun.
    Automotive Reconditioning Guru by day, firearms educator by night.
    Feb 2014
    Re: Yinding sources
    I have read all the posts as I can't be arsed
    Not seen if you ordered yet but avoid DX I been having but hessle mate to with his tablet order
    I'm using Yindings for both the helmet (using 15 degree optics) and the bar (using 45 degree optics). This combo is quite good as I get enough spill from the bar light and get the throw from the helmet light. BTW, I got 3 sets of Yindings all from Wallbuys. Never had any problems with shipping and the sets came in around 3-4 weeks.
    Jan 2013
    bongsta, I don't see the option to specify 15* or 45* optics from Wallbuys. Does the light come with both optics?
    The optics I bought from Reflector / Collimator Lens - LEDDNA
    KVW
    KVW is offline
    Law abiding citizen
    Reputation: KVW's Avatar
    Quote Originally Posted by bongsta329 View Post
    To be exact, is it this one? 15, 45, 60 degrees Lens for CREE XML XM-L LED - LEDDNA
    And just wondering - the lens being plastic and all, And you haven't had any melting issues?
    "Single track is for pansies!
    I blast down a mountain once, and in my wake, lies a new single track for the rest of you."-sm
    I like turtles
    Pardon my ignorance on this, but I assume the 15 narrows the beams into more of a spot for the helmet and the 45 spreads it out for the bar? What angle are the stock optics?
    I believe it was speculated that the stock lenses were 15, but their not marked so no way to tell for sure. The original ad stated they were 60 degree, but we know that to not be true. Optics also have a less defined cutoff so you can't really compare to a reflector like the 808's 10 degree.
    @KVW... Yes, that's the one. The original lens are also plastic. No melting issues and been using them since Dec.
    The stock lens looks something in between the 15 and 25 deg lens from leddna. The stock are definitely not 60 deg. The lens are cheap enough that I bought 10, 15, 25, 45, 60 degrees. For me the 15 and 45 degree combo worked the best.
    I like turtles
    So the 45 has a noticeable impact on the "spread" of the beam for bar use?
    45 degree has more spill but the throw is short. Definitely recommend the 45 deg if using bar/helmet 2 light combo. 25 degree is the best compromise for throw and spill. Better for single light application.
  1. User review: YINDING YD-2XU2 (Gemini Duo clone)
    By Kir in forum Lights and Night Riding
    Last Post: 12-04-2016, 08:36 AM
  2. Sources to buy signs.
    By bitflogger in forum Trail Building and Advocacy
    Last Post: 08-25-2012, 06:35 AM
  3. Front Wheel Sources
    By kosmo in forum 27.5
    Last Post: 10-04-2011, 09:22 AM
  4. Spoke & nip sources?
    By socalscott in forum 27.5
    Last Post: 03-10-2011, 01:18 PM
  5. 29er Wheelset Sources
    By JKeenan7 in forum 29er Bikes
    Last Post: 01-12-2011, 12:34 PM
