Hi All,
Xeccon released a new light, Xeccon Link, a built-in battery pack system light, I would like to share it with you all .
LED: Cree XM-L
Max Output: 300 Lumens
Running time: 1.7~18hrs
Mode: High>Low>Light Sensing>OFF
Battery: 4.2V 1000mah Li-ion battery
System Weight: 58g
Magnetic USB Rechargeable
Waterproof Standard: IPX7, Underwater for 2 Meters
Attachment 863588
Name meaning: Hope Xeccon Link can link the world, link you, him and me.
Design meaning: A boat shape, a Chinese meaning that trust and friendship, working closely and sharing the happiness and woe together, we are in the same boat.
1. Magnetic charging system
The first time that we use the Magnetic charging system on a bike light, to insure another level of waterproof for USB rechargeable light, up to IPX7, which make the light can be underwater 2 meters. The traditional USB rechargeable only can be water-resist, big move.
2. Light sensing
Xeccon still use the function of light sensing on the Xeccon Link to make it more humanized to save more powerful to change the brightness automatically according to the sunlight, also, we did some update for the light sensing technical to make a built-in light sensors like auto.
3. Safety key lock
According a lot of Xeccon customers’ support and suggestion, Xeccon finally import the Key Lock function to the light to avoid wrong operation when riding and safety in transit and stock.
4. Fast removable mount
To keep it from stealing, we improve a fast removable mount for the Xeccon Link, user can take the light head from the mount easily and carry it with you or carry it to your office for a charging.
5. Updates
Xeccon is using the double protection of charging system effectively to protect the life span of the light system.
New Cooling system to insure it still is touchable when it is burning on.
New reflector cup design system improved the efficiency of the brightness.
