Results 1 to 37 of 37
    Reputation: Texan-n-Fla's Avatar
    Sep 2013
    Where do you mount your battery pack?
    I'll be getting my first headlight with a rechargeable battery pack tomorrow. I plan on running it on the bars, and I'm curious what others have done as far as mounting the battery pack. So, share your expertise with me!
    Tradere Scriptura Magister
    Bourbon: Because no good story ever started with "So, there we were eating salads".
    Nov 2012
    I run my xeccon 6-cell battery, which came with an integrated and very long velco strap, on the frame top-tube near the front and close to the head tube. I used to use a 4-cell magicshine battery that went in a saddle bag with an extension wire.
    May 2005
    Strapped to the seat post
    I like turtles
    Reputation: TiGeo's Avatar
    Top of top tube near the front. Held on with a Backcountry Tube Turnequit.
    Sent from my SCH-I545 using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    I mount my battery under the stem. I use to do it on the frame, but it moved around a bit too much for me, but that can just depend a lot on the design of the frame, etc.
    Where ever you mount it, it definitely helps to have a bag with 2 straps, like these.
    A lot of the cheaper/Chinese lights come with bags with one strap, and I don't like them as much.
    Or if you want to spend a little more, and get a bag/case that will also help protect the battery in the event of a crash, there's these from MTBRevolution (and possibly elsewhere). A little more bulky, but the one wide strap is easy to use and nice and secure.
    I like turtles
    The straps from Backcountry are great for this app. They have a non-slip backing so it won't move on the frame. It seems that the stem or hbar is a rotten place for a weight to be strapped on.
    Quote Originally Posted by TiGeo View Post
    I can't say I've noticed the weight.
    Btw, do you have a link to the straps you mentioned?
    I like turtles
    Google...for the love of God man...
    Reputation: ironbrewer's Avatar
    Oct 2012
    Strap it to the top of my down tube.
    Thanks.....
    Seat tube water bottle cage.
    I like turtles
    How much more do you want? I gave the namd of the strap and the company's name. I may be a dick today but at least I am not lazy.
    Sep 2013
    Ladies, that's enough, thank you. If you wish to bicker, take it elsewhere.
    I got the light in today. I immediately thought of dropping the pack into a spare bottle and running it through that, just because I have nothing better to do.
    Considering I included links to the items I was talking about, I'd hardly say I'm lazy.
    With that said, I did miss your first post that mentioned the brand name. My apologies.
    Here's the link to the Tube Tourniquet that TiGeo mentioned.
    Reputation: androgen's Avatar
    Apr 2005
    two batteries on the bottom side of the top tube - one for headlight, one for tail light.
    I like turtles
    Didn't mean to be quite so turse...appologies.
    Oct 2012
    I mount my battery under my stem. Battery is in a Chinese case, yes a two strap version would be better. I strap it on with the single strap, connect the plug then I use an old school toe clip strap around everything. No problems, doesn't go anywhere and keeps all the wire in one place. O, and I wrap almost all the wire from the battery at the top of the battery in the cheap case and then fold the top cover over. Keeps it out of the way and short!
    Just a misunderstanding, we're good.
    I like turtles
    Man....a red chicklet for that one...I will be nice and won't throw one back your way
    Reputation: jetboy23's Avatar
    I put mine in an old water bottle. Similar to this...
    It doesn't wiggle, jiggle, or fall off (with a good cage that is). Also, its mostly protected from the elements.
    Nov 2012
    My li-po cells are in an ebay bag: AU Cycling Bicycle Bike Top Frame Pannier Front Tube Saddle Bag Pouch Outdoornew | eBay
    with some added protection to prevent damage from crash. It is attached to a saddle & tube on a full suspension bike.
    Sep 2013
    Quote Originally Posted by jetboy23 View Post
    I think this is the route I'm going to take. I like the fact that it doesn't stand out, and is better protected from the elements than in a bag.
    Nov 2012
    Does the battery bounce around the inside of the bottle?
    Reputation: ljracer's Avatar
    I put two batteries in a sks tool box bottle. Using waterproof cable glands.
    Wrapped in bubble wrap. No shaking or movement!
    May 2005
    When I did 24 hr races the promoter required bottle mounted batteries have an auxiliary strap or tape to guarantee they would not pop out of a cage. Seems they had a bad OTB crash from a battery popping out and getting caught in between the spokes. Of course batteries were very heavy then compared to now.
    Viva la Vida!
    Reputation: Camaleon's Avatar
    I use Niterider Lumina all in one piece no need to mount extra batteries
    We do not stop playing because we grow old;
    We grow old because we stop playing
    I like turtles
    Here is mine. The strap from Backcountry Research works KILLER for this application...v. secure. I have a GeoMan battery and the base is contoured to fit round top tubes; mine is more square and even then, it doesn't move. Before I was using the Backcountry strap, the battery came with a generic velcro strap that allowed the battery to rotate around the tube; the Backcountry strap has a rubberized backing that prevents movement and grips the tube securely.
    Attached Thumbnails Attached Thumbnails Where do you mount your battery pack?-20131026_231547.jpg
    Reputation: sohnice's Avatar
    My SL-R frame has a hole just nice for mj-880 6cell battery.
    Nov 2007
    Thanks for the direction to Backcountry Research, have been searching for a while now to find a durable velcro strap that holds a few bits and bobs onto top tube!
    quiggs
    I like turtles
    Quote Originally Posted by quiggs1974 View Post
    quiggs
    You won't be disappointed. I use their "Race II" strap to hold my tube/lever/CO2 under my seat. Great products..love supporting innovation by small US businesses!
    May 2012
    I made a carbon fibre bracket to strap mine to the down tube waterbottle fittings.
    Reputation: DustyTrail's Avatar
    Aug 2015
    I know this is an old thread but figured I'd see what people are using these days to mount their battery packs and where?
    I recently purchased a BT40s kit as well as an extra Action LED 4 cell battery.
    The Action LED battery came with rubber straps that latch and am wondering if it will be safe enough to use out on extremely rocky terrain???
    I noticed some people house their battery pack in their water bottle.... i like this idea but wanna know what other options I have!
    Rick~
    16' Superfly 9.6
    Tucson, Az.
    May 2005
    I go under the top tube as far forward as possible. I have the Panovo(?) 4 cell case that comes with a nice nylon/Velcro holder, I also use a cheap Velcro strap to make it extra secure.
    I like turtles
    I use the new Magicshine batteries that have the rubber straps. On top of the top tube toward the front...can only go so far forward as the cable stops get in the way. Perfect location and keeps the cable nice and short. And no...you won't hit your balls on it.
    Attached Thumbnails Attached Thumbnails Where do you mount your battery pack?-uploadfromtaptalk1445632713145.jpg
    Quote Originally Posted by DustyTrail View Post
    When mounting a battery to a frame a lot depends on the frame itself, where the shifter/brake lines are mounted and lastly the length of the power cords.
    I think most people typically mount the battery "under" the top tube and as close to the stem as possible. I mounted my battery there for years. Takes some practice threading the straps under the shifter cables/brake line but easy once you discover the trick ( when using Velcro straps ).
    Currently I use a Xeccon battery with supplied pouch. The Xeccon pouch has a very nice built-in ( wide ) Velcro strap/buckle that when properly secured holds the battery in place very well. A couple years ago I started strapping mine down on the top side of the down tube ( as high as possible ). It took me a while to get used to the look but really it's easier to do since I have no shifter cables on the down tube. Picks up a little more dirt mounted there but it's not a big deal.
    On my road set-up I just put the battery in my (aftermarket) small triangle frame pouch that I put all my other road stuff in. ( mounts in front between head tube, top and down tube ). Of course people with more racing style bikes usually like as less stuff mounted to the frame as possible. With my touring set-up the frame pouch works for me and leaves my "under seat" area clear for other stuff. I've seen people mount batteries under the stem too. What ever works.
    It's really not so important what it looks like, really. You're riding at night back in the woods. Who's gonna see where you mount your battery? The major issue for me is always function over form. I gave up worrying about how all the "light stuff" looked on my bike ( and helmet ) years ago. The important stuff is that I have reliable lamps and batteries and that they work long enough for me to complete my rides.
    I use a water bottle and have for a while now. I am not at all worried about the weight and use a very high power Li Po battery as I have a high power - high drain lighting setup.. but it is worth it.
    Battery is protected and the the bottle keeps out the elements.
  1. Battery pack for camera?
    By cstem in forum Lights DIY - Do It Yourself
    Last Post: 09-12-2014, 07:00 AM
  2. Battery pack help
    By Pete N in forum Lights DIY - Do It Yourself
    Last Post: 09-12-2013, 10:06 AM
  3. Help with battery pack mount
    By henry9419 in forum Lights DIY - Do It Yourself
    Last Post: 04-17-2012, 03:29 PM
  4. battery pack!
    By elbry in forum Mountain Cycle
    Last Post: 02-16-2011, 12:51 AM
  5. pre-made battery pack vs. battery cell holders
    By Andy13 in forum Lights DIY - Do It Yourself
    Last Post: 01-28-2011, 11:58 AM
