Results 1 to 6 of 6
    What's the best method to mount a WF-502B flashlight so it points behind me??
    So I had a drop-in customized for my WF-502b host. It's red and does 10hz strobe at ~200 lumens.
    Now I need to figure out how to mount it pointing backward on my bike...
    Any suggestions?
    Sep 2012
    How about a Two Fish block on the seatpost?
    Quote Originally Posted by Ian_C View Post
    I thought about that, but I'd like something more secure.
    Actually...I think the fenix ALB-10 is exactly what I'm looking for.
    Reputation: mtbRevolution's Avatar
    Quote Originally Posted by Bryank930 View Post
    Any suggestions?
    What I suggested in tail light mounting thread a few days ago would still work here. Remove the rear seat clamp bolt and slip in a U bracket best made of thicker aluminium (although pic is steel) to prevent vibration due to the length and weight of the WF-502B. Use a stainless steel hose clamp with small strips of old tube to fit in between the clamp, bracket and torch. You can spray the clamp black or get a colored if available.
    What's the best method to mount a WF-502B flashlight so it points behind me??-stainless-steel-hose-clamps.jpgWhat's the best method to mount a WF-502B flashlight so it points behind me??-long-u-type-servo-bracket-3-600x600.jpg
    Leonard - All things Xeccon + Beyond
    mtbRevolution.com
    I thought I'd point out that if you mount a torch to the side of the seat post there is a very good chance that it will hit your leg when you ride.
    I mounted a Ultrafire 501-B torch underneath my seat by attaching it to one of the rails. To get this to work I used a very long stretch of Velcro that had a plastic loop on one end. My seat has a hole in the middle and somehow I managed to loop it across the seat >through the hole and back around the other side of the torch. To get it aimed right I used pieces of soft foam and a couple more pieces of Velcro. Somehow it holds it in place and I can activate it by just reaching under the seat. The strap is flat enough that it doesn't bother my butt ( thankfully ). The downside is that I can't take it off or I'll probably never get it right again. The drop-in I use is a custom amber for Daytime use. The UI has several flash options.
    Somewhere I once saw a guy who made a custom bracket to fit across his seat rails. he than mounted the torch to the bracket. Best torch/seat set-up I've ever seen. Won't work though if you use a seat bag.
  1. Fenix ALB-10 flashlight mount
    By spankone in forum Lights and Night Riding
    Last Post: 11-14-2014, 03:43 PM
  2. Handlebar mount for 40mm diameter flashlight?
    By zuuds in forum Lights and Night Riding
    Last Post: 09-26-2013, 04:19 PM
  3. Best helmet flashlight mount solution?
    By Dogdude222 in forum Lights and Night Riding
    Last Post: 08-13-2012, 07:03 PM
  4. Custom Flashlight mount Idea.
    By walkertalker in forum Lights DIY - Do It Yourself
    Last Post: 01-28-2012, 02:01 AM
  5. Fenix Bike Flashlight Mount, so cheap?
    By ancndd in forum Bike and Frame discussion
    Last Post: 01-12-2011, 05:50 PM
