Page 7 of 10 FirstFirst ... 3 4 5 6 7 8 9 10 LastLast
Results 151 to 175 of 229
  1. #151
    Ride 'Til Your Knees Hurt
    Reputation: cycljunkie's Avatar
    Re: User review: YINDING YD-2XU2 (Gemini Duo clone)
    Quote Originally Posted by TiGeo View Post
    How to you make special requests when ordering from Hunk Lee? I got one of his batteries and wished I had known..didn't have the good connectors (MS-type that snap tight). Also interested in a screw-type fitting for my Solar Storm.
    When you check out on eBay, you can add a message to the seller. I just asked him to include the waterproof screw type connectors. I emailed him earlier and he said it was no extra charge.
    Sent from my Samsung Galaxy S3
  2. #152
    Reputation: znomit's Avatar
    Quote Originally Posted by cycljunkie View Post
    I didn't ask, mine came with a spare lead that has the screw connector.
  3. #153
    Nov 2012
    ^^ Edzackery
  4. #154
    Same for me. Message at check out and no extra charge for both screw type leads and balance connector.
  5. #155
    Can anyone yell me which charger to use for this battery?
    I have the following chargers. The one on the left came with my YinDing Duo clone. The one on the right is from my MagicShine light.
  6. #156
    Reputation: Sirius9's Avatar
    Apr 2013
    They will both do the job, the left one will be a little bit slower and the right one will be about double faster...
  7. #157
    Next dumb question from a know-nothing like myself... Before I cut the lead from my YinDing Duo clone, can someone tell me which wire connects to the red wire and which one goes to the black?
  8. #158
    Quote Originally Posted by Sirius9 View Post
    Cool Thx!
  9. #159
    Apr 2013
    red wire is + (positive lead) -> middle of the conector
    black wire is - (negative lead) -> outer part of connector
  10. #160
    Red to red, black to black
  11. #161
    I'm going to assume red to red and black to blue?
  12. #162
    Nov 2012
    You need a multimeter to find out the battery wires polarity. The red may be + but you need to be sure.
  13. #163
    Quote Originally Posted by MK96 View Post
    Fresh out of multimeters. There has to be someone on this board that replaced the lead on their YinDing Gemini Duo clone... Anyone?
  14. #164
    The guy at batteries plus was worthless. What do I need to do to determine which wire to solder to which? Can anyone help me out?
  15. #165
    The battery says "red inside + and black outside -".
  16. #166
    Tore apart the original connector and the red wire is inside +, blue wire outside -
  17. #167
    All is well... Now I just need to go for a ride!
  18. #168
    What exactly did I get?
    Ok, so I just got two lights from Fasttech. One has a lens gasket and is soldered much better with standard machine screws holding it together. It also has a slight greenish hue when on (seems a touch brighter). The other has no lens gasket appears to be re-soldered (poorly), has standard philips head screws and projects a whiter light. So how badly did I get screwed over here? What would you do to fix it? Also wondering if its normal for a fully charged battery to set the button LED color to red directly after turning it on?
    User review: YINDING YD-2XU2 (Gemini Duo clone)-20140610_173053_1.jpg User review: YINDING YD-2XU2 (Gemini Duo clone)-20140610_173300_1.jpg
  19. #169
    Nov 2012
    You need to add the gasket and change the wires optionally. These seem to be soldered ugly and may fail overtime. ... and check the driver side also At least they seem to have the same optic.
  20. #170
    Aug 2014
    Hi, I'm new here and instead of splicing power cable why not opne up light and solder new lead directly? Is cable too short? Anyway that's what I'd do.
  21. #171
    Aug 2014
    So, can anyone tell me if this light is still a good light as original poster reviewed or has light changed (cheaper mfg.) as to make it not worth the price. I have a Gemini Duo and want to get another so I have bar and helmet lights. I've read the entire post and saw the links to other reflectors/lens so I could modify one of the lights.
    A few of the newest posts have been from people complaining of quality issues, changes in parts, does anyone know where I could get the Yinding like the one reviewed or are they long gone? Thanks
  22. #172
    May 2005
    In my experience the light you get this week from China will most likely be different than the one you get next week.
  23. #173
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Quote Originally Posted by RochesterMTB View Post
    my yinding does that on occasion. solution is unplug then plug back in and repeat until you get it to go green
    I think it detects low power instantly from the thing being connected, and triggers the low batt function too early. it should have a delay on that circuit. anyhow, mine does that once in a while and if I reconnect it, it will go green eventually and good to go.
  24. #174
    because GIANT
    Nov 2013
    Quote Originally Posted by Vancbiker View Post
    apparently returns are being recycled
    no one knows for sure wtf is going on
    I happened to get I think one of the 'perfect originals' but now they are all over the place. only thing consistent is the body shape, and circuit board inside says YinDing on it. otherwise it's all been changing around.
    what I say original:
    translucent white silicone gaskets
    TIR lenses
    quality internal paste and soldering job
    allen screws not stripped
  25. #175
    What surprises me is that some people don't seem to understand that when buying cloned lamps that nothing is set in stone. If you want something more concrete you buy a brand name lamp. Why do you think when the Yinding came out they were referred to as "Duo" clones? Didn't surprise me at all when the internal design was changed.
  1. Solarstorm x2 + Gemini Duo clone?
    By Posher in forum Lights and Night Riding
    Last Post: 06-09-2014, 10:54 AM
  2. User Review: Shadow BL20
    By Kir in forum Lights and Night Riding
    Last Post: 01-20-2014, 12:14 AM
  3. User review Fenix BT20
    By pucked up in forum Lights and Night Riding
    Last Post: 08-30-2013, 08:25 AM
  4. User Review: Xeccon S-12 ( Cree U2 )
    By Cat-man-do in forum Lights and Night Riding
    Last Post: 07-22-2013, 06:44 AM
  5. Gemini Titan Light review
    By baker in forum Lights and Night Riding
    Last Post: 04-18-2011, 07:05 PM
