Page 4 of 5 FirstFirst 12345 LastLast
Results 151 to 200 of 248
  1. #151
    Ride 'Til Your Knees Hurt
    Reputation: cycljunkie's Avatar
    Re: User review: YINDING YD-2XU2 (Gemini Duo clone)
    Quote Originally Posted by TiGeo View Post
    How to you make special requests when ordering from Hunk Lee? I got one of his batteries and wished I had known..didn't have the good connectors (MS-type that snap tight). Also interested in a screw-type fitting for my Solar Storm.
    When you check out on eBay, you can add a message to the seller. I just asked him to include the waterproof screw type connectors. I emailed him earlier and he said it was no extra charge.
    Sent from my Samsung Galaxy S3
  2. #152
    Reputation: znomit's Avatar
    Quote Originally Posted by cycljunkie View Post
    I didn't ask, mine came with a spare lead that has the screw connector.
  3. #153
    Nov 2012
    ^^ Edzackery
  4. #154
    Same for me. Message at check out and no extra charge for both screw type leads and balance connector.
  5. #155
    Can anyone yell me which charger to use for this battery?
    I have the following chargers. The one on the left came with my YinDing Duo clone. The one on the right is from my MagicShine light.
  6. #156
    Reputation: Sirius9's Avatar
    Apr 2013
    They will both do the job, the left one will be a little bit slower and the right one will be about double faster...
  7. #157
    Next dumb question from a know-nothing like myself... Before I cut the lead from my YinDing Duo clone, can someone tell me which wire connects to the red wire and which one goes to the black?
  8. #158
    Quote Originally Posted by Sirius9 View Post
    Cool Thx!
  9. #159
    Apr 2013
    red wire is + (positive lead) -> middle of the conector
    black wire is - (negative lead) -> outer part of connector
  10. #160
    Red to red, black to black
  11. #161
    I'm going to assume red to red and black to blue?
  12. #162
    Nov 2012
    You need a multimeter to find out the battery wires polarity. The red may be + but you need to be sure.
  13. #163
    Quote Originally Posted by MK96 View Post
    Fresh out of multimeters. There has to be someone on this board that replaced the lead on their YinDing Gemini Duo clone... Anyone?
  14. #164
    The guy at batteries plus was worthless. What do I need to do to determine which wire to solder to which? Can anyone help me out?
  15. #165
    The battery says "red inside + and black outside -".
  16. #166
    Tore apart the original connector and the red wire is inside +, blue wire outside -
  17. #167
    All is well... Now I just need to go for a ride!
  18. #168
    What exactly did I get?
    Ok, so I just got two lights from Fasttech. One has a lens gasket and is soldered much better with standard machine screws holding it together. It also has a slight greenish hue when on (seems a touch brighter). The other has no lens gasket appears to be re-soldered (poorly), has standard philips head screws and projects a whiter light. So how badly did I get screwed over here? What would you do to fix it? Also wondering if its normal for a fully charged battery to set the button LED color to red directly after turning it on?
    User review: YINDING YD-2XU2 (Gemini Duo clone)-20140610_173053_1.jpg User review: YINDING YD-2XU2 (Gemini Duo clone)-20140610_173300_1.jpg
  19. #169
    Nov 2012
    You need to add the gasket and change the wires optionally. These seem to be soldered ugly and may fail overtime. ... and check the driver side also At least they seem to have the same optic.
  20. #170
    Aug 2014
    Hi, I'm new here and instead of splicing power cable why not opne up light and solder new lead directly? Is cable too short? Anyway that's what I'd do.
  21. #171
    Aug 2014
    So, can anyone tell me if this light is still a good light as original poster reviewed or has light changed (cheaper mfg.) as to make it not worth the price. I have a Gemini Duo and want to get another so I have bar and helmet lights. I've read the entire post and saw the links to other reflectors/lens so I could modify one of the lights.
    A few of the newest posts have been from people complaining of quality issues, changes in parts, does anyone know where I could get the Yinding like the one reviewed or are they long gone? Thanks
  22. #172
    May 2005
    In my experience the light you get this week from China will most likely be different than the one you get next week.
  23. #173
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Quote Originally Posted by RochesterMTB View Post
    my yinding does that on occasion. solution is unplug then plug back in and repeat until you get it to go green
    I think it detects low power instantly from the thing being connected, and triggers the low batt function too early. it should have a delay on that circuit. anyhow, mine does that once in a while and if I reconnect it, it will go green eventually and good to go.
  24. #174
    because GIANT
    Nov 2013
    Quote Originally Posted by Vancbiker View Post
    apparently returns are being recycled
    no one knows for sure wtf is going on
    I happened to get I think one of the 'perfect originals' but now they are all over the place. only thing consistent is the body shape, and circuit board inside says YinDing on it. otherwise it's all been changing around.
    what I say original:
    translucent white silicone gaskets
    TIR lenses
    quality internal paste and soldering job
    allen screws not stripped
  25. #175
    What surprises me is that some people don't seem to understand that when buying cloned lamps that nothing is set in stone. If you want something more concrete you buy a brand name lamp. Why do you think when the Yinding came out they were referred to as "Duo" clones? Didn't surprise me at all when the internal design was changed.
  26. #176
    because GIANT
    Nov 2013
    basically this
    some maker in china will tool up and produce 10,000 units and sell them and wait for another order
    times goes by and returns come in, replacements go out
    the maker then figures rework the returns and slap into the next 10,000 run. and continue to cut costs and cut costs forever.
    only if a buyer demands quality and pays a premium will the maker put more effort in a production run, otherwise the lights start out as 'pretty good' and as time goes by they get diluted with junk. scraps get picked up by third parties and resold perpetually, including failed laptop battery packs which are reinvented into 3x and 4x18650 light battery packs.
    you get what you pay for and the retail price for 'big name lights' is about market value for well constructed, tested, QC'ed, proper light systems. DX, alibaba, etc is the opposite end of the spectrum. chinese lights can be a total money saver but you cannot nor should you ever expect them to last long. always be prepared to mcguyver it, to keep it alive....or just order more cheap replacements periodically (what I am doing...sometimes you land on a light that really does it all for very lo bucks)
  27. #177
    Apr 2013
    Has anybody tried this one? At least it looks interesting but how the quality is i don`t know...
    New Generation XM L2 X2 CREE LED Bike Bicycle Light Headlight Cycling 5000LM | eBay
  28. #178
    I like turtles
    Reputation: TiGeo's Avatar
    Quote Originally Posted by Belse View Post
    Here are some threads on this light:
    New cheapo Chinese LED bike lights 2014 - please post info/link/review link here :)
    New 2x XML-2 on lightmalls
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2012 Specialized Stumpy EVO 29 HT
  29. #179
    Feb 2014
    Just want to share the results on my Chinese Roulette Game. Placed an order on: Waterproof 2300LM 2X CREE XM L U2 LED Bicycle Light Rotatable Bike Light & 8.4V 4400mAh Rechargeable Battery Pack & Charger-in Bicycle Light from Sports & Entertainment on Aliexpress.com Got a totally different thing.
    Did not get the Yinding (as described), but another one from SecurityIng. Did not test it yet on the trails but it does look good. Neutral White indeed; 10 stepless mode and CE certification. Was afraid I would have to pay more when shipping it to Portugal, but did not because it was sent from Netherlands apparently and because it had CE all over the package. I don't have much to say right now, so please take a look at the pictures.
  30. #180
    Reputation: Ofroad'bent's Avatar
    I'd unscrew the mount and see if it's sealed under there. It isn't the model shown on alibaba with the front screws and the cable exiting separately with what looks like a waterproof fitting. The lightmalls clone had a barely water resistant (if at all) fitting that held the mount and cable.
  31. #181
    Feb 2014
    I'm not home right now, but will definitely open it up (also because I'll be using vancbiker's GoPro adapter). I'm just waiting for some other parts and the SS X2 before buying it from him...
  32. #182
    Reputation: spankone's Avatar
    My yinding looks ok although the ano is scratched and it's missing orings to help keep the water out.
  33. #183
    http://youtu.be/aut4Ntx6F2s
  34. #184
    Feb 2014
    Hi all I like to make my Yinding more of a spotlight as it on my lid. I looked at DX not that I like using them at Lens.
    I don't know what size of plastic bits are I have in unit. Anyone changed got a link please.
  35. #185
    Reputation: garrybunk's Avatar
    Feb 2014
    I'm not sure what the size is, but I would check out LED DNA. TIP - Use coupon code BLF15 for 15% off your order. (I've purchased some of the XM-L optics which are currently $0.40/ea (not the $1.00 ones). Of course if these optics aren't the right size then this info is no good to you.
    -Garry
  36. #186
    This is the one you want for a spot. You have to remove the white plastic bit for them to fit. I have bought and used the 10, 45 and 60 degree lenses from there and they work great to customize your beam pattern.
    10 Degree 21mm Reflector Collimator LED Lens For Cree XML XM-L LED - LEDDNA
  37. #187
    Feb 2014
    I have a little project going on for which I will be taking comparison photos of different optics with a single XM-L2 and posting over at BLF. I can PM you the link when I get it posted. I do think the 10degree ones are what you want. And I would imagine somebody has posted beamshots comparing the different optics here on MTBR somewhere.
    -Garry
  38. #188
    I like turtles
    Found a great home for my Yinding....my road bike! Works great. Now that it is dark when I leave for mid-week rides.User review: YINDING YD-2XU2 (Gemini Duo clone)-uploadfromtaptalk1410438723847.jpg
  39. #189
    Sep 2004
    Anyone compare the Yinding to the Securitylng light? Thinking about getting one of these and the Securitylng is available on Amazon for $38 with free 2 day shipping. If the performance of the Amazon light is similiar to the Yinding I'll go with that one just for the quick shipping. Also easier to return it if there's a problem. I could care less about waterproofing. I don't ride in the rain.
  40. #190
    Feb 2014
    Garrybunk & Robs31 thanks for URL and code I now odder new lens
    mm may get another Yinding but like the look of the Ultrabright 3*Cree XM-L2 5-Mode what MK 96 posted.
    Last edited by Smoke&Lasers; 09-12-2014 at 05:22 AM. Reason: don't know why there URl in post!
  41. #191
    I like turtles
    Quote Originally Posted by slsl123 View Post
    Someone above had posted on the Securitying version.
  42. #192
    Ok, so I've been a long time lurker. This is my first time posting.
    I've had my eye on the original Gimini Duo and Gloworm X2 for quite some time now, but have always been reluctant picking one up due to price.
    So last week I stumbled across some of these clones on DX and ended up purchasing a Securitylng version off amazon for $39. Shipping was super fast (3days).
    My main use will be for night skiing/snowboarding. I frequently ride in between lit runs in the trees where the snow is usually still untouched.
    Everything works as expected. Although after disassembly i was a bit concerned about a few things (don't worry i wasn't expecting this to be a top notch unit, and figured it might need some tweaking )
    First and foremost, I'm not to sure how long this unit will last given the poor heat management. The LED slug only really makes contact with the light body at the two screw down locations. It maybe makes a bit of contact on one side of the slug as you can see in the pictures. Ill be adding some thermal paste around the screw mounts to hopefully give it a tiny bit more heat transferability.
    Second, obviously this isn't water proof and I probably wouldn't even call it water resistant. There's no O-ring in the back end and the giant open hole in the bottom where the mount attaches doesn't really help either. Ill try and find an O-ring for the back half. As for the hole on the bottom I was thinking about switching to "vancbiker's" aluminum GoPro mount possibly with some cooling fins milled into the side. Then seal it up with some silicone.
    Not sure if i trust the battery or not. As you can see in the pics there is some sort of circuitry included, be it for charging or protection or both i don't know. It also looks like the individual cells may have protection as well (you can see what might look like a protection circuit on top of each cell). Either way i plan on using my 5Ah RC Lipo's with inline protection (still looking for a small circuit i can add inline).
    Also, i couldn't get the power connector to fully seat. I ended up using some sandpaper to sand down the ridge a little bit. Snaps in like a charm now.
    I'm quite happy with the selection of brightness modes though. Powered up, button lights up green and starts in the low brightness setting of the 3 main settings (low/med/hi). While in any one of those three brightness setting pressing and holding the button will enter into a more detailed menu with 10 brightness levels. If the light is off and you press and hold the button it will go into a steady flash mode.
    I'll test the run time once i get some thermal paste.
    Overall I'm quite happy for the price point. Even if it only lasts me a season or two.
    On to the pics!
    (Quick shipping from amazon, packaged well)
    (Main brightness selection mode. low/med/hi)
    (Sub brightness menu with 10 level settings)
    (Giant hole in the bottom...)
    (Two small set screws that hold the back end by pressure only...)
    (Thin aluminum slug for heat dissipation)
    (Back of the aluminum slug. As you can see it really only makes contact on one side, and barely at that)
    (The two mounting surfaces for the slug, ill try and add some thermal paste here)
    (4 cell pack. 2s/2p.)
    (My RC Lipo which i plan on using)
  43. #193
    Feb 2014
    Whoa! I literally just minutes ago took many of the same photos of my Kaidomain Duo clone! Mine is the same except that I have a different driver without the programmable modes. How much current does yours pull from the battery pack on high? Is yours an 8.4v or 4.2v version. Mine is 4.2v (threw me for a loop as I bought it head only) and won't even run on 8.4v.
    For an idea on helping with the heatsinking, you could fill begind the emitter plate and up close to the driver with JB Weld (a permanent solution) or search BudgetLightForum.com for "Reversible Potting Option for drivers" or something like that. It uses silicon carbide mixed with "duct seal". That's my choice.
    -Garry
  44. #194
    Not sure about current draw yet. I'll be picking up a few supply's tomorrow (thermal paste and some new Anderson connectors). With the new connectors ill be able to connect to my existing lipo battery's as well as my inline Watt meter (reads voltage, amp draw, etc). I'm quite interested in finding out what the current draw is, i have a feeling that they are under powered. If they are using Cree XM-L die's they should be pulling close to 3amp's each...
    4.2v? That seams a bit odd. Each LED is rated for 3amp's @ 3.1V
    Can you post some of those pics you took?
  45. #195
    And thanks for the info on the reverse potting. Sounds like it might be a good option considering how poorly these LED's a set inside the housing.
  46. #196
    Quote Originally Posted by Trevs View Post
    Actually, it is not that odd. It just means that his emitters are arranged in a parallel configuration. Your Securitying® lamp is likely using a board arranged in series. This is one of the reasons though that you have to read all the product descriptions when buying stuff from the Chinese web sites. If they don't list the battery or power requirements you have to send them an email to ask. While doing that you might ask them how the leds are configured as well. It can't hurt to ask, particularly if you are considering modding the lamp.
    Since you mentioned being interested in the current draw it would be more interesting to know what current is being supplied by the driver to the emitters. You could find that out if you unsoldered one of the power wires coming off the driver and placed a multimeter ( set for DCamps ) in series. Turn the lamp on high and you will have an answer. That said I don't know why it would be important unless you plan on trying to alter the driver. While I've heard of people altering the sense resistors I'm not sure that is a good thing to do.
    Anyway, I like the look of your Securitying® Duo clone lamp. I also like that it includes the variable output sub-mode for changing the mode outputs (if you choose to do that ).
    A couple questions for you: How long did it take for you to get your lamp and where was it shipped from? Since you seem to have a nice camera, is there anyway you can include some outdoor beam shots?
  47. #197
    Sep 2004
    I picked up the Securitying Duo clone light a couple months ago. I received mine in two days- I chose a seller that uses Amazon to fulfill the order. I think that may mean it ships from Amazons distribution center, whereever that may be. I returned it after giving it a quick test run. It throws a nice wide bright even beam with no hot spots. But when I tried to run the light on the highest brightness setting for more than 30 seconds or so the led would turn red and the light would dim. This was when riding on the road at about 15mph.
  48. #198
    Cheap powerful compact light. Too bad about the poor tint of the LEDs (too blue-ish for optimum detail on trails), poor heat sinking, garbage batteries and very poor waterproofing. Once I heat sinked mine, used my own battery pack, waterproofed it and changed the mount it's not bad, but I would need to change the LEDs to be happier. Still, it cost peanuts.
  49. #199
    Sounds like a bad driver. Did you have a problem getting it replaced?
  50. #200
    Feb 2014
    Or poor heatsinking? Mine (KD) ran fine for the few minutes that I used it taking beamshots and playing around with it.
    Pics will follow later when I get more time.
    -Garry
  1. Solarstorm x2 + Gemini Duo clone?
    By Posher in forum Lights and Night Riding
    Last Post: 06-09-2014, 11:54 AM
  2. User Review: Shadow BL20
    By Kir in forum Lights and Night Riding
    Last Post: 01-20-2014, 01:14 AM
  3. User review Fenix BT20
    By pucked up in forum Lights and Night Riding
    Last Post: 08-30-2013, 09:25 AM
  4. User Review: Xeccon S-12 ( Cree U2 )
    By Cat-man-do in forum Lights and Night Riding
    Last Post: 07-22-2013, 07:44 AM
  5. Gemini Titan Light review
    By baker in forum Lights and Night Riding
    Last Post: 04-18-2011, 08:05 PM
