    Feb 2012
    Troubleshooting DX Cree light
    Bought one of the DX lights for an 18 hour race. This one:
    Buy ZXC-01 Cree XM-L T6 910lm 3-Mode Memory White Bike Light - Black (4 x 18650)
    Worked fine for a week, now I can't get it to work. I plug it in and it shows fully charged, and a check with a volt meter shows full charge. When I plug it into the light, The on/off button shows red (signaling dead battery) and it will only give me one level of light rather than three.
    Can anybody suggest what's wrong and what I might do to fix? Out of the return policy I'm afraid.
    Thanks much.
    Mar 2006
    You may have to open up your light to see if there are any loose wires inside. Or if you have a buddy that you can plug your battery into to see if it'll light up. You'll know it's not the battery if it does.
    "By Your Command"
    May 2005
    Most likely a bad driver in the light head. Like Pucked says open it and look for broken wires or obviously burned components. If there is an inductor on the driver (donut shaped thing with coils of wire wrapped around it), check closely for where those wires solder to the board. I've seen that before. Otherwise you might need to order a new board. Or maybe another light.
    Feb 2012
    awesome, thanks for the info. I'll see what the driver and connections look like.
  1. cree MC E light but need a little help
    By troutie-mtb in forum Lights DIY - Do It Yourself
    Last Post: 04-29-2013, 06:10 AM
  2. Troubleshooting light system build
    By zanq in forum Lights DIY - Do It Yourself
    Last Post: 01-07-2013, 02:10 AM
  3. cree Q5 240 lumen zoomable light! for less then 10$
    By dugan661 in forum Lights and Night Riding
    Last Post: 02-15-2012, 12:30 PM
  4. cree Q5 240 lumen zoomable light! for less then 10$
    By dugan661 in forum Lights DIY - Do It Yourself
    Last Post: 02-15-2012, 12:29 PM
  5. 1st attempt at Cree XP-G LED Light
    By liv2_mountain_bike in forum Lights DIY - Do It Yourself
    Last Post: 01-21-2012, 08:15 AM
