Results 1 to 3 of 3
    Reputation: C.M.S's Avatar
    Which style is prefered ??
    WARNING : Do not ride your bicycle until you have read and thoroughly understood the owners manual.
    Reputation: TiGeo's Avatar
    One of each. You really will want one on your bar and one on your helmet. Both of those will work and will be more spot lights but will work fine. The dual is a good helmet light and the other will work on your bars well if you add a compatible wide-angle lens to spread the light out a bit.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2012 Specialized Stumpy EVO 29 HT
    AKD
    AKD is online now
    Temporarily flatlanded
    Reputation: AKD's Avatar
    May 2012
    Quote Originally Posted by TiGeo View Post
    This. Riding with one light, particularly if bar mounted, makes for some odd optical illusions, particularly on rocky downhills (things look steeper, rocks look bigger). Having two lights mounted at different heights (bar, helmet) helps eliminate this effect.
    Go light on the helmet (100 gram light head) and long run time on the bars.
  1. Prefered spoke wrench for Industry Nine spokes?
    By Shatmepants in forum Wheels and Tires
    Last Post: 12-04-2013, 01:01 PM
  2. Replies: 0
    Last Post: 05-07-2013, 10:03 PM
  3. Plate style dropouts vs. hooded style? (semi troll)
    By febikes in forum Frame Building
    Last Post: 02-08-2013, 05:10 AM
  4. Prefered type of light?
    By jujup in forum Apparel and Protection
    Last Post: 10-26-2012, 02:49 PM
  5. Prefered 29er config for PNF
    By FatTireGoose in forum North & South Carolina
    Last Post: 06-24-2011, 03:26 AM
