Results 1 to 7 of 7
    Strykr SL or Gemini ?
    Baja Design has the Strykr SL back in stock and was planning on getting one back in November before they went on back order . While i was waiting, I researched alternatives. Is there any reason why i should get the Gemini Duo instead?
    SL: Strykr SL System
    DUO: Action-LED-Lights — Gemini DUO 1500 lumen LED light System
    DUO: DUO LED Light System | Gemini Lights
    Reputation: Gharddog03's Avatar
    Sep 2013
    More lumen? Design?
    I own two Duo's and they are killer lights. If you consider Gemini why not look at gloworm?
    There are so many options, you have to limit yourself somehow.
    So i ruled out Gloworm because it's not USA based. But it is a good light.
    Strykr SL = 950 Lumens $200
    Gemini Duo = 1500 Lumens $210
    Gemini Xera = 950 Lumens $180
    Sep 2013
    Duo lighthead, 6030h battery, and gemini charger. $179.05 shipped.
    where's the Duo for $180?
    Sep 2013
    Action led. Click on lighthead only 115.15$. Magicshine 6030h battery 53.95$. Gemini charger 9.95$.
    I own two 6030h and they are awesome.
    Reputation: MRMOLE's Avatar
    Unless you're going to use your light as a dive light, other than a slight increase in price I see no advantage in going with the strykr. The Gemini Duo will give you brighter and wider beam pattern, a much lighter system, a much more programmable system that will run just a long @ higher powered max setting with the optional 4 cell battery(well worth the extra $33 IMO). I own several Gemini lights (Titan, Xera, Duo, Olympia) and they're all excellent. I also agree with Gharddog03 that you should look at the Gloworms. I got an X2V3.1 (Gloworms dual emitter light (similar to the Duo) and I definitely like it better than my Duo. It does all the things the Due does plus it has much nicer bar and helmet mounts and considerably more power (Its not brighter but it has a lot more throw - check out Actions beam pattern graphs for both lights to see how much further ahead you can see, it's a big difference). It also runs abit cooler which is important to me since I live in the desert. Unfortunately it's another $36 more than the Duo ($70 moer than the strykr). I'm not sure if you have to pay shipping on the Strykr but both the Gemini & Gloworm are free shipping from Action. They're all good lights, you have to figure out what's the best deal for you. Hope this helps.
    Mole
  1. bd strykr sl
    By 07civ in forum Lights and Night Riding
    Last Post: 09-01-2013, 08:48 AM
  2. bajadesigns strykr sl
    By Rocker T in forum Lights and Night Riding
    Last Post: 12-03-2012, 12:28 PM
  3. strykr pro change??
    By Romic tech in forum Lights DIY - Do It Yourself
    Last Post: 08-31-2012, 10:10 AM
  4. Replies: 74
    Last Post: 08-28-2012, 05:11 PM
  5. 2011 Baja Designs Strykr/Strykr Pro Trade-Up Program
    By Baja Designs in forum Lights and Night Riding
    Last Post: 04-11-2011, 09:26 AM
