Results 1 to 3 of 3
    Reputation: BigEarn86's Avatar
    Spoke Gernade Battery Mounting Help
    I read through most of the forums that had info on where to mount your battery for your handlebar lights. I have the same problem as some of the other posters. My cables run under my top tube. In addition there is not enough room on the stem, or the down tube, and I like to use my water bottle for water.... So what I didn't see recommended was mounting the battery on top of the top tube... I am thinking directly behing the head tube. Is there any reason why that would not work? I was just curious that I didn't see that recommend or even mentioned? Thanks
    Of course it will work. You can also use an extension cable and mount the battery on the seatpost.
    Thanks. I can mount it on the seat post but I figured the cable length would need constant adjustment everytime I adjust my ride height. I guess I will have to see which one works out.
