Results 1 to 3 of 3
    Bigger is better!
    May 2005
    Small lights with single XM-L + reflector?
    Are there any smaller lights than the MS lights with single XM-L + reflector?
    A L&M Stella with XM-L would be awesome I think...
    What I'd like is a light similar to MS/Tesla, only smaller. Heat dissipation may be a problem though..
    Quote Originally Posted by langen View Post
    This is a good question! It's surprising that there are not more compact set-ups using a single XM-L. Scar builds a duel XM-L that is small so he might be able to build a single without too much problem. I personally use an XM-L drop-in torch ( for helmet use mostly ) that has a small reflector and it does very well...even on medium. Moon lights has a single self-contained bar system as does others no doubt but these are almost the same as torches. It sounds like what you want is some thing like a Lupine Piko only with a single XM-L.
    Bigger is better!
    May 2005
    Piko with single XM-L and reflector, or an XM-L'ified Stella would be good headlights I think.
    It shouldn't be impossible to have a body diameter of 30mm or below I think, especially when the Regina (19mm) performs relatively well with the XM-L. A well designed reflector of 25mm should therefore do the trick.
  1. Better to get a brighter single light or two lower lumen lights?
    By quasi_shawn in forum Lights and Night Riding
    Last Post: 09-15-2010, 07:52 PM
  2. Replies: 18
    Last Post: 04-17-2008, 06:40 PM
  3. Single battery for two lights
    By cdn-dave in forum Lights DIY - Do It Yourself
    Last Post: 03-31-2008, 09:16 PM
  4. Some lights are small, some not
    By fc in forum Lights DIY - Do It Yourself
    Last Post: 01-24-2008, 10:01 PM
  5. DiNotte 200L AA lights (single source helmet) for trail riding
    By ting in forum Apparel and Protection
    Last Post: 10-16-2007, 11:51 PM
