Results 1 to 18 of 18
    am7
    am7 is offline
    Apr 2014
    Which self-contained single 18650 with proper mount bike light?
    Hello,
    I am now confident that there is no decent torch mount in existence having tried them all, whether fenix, nitecore, velcro type, cheap chinese dx type, etc. etc.
    So while the torches are perfect for my use, the mounts either wobble, rattle, are heavy, cumbersome, scratch my bars, break (yes even the fenix one) you name it.
    Fenix have released a new mount (about time) but I see it is more of the same (I can't believe such a simple thing to be so hard to grasp).
    I have now given up on this idea and I am looking for a bike specific light. This is were I need your help.
    The light must:
    - be self-contained with a single 18650 cell, I carry the cells with me, I do not want usb recharging
    - be of a decent die xml2 or similar efficiency I need over 2hrs of real 500+ lumens
    - come with a sturdy mount (no rubber bands!) and keep the light steady as if it was bolted to the bars but offering scratch proof protection with rubber pads.
    - of high quality, no cheap lights please
    So any ideas or am I barking at the wrong tree?
    Reputation: spankone's Avatar
    some thing like this lezyne light would do the job. Lezyne - Engineered Design - Products - LED Lights - Power Drive XL but not many lights let you remove the battery. Also try moon lights
    am7
    am7 is offline
    Apr 2014
    Quote Originally Posted by spankone View Post
    Thank you!
    I believe I have found my light. It is the Super Drive XL not Power Drive XL. Unless I am missing something obvious from where I am standing (sitting) apart from the poor run time () it looks absolutely perfect. I would kill t have that mount for my torches.
    Any other suggestions before I order?
    I looked at the moon lights and while far technically superior to the lezyne, actually the X-Power 780 can match my torches for brightness and times they are far too ugly to consider (sadly I do care about the looks).
    If anyone has a lezyne with the same mount can you tell me if it fits over 31.8mm bars with the rubber lining in place? That is my only worry. Not only to avoid scratches but the rubber provides the necessary grip when tightening so there is no slippage even in the biggest knocks & bumps.
    Lastly my 18650 batteries will fit right?
    Gemini xera as well.
    am7
    am7 is offline
    Apr 2014
    That is a torch of beautiful clean design with the ideal spec but the mount is horrible. I fail to see how they mention rock gardens in the same sentence referring to a mount held by glorified rubber bands and no securing mechanism for the torch, you just push it in and hope it stays put. I am sorry but using an o-ring as opposed to a proper mount is a terrible idea in the first place and a recipe for epilepsy.
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Lezyne uses 18650 yes, they sell 2400mah. you can use a 3400mah 18650 in it
    am7
    am7 is offline
    Apr 2014
    Quote Originally Posted by 127.0.0.1 View Post
    Thanks. Good to know. Apart from a couple of 3100mah all my 18650s are 3400mah, does that mean that my runtime will increased over the 1:30 stated? Lezyne does not state which batteries they use for the runtime test unless the test conforms to some kind of standard?
    jl
    jl is offline
    climb
    Reputation: jl's Avatar
    I decided to use this host with a 2.8a driver and an CREE XML LED. You can then create your own mounting system for fairly cheap. Drill and a screw and use cateye, nite-rider, etc.
    $15.17 Convoy S4 DIY EDC LED Flashlight Host - emitter and driver sold separately at FastTech - Worldwide Free Shipping
    Been a good torch solution for me.
    We don't need more to be thankful for; we just need to be more thankful.
    Quote Originally Posted by am7 View Post
    Yeah you got a longer runtime as long as the battery's are good.
    because GIANT
    Nov 2013
    since the leyzyne runs at a modest lumen level, expect longer runtimes from 3100/3400
    in a general sense comparing a panasonic (NCR) 18650
    in a very bright light running an 18650....(900 lumen for example)
    a 2400 can drive higher amps longer than a 3400, but has less overall juice,
    this means the initial brightness lasts a bit longer in the drain-curve
    a 3400 will drop it's amps sooner than a 2400, but then flatten out, and run
    a bit lower lumen a fair bit longer than a 2400 will
    since the Leyzyne is under 500 lumen, this won't matter as it is not asking so much current for you to see the '3400 drop'
    am7
    am7 is offline
    Apr 2014
    I did my fair share of cateye diy mounts and botching. Now that I'm older I prefer to buy off the self even if you don't get the same bang for buck.
    Very interesting about the 2400 vs. 3400, I would have thought the 3400 would be brighter throughout.
    Btw the lezyne is over 500 lumens
    Review: Lezyne Super Drive XL | Mountain Bike Review
    because GIANT
    Nov 2013
    on candlepowerforums they did battery comparisons and the graphs showed... to get 3400mah squeezed in a cell there is a trade-off on '1st hour amps' ....the 3400's drop off steeper
    so not all lights will benefit from a 3400, [except overall run-time at a 'medium high' level] at max level 2400's work better for the first hour (mostly)
    That's good to know. Thanks.
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    I have the xera and would not recommend it at all. It starts flickering sometimes and jumping between power levels to shortly end up at really really low output, and then just stops working.
    The problem is the rear brass thingy with the switch, it unscrews itself each month and has about 2 threads to hold on to the battery tube threads. flawed design imo.
    I would have gotten cygolite or lumina instead.
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    I have questions concerning this. *Can you give me the CPF thread link that you used as your reference? I can't comment before looking to see "what batteries" were tested.
    (*edit: Never mind, I saw your reference link on the SS thread...after I already found it myself. )
    Continued from my last post:
    I did some quick searching on CPF. ( *There is so much stuff on CPF that it boggles the mind... ) After looking around I've come to the conclusion that most people ( on CPF ) believe the Panasonic cells are the best made. It's been my experience that the good Panasonic cells beat others hands down. Keep in mind that there are many sellers that repackage the Panasonics ( using their own protection circuit ) and sell them under their own label. Some of those also work as good or better than the green label off the shelf Panasonics.
    As I see it their is no way a normal ICR type 2400mah Li-ion battery can beat a normal NCR type Panasonic 3400mAh cell. I have many older 2400mAh cell and none of those were ever able to compare to the Panasonics once I started using them. The Panasonics ( used in single cell torches) gave me *brighter initial output ( *more initial current ) and longer run time.
    That said there are other types of batteries that are designed to provide more current than the typical ICR type cell. Cells of the IMR type can do just that. Capacity on these cells are much lower BUT they can supply higher current levels for longer periods. They will however run out of juice rather quickly if powering a lamp that is drawing heavy amps. I don't own any IMR 18650's but somewhere along the line I will pick up a set of Samsungs IMR's and see if they are worthy of my helmet torch duties. If you know you have a lamp with a 3A driver ( that uses a single cell ) it might be worth the try if you want maximum output. In the meantime I'm very happy with my single cell Panasonics.
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Quote Originally Posted by car bone View Post
    Gemini redesigned the switch/endcap for the Xera Flashlight and it is now reliable. I will agree that the stock mount does not hold the light securely on rough terrain. I recommend a Twofish Flashlight Holder to go with it. Put a wrap of friction tape on your bar and it's very secure.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    ~ B A D A S S ~
    Yeah I kinda did a redesign myself after the third time. The 2 small not completely drilled through holes for the spanner wrench are now completely drilled through and I torqued down on it as hard as I could with a diy tool. Been good since then.
  1. Best Self-contained Tail Light
    By Lugano in forum Lights and Night Riding
    Last Post: 06-23-2014, 12:55 AM
  2. My short search for a self-contained commuter light
    By pigmode in forum Lights and Night Riding
    Last Post: 01-18-2014, 11:33 AM
  3. Self-contained rechargeable front light for roadbike
    By Flyer in forum Lights and Night Riding
    Last Post: 10-09-2013, 08:18 PM
  4. Self contained helmet mount lights for commuting
    By ese002 in forum Lights and Night Riding
    Last Post: 09-20-2013, 08:37 AM
  5. LXP B4 4*XM-L U2, 6*18650, 3500lumens Bike light
    By Cat-man-do in forum Lights and Night Riding
    Last Post: 07-25-2012, 08:32 PM
Members who have read this thread: 13
