Results 1 to 90 of 90
    RAKC
    Reputation: tigris99's Avatar
    Review: Ituo XP4 mountain bike light
    OK as promised, review time again.
    They haven't released the "official" spec sheet yet but since I've tested all that already and this is the production unit. So this will be the official performance specs.
    https://www.ituolights.com/collectio...nt=28147973191
    First impressions:
    It's Ituo, quality right on par as usual. Nice, clean, well finished look. Properly sealed (I inadvertently got a ride in the rain test), good thermal paths with high end thermal compound and all that.
    Same mounts as other XP series lights (new version bar mounts that have been beefed up at the hinge and supposed to be a stronger plastic). My unit is the current 4 cell pack, 6400mah Panasonic cells. 6 cell pack is in the works. But I was informed they are moving up to NCR18650B cells, 3400mah for 6800mah packs.
    This light is a MONSTER! Not talking in weight (but it's 132g, so not terribly light either). I talking in lumens. When I get the video cut (used my new YI 4K on the Rider-m gimbal for chest and Hero 5 on the bars to test it's EIS) I'll get it posted. But towards the end I crank both up to high even though I was off tonight so slower than usually and didn't need it. It overpowers the xp3 very noticeably.
    Throw is intense. It uses what looks to be 4 10deg optics that were combined into one. Mean hot spot (if I turn the cameras down to cut that I loose the clean showing of the spill, cameras don't like a spot that intense only a few feet away). Not sure how anyone could need more light than this. I rode mostly at 60% and I already felt like daytime with a search light on my bars.
    I told ituo to check into a more diffused optic for bar use for those of us that like a more even spread. Transition is smooth and spot is larger than the xp3 on stock optics but not by much.
    Air is drying out so I'll try for good beam shots tomorrow night. High humidity kills the effect of this light for a camera. Too much feedback glare to get a good exposure.
    Specs:
    Weight: 132g
    Output: 3282 lumens at 30 seconds (drops slowly to 3100 range and holds for a bit) using 4 xm-l2 u3 emitters
    Beam: Narrow spot
    Current draw on high: 4.6A
    Runtime on high: (I'll have to update exactly when computer is done rendering video) but roughly 1.5 hrs of of decent output on 4 cell. By "standards" it'd just barely make 2 hours before it shut off completely. 6 cell I have has a lower class protection circuit (not an ituo pack, kd/gearbest Panasonic 6 cell) so 2.25 good output, over 3 before it hits 10% output and shuts off at the same time.
    For the uninitiated, ANSI FL1 is lumens output at 30 seconds-120 seconds and runtime is based on when output decreases to 10% of its ANSI lumen reading.
    I did find that my cooling tunnel on my sphere can barely handle this thing. It produces a lot of heat and takes up a lot of space making the fan have to work harder. So Graphs aren't as steady looking as I'd like. Never stepped down but I could tell it was running pretty close. Need a higher cfm fan for this thing to be able to provide the same air flow around the light as this fan does to normal lights. Or try to fit a bigger tube. I did check with my with my anemometer and I did loose about 1 mph air speed with this beast in there.
    OK here's my pics:
    Ride test: ridden a few times now on it, performance was flawless. Like I said above, it's a beast. Night into day and then some. Mount has no issue holding this thing solid. Just, for me, I want that spot bigger for bar use. Too tight and intense for my preference. Make an insane helmet light though (tried that too way the prototype. Too much when riding a hardtail though for me. Too big.
    Videos and Graphs coming soon, computer for some reason won't use more resources to render a video so it's slow as hell.
    Sent from my SM-T350 using Tapatalk
    RAKC
    As for the UI, I had to get confirmation:
    3 modes simple click for on. Programmable.
    Long press from OFF position goes to flash modes.
    Faster off!!! No blinky when shutting off.
    It will be a fair bit before this trickles to other lights.
    Quick Video Segment:
    Be sure to set quality to full 1080p otherwise you don't get the full effect.
    Full ride video:
    https://youtu.be/-_7lMPgfpsM
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    No mention of what type of LED's being used?
    RAKC
    Didn't think about it because every light they make (and most other brands) use the same emitter. Xm-L2 U3
    Sent from my XT1565 using Tapatalk
    Light freak
    Jun 2005
    Two of them on a helmet looks doable
    To me the fact that you say it is producing a good spot pattern makes the lamp sound promising as a helmet lamp. Now I know that you don't particularly like tight beam patterns but I'd like to know more about the beam pattern of this lamp. How does the beam pattern compare to other stock lamps you have ( Olympia, XP3 ) Is there a way you could provide a couple photos showing the comparisons with the other lamps. I figure the best way to do this is to find a spot that has a definable object at about 200 ft. That way we would/should be able to judge how intense the throw is.
    I do have two main worries; the weight and how easy/hard it is to turn off. If I were to use something with this much power I am going to be using it most of the time on less than half power. I have no idea if I'd be able to run this lamp on my helmet due to weight. I need to find something that has 132gms of weight so I can judge whether or not I can handle the weight on my head. Damn!...wish I had my own scale.
    Any news from ITUO on when this lamp might come to market?
    RAKC
    Cat
    I'll do a comparison of them hopefully tonight when I do beam shots. You can see it big time in the video I'll be posting though. Camera isn't very fond of it when it's on high mode cause of the spot.
    I'll get into the UI when I update above again. This will be the first release of the new UI that's a lot simpler (and quick to turn off)
    As for release date, end of month early next month. Not for sure just yet.
    Just Ride !
    Reputation: C.M.S's Avatar
    Looks like Ituo has seriously come to play in a big way with there line up of lights and here to stay .
    Great review as always .
    Hit the trails with your bike and get freaky.
    RAKC
    Deleted
    Reputation: garrybunk's Avatar
    Feb 2014
    Wow! What a monster! And yeah, that beam looks like it has a very intense spot.
    -Garry
    "My Bike Lights" Thread on BLF teardowns, measurements, and beamshots. Moving my photos, PM or post up if you can't see them.
    Nice video tig but I couldn't tell which of the two beam patterns was for the XP4. Was the XP4 on the helmet or on the bars? I saw two lamps on the bars so I have to ask. I couldn't really tell from the video what kind of beam pattern the XP4 has because you were running two lamps. What I could tell from the video was that both lamps had a hot spot and that there was a ton of light coming from the two lamps you were using.
    RAKC
    Cat,
    Had to edit cause I completely misread your post lol.
    Xp4 on bars and xp3 on the helmet. Video removed sorry
    Reputation: OverTheHill's Avatar
    Dec 2004
    I'm a little confused now with respect to the video. It would be nice if you could annotate it to indicate what we are actually seeing with each section of the video. i.e. What lights you have on, level for each light and position.
    For instance, after the first section where the critter crosses your path, it seems like the colour rendition of the light changes a bit. Obviously the light position has changed on to the bars but is that because it is a different camera causing that?
    EDIT: Reading your comments above maybe it's not so obvious that the light position has changed but the camera. Is the XP4 always on the bars and do you have an XP3 helmet light on as well? If so I don't think it's an accurate representation of what the XP4 is capable of on its own.
    RAKC
    The video is segments of one continuos ride. Literally nothing changed from start to finish. 2 cameras, 2 lights, one ride start to finish.
    But seeing as the effort has gotten poor response video has been removed. And since I won't ride with it on my helmet because it's too much for my neck, I won't be putting up a new one. I'll just post a short clip and make sure its on there that it's on the bars.
    RAKC
    OK heres the new video, very simple short little video.
    Feb 2014
    I agree that it's tough to tell what's going on in the video with the lights, especially when there are two. Switching modes / lights on & off with some text overlaid on the video saying "XP4 alone High 100%", "XP4 @ 60% & XP3 @60%". The beginning of the video could then explain that it's always XP4 on the bars and XP3 on the helmet. I definitely think we need to see the reviewed light by itself at times, even if it's standing still and just changing modes. Otherwise it's a good video and I'm jealous of what looks like a great place to ride.
    -Garry
    RAKC
    Well I said I would be doing beam shot type work when I get a chance. That was the ride video... When I'm on the trails on my bike I'm there to ride, can't afford to waste time with trying to get 20 different beam shots and little riding bits with a single light on etc. That's the purpose of the rest of the review, to gradually cover all that. At least for me, trail riding time is valuable
    Feb 2014
    But you're NOT there to enjoy riding, you're there to get material for a review! How dare you put your ride above the data for the review!
    -Garry
    RAKC
    Lol.
    Well since the bar camera was confusing people and such, I just spent the last 1.5hrs fixing the video for you guys.....picky a$$ ppl
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Pre-ordered. Looking forward to trying it out.
    I got some bad ideas in my head.
    RAKC
    It's a lumen monster that's for sure.
    Update:
    I mentioned to Ituo that a more diffused optic would be nice to have since some of us hate tight beam patterns on the bars. Their checking to see if the manufacturer of the xp4 optic has a wider pattern version.
    Feb 2014
    Is that XP4 optic different sized from the "standard" LEDDNA sized ones? What about the XP2 & XP3 optics?
    -Garry
    Dec 2004
    Quote Originally Posted by garrybunk View Post
    -Garry
    It looks to me like it's all one quad optic rather than 4 separate ones Garry, if that's what you are asking.
    Feb 2014
    Oh that's right. I forgot this one wasn't individual optics.
    -Garry
    blair witch ride ...
    RAKC
    Ya it's a single quad optic
    Reputation: MRMOLE's Avatar
    Quote Originally Posted by tigris99 View Post
    Update:
    Please keep us updated on this. Light-head size limits this to bar use for a lot of us and a wider beam option would be more useful.
    Mole
    Have Ituo look at the Wilma quad optic for the XM-L2's i believe its 26 degrees. That would be a great option for the XP-4.
    RAKC
    Oh ya, their taking Pre-Orders now for the xp4.
    I know their looking into all available options so it's sorted by the time their in stock.
    Mole, I agree, big problem is so many here talk about wanting laser beam level beam patterns. So they went off majority of postings I'm guessing.
    RAKC
    sorry guys, havent gotten to the beam comparisons and all that yet. Busy weekend with youngest birthday and all. Hopefulyl get to that tomorrow night
    RAKC
    Here's pic from riding with the xp3/xp4 combo last night. Get to see my ugly mug 😎
    RAKC
    OK guys, finally got off my butt and got a comparison video made of beams.
    Also realized that neither Gemini, glowworm, or my bt40 will fit 35mm bars... That made for a giant headache and really cold fingers before it was said and done.
    I'll try to get the video posted before the night is out.
    RAKC
    Here you guys go. Didn't come out as good as I had hoped.
    https://youtu.be/DNLLHcJhQ1U
    Oct 2016
    Whats this light suppose to cost? dont see it listed anywhere yet.
    Dec 2004
    From those beam shots tigriss I would say the XP3 was the most impressive. The XP4 seemed to have too much hotspot in the middle which made the spill area look dim by comparison.
    You mention in the commentary that the XP4 had smoother spill so what do your eyes tell you that the camera doesn't? The other advantage with the XP3 is that the optics are user configurable whereas the XP4 is fixed.
    What would be your preference between the XP3 and XP4?
    RAKC
    I don't need something as big as the xp4. And the optics hopefully won't be fixed, waiting for updates on a wider beam.
    The big problem for the camera is that the hot spot messes with the rest of the shot. And since the xp4 is much more powerful, it was drowning out the spill more. And remember that is pointed at the ground 5-8ft in front of the bike.
    Xp4 isn't something to run at full power for most of us. But from an efficiency standpoint it will get a fair bit longer run time producing the same output at the xp3.
    Or if your one of the guys that has trails where you can make use of the lumens, the throw and spill would do awesome. Out on open ground it makes sense but in tight and twisty its better suited to run lower outputs and enjoy the extra run time.
    I'm going to try and locate something that works better (flat ground) and use regular still photos and see if I can capture what I'm seeing better. Basically beam shots on flat ground. Not easy to find where I won't piss ppl off around here lol.
    As for the cost thing, sorry this thread was started long before light was available for preorder as I was testing it to make sure all was good before its release.
    Price is $229.99 preorder, normal price is $269.99
    Anytime. Anywhere.
    Shipping soon, yay.
    Anytime. Anywhere.
    Shipped Yesterday!
    RAKC
    Did it arrive yet, curious to hear thoughts/opinions.
    Anytime. Anywhere.
    Not yet, I live in BC.
    Quote Originally Posted by Travis Bickle View Post
    Travis, what's your intended use? Bars or helmet?
    Anytime. Anywhere.
    I'm not sure yet, I will try both.
    Anytime. Anywhere.
    Supposed to be here Friday
    Jun 2005
    Mine came in last week, but since it's been raining in SF Bay Area, haven't bothered opening it. First, I was scared because the box was messed up, but seemed to work.
    Took some physical size comparisons. NightFighter BT70, SSX2, Ituo XP3..
    Review: Ituo XP4 mountain bike light-fdgvlxtmau-z9ia1mskidnlrt1tzxwkam8e9oumoza8px92ib.jpgReview: Ituo XP4 mountain bike light-yts0e4pw2hkjnzbmu7upezwsr1_osnmjy-w-hir4opcpx92ib.jpgReview: Ituo XP4 mountain bike light-itqndejdlrv6xobgokpknrreophiqgx9kopnrf8fs0kpx92ib.jpgReview: Ituo XP4 mountain bike light-4bsat4qig1irkhugtgj9ehz0_hccpkrqzkamf9enhr8px92ib.jpg
    RAKC
    Their mtb lights, they should handle more than some rough shipping without issues
    Seems I'm not the only one that still has a functioning bt70. Though it just sits on display, has for over a year.
    Just wait till you can turn the xp4 on, it will well overpower anything you've got!
    May 2005
    Quote Originally Posted by bluesaint View Post
    Does it look like the heatsink GoPro adapter from the XP3 will work on the XP4?
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    RAKC
    Vanc
    The mounting interface is identical across all 3 xp lights so it will fit no problem.
    May 2005
    Vanc
    Thanks! Could not tell from the pics is the XP4 is flat on the bottom or if it has a recess on the bottom similar to how the area around the switch is.
    I always feel a bit more comfortable about fit once someone has actually put them together. Especially after the BT21 adapter needed to be tweaked 3 times to get dimensions that worked with all "versions" of the BT21.
    RAKC
    The bottom of the xp4 is literally identical to the rest so no issues with the mount. Thankfully Ituo is actually quality lights so should be 0 issues ever with that.
    Jun 2005
    Quote Originally Posted by Vancbiker View Post
    Review: Ituo XP4 mountain bike light-7jijtbxcysjwlmtauj9pqukcozyc_icvjvd93woxtkgpx92ib.jpgReview: Ituo XP4 mountain bike light-kn84e2mt6edsmptv6rasilq3sba-mjxrlphzl6_mc2spx92ib.jpgReview: Ituo XP4 mountain bike light-taw8dbmzesghe0quryxdskzvraexrhlfty7m9pfdkcmpx92ib.jpg
    Here you go
    May 2005
    Excellent! Thanks. Looks like it will work in both orientations, low profile or extra low as you have shown too.
    Oct 2012
    Any updates on if they are going to make a wider lens for this light?
    I assume this won't make a good BT40S wide beam alternative unless they make a more flood lens for it?
    My plan was to use the XP3 for spot and the XP4 for wide.
    RAKC
    Nothing yet, I'll find out if an option was located. Truly I've ridden with that combo (how I did the videos) and the spot on the xp4, is fairly wider. Just the extra almost 1000 lumens overpowers the xp3 in a straight line.
    Its actually fairly similar to the bt40s for beam, just the spot is slightly tighter and way more intense (twice the lumens).
    I'll post an update when I get one. But I know if they do get a wider optic it won't be included with the light, will be a separate part to buy.
    RAKC
    Holiday gift for those interested, nice discount and 2-3 day shipping so you get it before the Holiday weekend.
    https://www.ituolights.com/collectio...00-lumen-light
    Oct 2016
    Hello all. General inquiry... I have a wiz20 on order but am wondering a few things about the xp3&4. Firstly most of my night rides will be in winter sometimes down to -30c will these things handle that kind of cold and would it be worth having both xp3&4? Thanks a ton guys
    RAKC
    The lights will handle it fine but you would need to keep them packs warm it loose a lot of run time. Also make sure you wait till they have warmed up in your house before you recharge the batteries.
    It's always worth it to have 2 lights, what 2 you need is up to you. Xp3 and 4 are great lights so no reason not to.
    RAKC
    So now that there is proper extension cables I decided to play with this on the helmet more. Though I could run this off a 2 cell, can't exactly run all out. Now I see why Vanc and such like putting a full pack down in a jacket pocket. Truly the wires are not a problem at all and though this light is a bit bigger, not having my 2 cell on my helmet makes the whole deal a lot lighter weight on my neck. Think I'm going to stick with using extensions and putting the pack in a pocket or something. Much less cumbersome on my neck regardless of the light I use.
    Have to say it's rather fun as a helmet light. Next time I go out I'll remember to bring my GoPro. The snow (till it melted over the last few days) made it interesting too. Everything is so much "brighter" when the snow is on the ground. Don't even have a need for a bar light with this thing on helmet.
    Was on the US Ituo website this morning and noticed they have a sale on the XP4/XP3 full kits. $200/180 is the lowest price I remember seeing on these lights and is only going to last for a few days. Never hurts to save a few extra bucks!
    Mole
    Last i heard they were out of stock??? Am i mistaken? It really is remarkable Ituo can sell a set up with those specs and have the quality for that price. Thanks for the heads up.
    RAKC
    New year's deal is all, till Tuesday, only US location. Last sale pricing deal we can do. I'm just trying to help ppl that the price tag is a bit much for.
    Always helps when your trying to convince the spouse to be able to show them its on sale and that your trying to be responsible about your bike purchases. Congrats. to those able to take advantage of this deal.
    Mole
    RAKC
    Oops just realized that's supposed to be "till Thursday" not Tuesday lol.
    I know that pain. Though it's really hard to offer that with shipping and all, I'm still me. Try to help get people into better lights.
    Oct 2012
    I don't get how the XP4 without batteries is actually more money. Why is that not on sale?
    RAKC
    Never paid attention to the light head (corrected price now) because your literally the first person to mention any interest in the light head only option.
    Oct 2016
    Hi all
    Went for a ride tonight with the xp4 and noticed that 2 of the 4 emitters were not working. Hoping you guys can help with a solution that is not sending it back to the factory
    RAKC
    Zac, odd but no worries. That's why there's warranties. LEDs can fail and in a set up like the XP4 it takes 2 out if one fails. Got you covered.
  67. #67
    Oct 2016
    Awesome thanks tig. Other than this little blip I have been impressed with the light. It is too bright on high in the snow so that can only be a good thing. Also customer service has been excellent up to this point. Keep it up
  68. #68
    Anytime. Anywhere.
    I have had mine out for a few rides now and my confidence has come back at night. I have the XP4 mounted on the bar and a new BL70 on my helmet. I will probably pick up a longer cable so I can mount it on my helmet and put the battery in my pocket. Wider optics when they are available, maybe. Very impressed.
  69. #69
    RAKC Industries
    Jan 2017
    BL70???
    Life on a bike doesn't begin till the sun goes down.
    US partner for Ravemen:
    www.rakclighting.com
  70. #70
    Feb 2016
    get some beamshots up Bickle!
  71. #71
    RAKC Industries
    Jan 2017
    Oh wait BL70 is the xhp50 thing isn't it?
  72. #72
    Anytime. Anywhere.
    Quote Originally Posted by Dirt Road View Post
    They didn't turn out very well.
  73. #73
    Idea!
    Quote Originally Posted by RAKC Ind View Post
    No, XHP70, if it is from KD.
    http://www.kaidomain.com/p/S026105.K...ke-Light-Black
    I really like mine!
    Peace!
  74. #74
    Anytime. Anywhere.
    Oops.
  75. #75
    RAKC Industries
    Jan 2017
    Ya that's what I meant the xhp70 light.
  76. #76
    RAKC Industries
    Jan 2017
    Figured I'd share this. Got a snow storm that just started, getting several inches over the next several hours.
    Meant fat bike can play on trails again. Decided to see how the XP4 would mount on the minoura mount. Then battery pack will go in the frame bag:
    Going to be way overkill in the snow except I'm going to run it down in the lower modes so I get a nice, low current draw in the cold for the nice long run time.
    Still working on how I'm going to get my GoPro mount on my new helmet because theirs a mesh screen for bugs built into the front vents.
  77. #77
    Dec 2009
    Can please share what model of Mount you are using? I can not see any gopro compatible mount on their website.
    Is it maybe the CS-500 with an add on?
    Gesendet von meinem LG-H850 mit Tapatalk
  78. #78
    RAKC Industries
    Jan 2017
    This is not a Ravemen light. This is an Ituo light, the thread is about the Ituo XP4 and that's what's pictured on my fat bike. An Ituo XP4.
  79. #79
    RAKC Industries
    Jan 2017
    Had to resurrect this because had a big mtb 20th anniversary party for the club Im with.
    Decided to run my XP4 on the lid solo for one of the night group rides. 2 cell pack on my helmet and all. After the first stop (about 10 minutes in just for a quick regroup after clearing the advanced loops) i never turned my bar light back on. Forgot about it.
    Had low at 30% and medium at 60. Never used high but after the beginners broke off to head to their campsite (I was secondary safety sweep and primary had to break off for a rider that got lost) i put it on medium and took off as fast as my legs would go. Had to get back to where we came in and exit trails by 10. 8 minutes to clear something like 3 miles (trails except the last 1/4 mile or so of pavement) back to camp. Didnt make it but was my second fastest time though that section. Difference was about 30 seconds. 4 minutes late clearing the trails then i just chilled on the pavement.
    I like my xp3 on the lid better only because the COG of the light is lower but no complaints. Works as a helmet light on a 2 cell in lower modes for about an hour.
    Xp3 the night before was my only light (last minute decision to go ahead with group night ride) on a 2 cell. Same ride but slighty shorter (didnt take one advanced loop as people werent comfortable doing it at night).
    Sucks I only get to ride those trails one weekend a year after dark.
    Sent from my SM-G950U using Tapatalk
  80. #80
    RAKC Industries
    Jan 2017
    Pic from ride at Sugar Bottom in Solon, Iowa (just north east of Iowa City) road a lap after breakfast since it was my first time out there.
    Video (link to facebook page, not post 30 second video to youtube lol) is a quick clip from my night ride. Forgot to charge the gimbal so the gopro stabilization was having problems since the trails weren't very smooth. Video from morning ride was much smoother (still no gimbal, but not chasing bike lights)
    https://m.facebook.com/ItuoUSAbyrakc...36769653166983
    PS: the xp4 is on sale for $40 off right now, $209.95. https://www.ituolights.com/collectio...00-lumen-light
  81. #81
    Anytime. Anywhere.
    Thanks, just ordered a 2nd XP4, gonna look like a train coming down the trail
  82. #82
    Anytime. Anywhere.
    F it, I'm going with one XP4 on the bars, and one on the helmet. The last couple of years I've noticed that I struggle at night, unless I have a lot of lumens. I think that at 59 and still riding quite well on the downs that 6000lm will be fun.
  83. #83
    Feb 2016
    WTG Travis. Fk the bs! Lol. Lumens is my friend at my burnt age. Xp3/xs is my weapon of choice!. 5k lumens of NW goodness...
  84. #84
    RAKC Industries
    Jan 2017
    Lots of lumens are fun on open ground decents, going fast. "Look Ma, no brakes!" Lol.
    Actually if you look at the link above, exactly what did on my last ride, was over 20mph through a lot of it.
  85. #85
    Anytime. Anywhere.
    I can't believe there isn't more stoke about this light, I love it.
  86. #86
    I think for most the horizontal inline configuration of the XP2/3 is a better fit. No denying the XP4 is a fantastic light and the fact that it fits your needs and your sooo happy with it is awesome!
    Mole
  87. #87
    Jun 2005
    I'm quite unhappy with mine. The throw or perceived lumen is worse than my xp3 and the xp4 glitches out every other use where the on button just starts blinking nonstop and light becomes non responsive.
  88. #88
    RAKC Industries
    Jan 2017
    Did you get a light head or kit?
    The remote if its not seated all the way (twist a little while pushing in) it will do that.
    Let me know we can get you sorted as thats not "normal".
    As for the lumens, its because the beam its more spread out so spot intensity is not as high because of the close in spill.
  89. #89
    Jun 2005
    you can refer to my post in this very thread, but I gotten the head unit when it first came out: Review: Ituo XP4 mountain bike light- Mtbr.com
    I'm not even using the remote, just the power. When it glitches out, I have to unplug the power connector and reconnect it.
  90. #90
    RAKC Industries
    Jan 2017
    Its under warranty, a simple email would get it taken care of. A bad connection at the pack can cause issues, which we cant control how other packs handle the light but I can sort out the glitch and its covered by warranty if its indeed the light itself.
  1. Replies: 69
    Last Post: 11-08-2017, 12:24 PM
  2. Ituo XP2 1500 lm bike light user review
    By Skyraider59 in forum Lights and Night Riding
    Last Post: 10-23-2016, 07:56 AM
  3. ITUO WIZ XP3 Triple XM- L2 U3 bike light
    Last Post: 09-01-2016, 07:49 AM
  4. User Review 2: ITUO Wiz20 bike light
    Last Post: 07-30-2016, 11:31 PM
  5. User 2 REVIEW - ITUO WIZ20 twin xm-l2 u3 1500 lumens wireless bike light
    Last Post: 12-13-2015, 10:41 AM
