Page 12 of 16 FirstFirst ... 2 8 9 10 11 12 13 14 15 16 LastLast
Results 276 to 300 of 397
  1. #276
    Reputation: bobale's Avatar
    Sep 2012
    Thanks. I've made UI to my liking, but it can be made to suit anyones liking. About 3XML: hopefully, it can. But, as I'm not planning on buying triple any time soon, someone else will have to check that.
  2. #277
    Reputation: spartacus001's Avatar
    Wow.
    80K+ views and counting. I'm flattered with the ongoing discussion since my original post a year ago.
    Time for an update:
    After a year of moderate use the battery capacity is only functioning at 20%.
    I always carry 3 light sources but 2 of them failed because of battery issues.
    On my commute home last night the Ebay light cut out at around 35mins (high) after an overnight charge. I had to finish the ride with only a small blinker and 10km was in pitch dark.
    The original charger died after 6 months and had to be replaced.
    So now I plan on building a custom 2S2P battery pack with a set of high quality 3100mAH 18650s
    In the end it costed me $60+ for a year of lighting. *meh*
    Nothing lasts forever but I was expecting a little more longevity then a year.
    In hind sight, if I had to do it all over again I would spend a little more money for a quality light. So if you have this light or you're considering it, don't set your expectations too high. You get what you pay for.
    I'll keep you guys posted on my build.
  3. #278
    Nov 2012
    I think you should get a LiPo battery from hobbyking, as bobale suggested. You loose headache, and you can get a 2S1P 8000mAh for a price of 2 18650 panasonics. You just need a hobby charger(perhaps also from hbkg) to charge it properly.
    Quote Originally Posted by spartacus001 View Post
    Wow.
    Time for an update:
  4. #279
    Reputation: patski's Avatar
    Dec 2005
    LiPo battery
    My 14yo son has a lot of RC planes/cars they use LiPo so he has several including the chargers.
    What size do I need? I guess I'd have to bribe him to solder on different connectors, etc...
    Quote Originally Posted by MK96 View Post
  5. #280
    Sep 2012
    You'll need 2S battery, whichever capacity will get you job done.
  6. #281
    Hey Patski,
    Thank you for the generous offer.
    I've already order parts so I can use after market 18650 batteries with an external charger.
    My build thread is on the way at:
    Needing Expert Advice with a 4-cell 2P2S build
    Quote Originally Posted by patski View Post
  7. #282
    Dec 2005
    OK, lifebike2011 finally "found" my returned light, a new one is on it's way...
    Only took 2 months, now let's see how long it takes to get here....
    patski
    My lighthead died the FIRST time I used it, I got it from lifebike2011
    The button on the back still glows but nothing... tried several batteries...
    It's been more than 14days, "top rated seller," we'll see if they will help...
    CREE XML XM-L T6 1800LM LED Bicycle bike Head Light Lamp/Bicycle Light SET | eBay
  8. #283
    May 2005
    Since the RC hobby type LiPo battery does not have a protection circuit, it will be possible to overdischarge and cause damage to the battery. As long as you are careful to not drain below 6V for this type of light you will be OK.
    It would also be a good idea to install a fuse or PTC fuse in the circuit at the battery to prevent burning up the wiring in the event of a short circuit.
  9. #284
    Reputation: Reelchef67's Avatar
    You'll need one of these
    Tenergy 32005 PCB for 7.2V / 7.4V Li-PO and Li-ion 18650 / 18500 7.2V Battery Packs
    this will protect your battery
  10. #285
    Thanks for that link.
    If I wire in a PCB can I still use protected cells in the holder without any ill-effects?
    Here is my make-shift replacement pack for now:
    My project link is here:
  11. #286
    Thanks for the review, think i'll get one
  12. #287
    Surfin' da mountain
    Reputation: Cucucachu's Avatar
    Aug 2003
    I've read a lot about battery pack issues.
    - Does anyone know if a good replacement battery from Magicshine is compatible?
    - Has anyone had a Battery+ store replace the cells in the battery pack?
  13. #288
    Nov 2012
    I think most of us done the replacement on our own. The compatibility depends on the connector you have as the lights come with different connectors
    Quote Originally Posted by Cucucachu View Post
  14. #289
    Surfin' da mountain
    Aug 2003
    Cool thanks. I just ordered a China Cheapo (Magicshine knock-off) through Amazon. I have a Light & Motion Arc (HID) and the battery for that is now down to 30 mins. run time. The HID is freakin' amazing, but I can buy 5 magic shine knock-offs for price of a replacement L&M L/ion Battery.
    I may still splurge for the L&M Battery to use the ARC another few years, but find it hard to buy another proprietary battery.
  15. #290
    I'm right there with you.
    My Niterider Moab battery is down to about 1.5 hours....and now the switch ( or maybe the board inside) is funked up ( it toggles between the HID and leds....no brightness levels or off)....but it still works
    The price of these clones , I can get a couple of lights cheaper than a battery or switch repair.
  16. #291
    Dec 2005
    Yay, my replacement light from lifebike2011 arrived yesterday, exactly 3mos from the date I mailed it to them....
    patski
  17. #292
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    i've just purchased this system from amazon for $20!
    can anybody tell me how well the helmet strap works?
  18. #293
    Sep 2012
    $20? Damn, that's cheap! Please, share link here.
  19. #294
  20. #295
    Feb 2012
    Fulfilled by Amazon: 27.40 with free shipping
    From the cheapest seller: 20.91 + 6.48 shipping, which by my math is 27.39
    Whoever set the price was no dummy.
    2011 Specialized Hard Rock Sport Disc 29
    Nukeproof Proton pedals
    Ergon GP2 Grips
  21. #296
    Dec 2005
    I cut straps off, trimmed the plastic down to a minimum for weight savings and used a ziptie.
    Review of Ebay: 1800 Lumen CREE XML T6 LED Bicycle HeadLight Lamp-016.jpg
    Quote Originally Posted by shekky View Post
    i've just purchased this system from amazon for $20! can anybody tell me how well the helmet strap works?
  22. #297
    Oct 2011
    i think that's the route i'm going to take.
    it's what i was thinking of.
  23. #298
    Oct 2011
    so my package arrived in the mail today from this shipper, who is located in chino hills, ca. it took the weekend for the item to process and ship to san francisco.
    there's no instruction manual with this thing to speak of. does anybody have an idea of the charge time from a near-complete discharge?
    i've also found a way to rig the lamp assembly to my old niterider helmet mount. note that i have a small piece of velcro attached to the helmet and the mount. i've yet to field test this set up though but i will post a report ASAP.
    Attached Thumbnails Attached Thumbnails Review of Ebay: 1800 Lumen CREE XML T6 LED Bicycle HeadLight Lamp-dscn1725.jpg
    Review of Ebay: 1800 Lumen CREE XML T6 LED Bicycle HeadLight Lamp-dscn1726.jpg
    Review of Ebay: 1800 Lumen CREE XML T6 LED Bicycle HeadLight Lamp-dscn1727.jpg
  24. #299
    Nice adapting with the Velcro patch.
    I think a full charge took me ~10 hrs.
    Make sure you never leave the charging unattended.
    Exploding Battery pack - CREE XM-LT6 LED Bicycle Light
  25. #300
    Oct 2011
    mother of dog...
    explosions! really?
    looks like i'll be charging this thing in an old metal cake pan, then...
  1. CREE XM-L 1600 & 3800 lumen flashlights on eBay
    By ussprinceton2004 in forum Lights and Night Riding
    Last Post: 01-25-2013, 03:42 AM
  2. Serfas TSL-500 True 500 Lumen Headlight
    By skyflying1 in forum Lights and Night Riding
    Last Post: 11-06-2011, 05:42 AM
  3. 1800 lumen Regina batteries inc
    By troutie-mtb in forum Lights DIY - Do It Yourself
    Last Post: 12-19-2010, 06:02 PM
  4. DIY headlight on the cheap with an MR16 LED lamp
    By Mtn-Rider in forum Lights DIY - Do It Yourself
    Last Post: 10-01-2010, 08:28 PM
  5. 1800 lumen Cateye tripleshot
    Last Post: 05-15-2010, 02:03 PM
