Results 1 to 3 of 3
    r29
    r29 is offline
    Poc Trabec + Exposure helmet mount
    Does anyone have the poc trabec and use exposure helmet mount? do you have trouble with it or does it work like any other helmet that has holes.
    Reputation: Danimal1's Avatar
    Custom Exposure mount
    There are 2 issues you will run across when trying to use an Exposure light mount on a POC Trabec helmet. Luckily they are both very easy to solve.
    1) The lower mounting washer on the Exposure light is too small and gets pulled thru (or into) the EPS foam of the helmet. If you are going to make a larger washer to fit there are 2 requirements. 1) That the plastic bolt remain recessed so that it does not make contact with your scalp. and 2 that the washer that you use is flexible enough to confirm to the inside shape of the helmet.
    Solution: Go to TAP plastics and have them cut you a washer out of thin polycarbonate. I can tell you from experience trying to fabricate something out of plastic without proper tools is gonna be a headache. It was worth the $6.00 they charged me.
    2) Because the top middle vent is slightly recessed, it is difficult to aim the light forward enough for steep fast downhills where you have your seat down and are looking up and forward.
    Solution: Went to hardware store and bought a sprinkler gasket and trimmed it with a x-acto knife to fit between the top washer and the helmet. The light now has full range of motion and the paint on the helmet is protected by the rubber washer.
    Attached Thumbnails Attached Thumbnails Poc Trabec + Exposure helmet mount-img_2042.jpg
    r29
    r29 is offline
    Quote Originally Posted by Danimal1 View Post
    awesome thank you for your reply and pictures. Im on the fence on whether I want to get the POC or the Smith Forefront
  1. POC Trabec Race Helmet
    By 1Flashback in forum Apparel and Protection
    Last Post: 08-17-2015, 01:18 PM
  2. SECA Light on POC Trabec Helmet
    By SmooveP in forum Lights and Night Riding
    Last Post: 02-13-2014, 05:44 AM
  3. Poc Trabec Race or Trabec Race MIPS or Troy LEE a1 helmet
    By rave81 in forum Apparel and Protection
    Last Post: 07-12-2013, 10:50 AM
  4. PAC Trabec helmet $65 until 10:50 AM
    By KevinGT in forum Where are the Best Deals?
    Last Post: 02-01-2013, 08:35 AM
  5. POC Trabec Helmet
    By dworley505 in forum Where are the Best Deals?
    Last Post: 01-07-2013, 08:44 AM
