    Jun 2010
    Niterider 1800 Indicator Light Question?
    I just purchased a NiteRider Pro 1800 last night. I tested the light when I got home, seemed to work well. The battery indicator was flashing red.
    I fully charge the battery today. When I connected the light and turned it on, the light immediately was showing the right indicator flashing green. I was expecting to at least see the indicator lights showing full charge for at least a few minutes. Is this normal or do I have a bad battery and need to do a return?
    Thanks in advance.
    Reputation: mtbRevolution's Avatar
    Quote Originally Posted by vamaro View Post
    Thanks in advance.
    You will get a quicker and precise answer from the people you bought it from. Why don't you give them a call?
    Have you done a runtime test to see if it works properly despite the flashing green indicator? You'd expect this mentioned in the manual that comes with the light set.
    Leonard - All things Xeccon + Beyond
    mtbRevolution.com
    Goats Rule!
    It's normal. The 1800 I had last year did it. The two 3600's I've had also do it. NR says to do a complete discharge and charge cycle to calibrate the meter but it's never made a difference with my lights.
    I just accept the flashing fourth LED even though fully charged, don't worry about it and ride.
    Thanks in advance.
    Jun 2010
    Tried to give it a go. I was down to 3 lights in less than 5 minutes using the medium and low settings. Just returned it and ordered the 2200. I think the 1800 would have been plenty of light but for a little more money picked up the 2200 just for the wider beam.
  1. Does anyone have the Niterider Pro 1800?
    By Muffinhead in forum Lights and Night Riding
    Last Post: 05-05-2015, 10:54 AM
  2. NiteRider Pro 1800 light pictures.
    By Jack Archer in forum Lights and Night Riding
    Last Post: 01-02-2013, 06:14 PM
  3. Niterider Pro 1800?
    By VFRLuke in forum Lights and Night Riding
    Last Post: 12-11-2012, 03:52 PM
  4. New Niterider Pro 1800 Race LED - Anyone?
    By nando87 in forum Lights and Night Riding
    Last Post: 12-08-2012, 06:05 AM
  5. Niterider pro 1800 race
    By DCTILLER in forum Lights and Night Riding
    Last Post: 11-30-2012, 10:49 PM
