Results 1 to 28 of 28
    New D/X SST-50 torches
    I just happened to notice these when checking the D/X web site. Five new torches using the Luminous SST-50 emitter. D/X is listing these as using a 2500ma driver and outputting 1000 lumens . According to the spec. sheets that doesn't jive as the spec. sheets seem to indicate a current of 3.4A would be needed to get 1000lm. Still, 2500ma might be able to get you ~ 700-800lm if you can believe the claim to 2500ma on the D/X driver.
    A couple months ago I bought a drop-in SST-50 for one of my torches. On a fresh battery the output looks close to 600lm but with a medium width beam pattern. Of course if my memory serves me the driver on the drop-in was not anywhere near 2500ma. Still this torch drop-in rocks and I can't wait to try it out on some trails when all of this snow goes away. It's quite possible that with the bigger reflectors of the standard size torches the SST-50 will have more throw and maybe even beat out my MC-E Aurora torch. The drop-in I'm using doesn't beat my MC-E powered Aurora for throw but like I said, it has a wider beam. Someone needs to buy one of these for a review. This just might be a very hot item if what I'm thinking is true. I still can't see it running for the claimed 1.5hr @ 2500ma that D/X claims. Link > http://www.dealextreme.com/products.dx/category.999
    ....Right now I'm sitting on two feet of snow. Another foot expected in the next 24hrs.
    I sure could use a set of nice snow shoes right now....*Sigh*...
    Jan 2009
    Stop it!
    My SSt-50 in the B R body was crap so i think i'll steer clear in future.
    Cree or SSC must be working on a R5 or S2 based Multi core LED or a large type like the ssc. Come on!
    Quote Originally Posted by moggy82
    Stop it!
    Hey, what can I say. Mine looks good. I've been wanting to do beam shots for months but the weather is not cooperating. Mine looks to put out about the same amount of light as my Aurora with MC-E only the Aurora has a more tightly defined hot spot so has a tad more throw. So....the questions remains....How bright and how tight are these new set-ups with their larger reflectors AND are they anywhere near 1000lm? Don't ask me, I already spent too much during Christmas. Someone else needs to buy one of these and compare it to a P-7 or MCE. Personally, I'm still waiting for D/X to come out with a triple XP-G set-up. Right now the only torch available in a triple XP-G is a custom job over on CPF and those are limited in production and very expensive. (edit: not to mention I'm still wondering where all the D-bin P-7's went. )
    Why don't go with this SST-50 light:
    4000mA current
    Quote Originally Posted by Whitedog1
    4000mA current
    Interesting....It also seems to have one positive review. I find it hard to believe though that this torch has a driver capable of outputting 4000ma. However if true this could make a fine torch to mod to use as a *bar lamp ( * the review stated that it was more of a flood lamp ). Simply cut off the light head, move the switch to the back of the light head and run an external 7.4 volt Li-ion set-up to power it. If I already didn't have a bar light capable of outputting 1000lm I would seriously consider buying one of these to mod.
    On a side note: If D/X can get a torch like this made with a 4000ma driver, we may soon see an upgraded version of the MagicShine! Matter of fact, I triple Dog dare them to come up with a 1100Lm , SST-50 version of the MagicShine!
    Quote Originally Posted by Cat-man-do
    love that idea!!
    4000mA current
    ordered this torch last week - we will see....
    I really, really hope this is as good as the ad says it is. Do you have something to compare it to?...P-7..or MC-E torch/light?? I can't wait to read the review!
    I can compare it to my modded Romisen RC-T5 (4x Cree XRE@~1000mA) and my Hope Vision 4!
    We will seeeeee
    Torch is leaving Hong Kong today!!
    Moderator Moderator
    Reputation: 2melow's Avatar
    I got this light last week and it is huge. Bar mount only...it's far brighter than 4 of my 230 watt torches combined. I can't see anyone wanting to put this on a helmet - modding as mentioned above would be sweet.
    Front Range Forum Moderator
    Recieved it last Thursday, but hadn't time to play with it during the last days.
    Did only a quick test to see if it is working!
    Loaded 2 18650 Samsung 2600mAh Liion cells and turned it on - its bright with 5 modes.
    The cells have a too lose fit, so the torch turns off and on when turning it upside down
    Therefore loaded 4 CR123 Cells (from AW) into it - its as bright as with 2 cells
    After a few seconds the lamp started to flicker and finally turned off!??
    switched back to the 18650 cells and it turned on again, but the modes were gone! only full blast or nothing!
    seems the driver circuit is a bit on the low side of quality
    A quick comparison to my 4xXRE modded torch shows a warmer tint, more peripheral light and the same throw.
    will do outside comparison later on, i also made some pictures - will post them when i have time
    Sounds like it might indeed be putting out around 900-1000 lumens. If I didn't already own a 1000lm triple xpg bar light I would seriously consider modding one these for the bars. For the cost of the torch, battery holder, batteries and other DIY supplies, a person could easily put together a 900-1000lm lamp for somewhere around $100.
    Can't wait to see some beam pics so I can judge the throw/beam pattern.
    Moderator Moderator
    switched back to the 28650 cells and it turned on again, but the modes were gone! only full blast or nothing!
    will do outside comparison later on, i also made some pictures - will post them this late afternoon
    Mine seems ok. The flood is really really nice but the light is long and heavy. I think this one might end up on my WR250F...
    I was going to make some beamshots, but the torch isn't working any more!
    So i opened it up and removed the driver board from the housing - and....
    ....the black wire was loose!!
    Now the only problem ist that I don't know where to solder!
    NEEEED Help!!
    Some Pictures to ilustrate:
    I marked on the 2nd and 4th picture the areas where i found the negative potential with the multimeter! Hope this helps??
    Oh My! Well , I guess this explains why you had some trouble.
    My only suggestion is the obvious....Look for a solder connection with some pieces of wire sticking out of it. If that doesn't work send this ball-of-wax back for a replacement. Of course if you choose right and resolder you should be good. If you manage to get it working again be sure to take some more detailed photos for future reference. You never know who may soon have the same problem. Interesting driver that is. If you do figure out the connection, before re-soldering it would be nice if you could do a current test of the SST-50 on high to see what the driver is really supplying to the emitter.
    Yea looks like the obvious isn't! There is no piece of wire sticking out somewhere!
    It looks like the wire desoldered due to heat generated by the high current....
    Edit: I discovered that i have electrical contact from the spring(plus) to the red wire
    and from the outher ring(minus) to the place I marked in the 2nd picture!!
    I tried to measure the current with this aproach of connection, but nothing happened!
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    It looks like the wire desoldered due to heat generated by the high currant....
    Its a possibility, because I've noticed that driver does seem to get pretty hot... but it would of had to be poorly soldered in the first place I think otherwise other components would also be unsoldering themselves.
    I might be able to help you out if you get really stuck as also have that model of torch from DX, but I won't be able to get to it for a few days most likely. Let me know you don't figure out where that wire goes.
    Oh and if I was to make a guess, the spot you circled in the 2nd picture is a very good candidate for that ground wire (especially if you've confirmed with a multimeter that it is at ground potential relative to the battery ground).
    another thing to mention:
    Tere is really no thermal paste in this light!!!
    The Led has some thermal glue to stick on the heatsink, but the rest of the torch is completely without!
    If I get my light working I will add some paste between the LED heatsink and the reflector and between the reflector and the bezel!
    I measured the diameter of the driver: it is 20mm !! Are there any driver out there that will fit, so i can replace the broken one?
    Have you determined the driver is broken or do you still not know where to hook up the black wire?
    Until now i don't know where to hook up the black wire and if the driver is broken or not !
    Update: soldered the black wire after some measurements to the position marked in the picture:
    Woooohoooo - the light is working again!!
    The modes are still gone.... but this doesn't bother me much.
    I also tried to measure the amps, but my multimeter wasn't showing any results
    Ok, seems like sh** happens!
    Fired up the light and after a short time (app a few seconds) it died!
    Smelled strong like burned electric components
    I didn't opened it again....but I am shure its dead now
    Looks like you have some decisions to make now. You could send it back to get a replacement or keep the old one for parts. Before doing that though I would quickly test ( using one 18650 ) using the direct drive method to see if the emitter still works. If it does all you have to do it get another driver. That shouldn't be too long a wait before Taskled begins to market one that should work fine. ( for modding that is ).
    It would be great if you could just get the driver from D/X.
    I don't know if they will do something like that but it is worth a try.
    I have already requested an RMA at DX, but no response until now! (did this after the first problem)
    I think the led works fine - its the dirver...
    I'm in contact with "Der Wichtel" over at CPF, he makes some realy nice drivers! But only 2.8A ;-(
    perhaps it is possible do use this after some modding?
    Tonight I was messing around with my SST-50 drop-in.
    I removed some of the reflectors from my other torches just
    to see if I could tighten the beam a bit. The ones from the
    P-7's had too big an opening for the emitter and so there was
    not much difference. However when I took the reflector off my
    Aurora MC-E torch things got interesting. I held the reflector up
    to the emitter and..."WOW"!.. ..now that's some nicer
    throw there. Since my Aurora was my best throwing torch I
    suppose this should of been no surprise. When used with the
    SST-50 emitter the throw looks a tad better than with the MC-E,
    not to mention it still has a slightly wider center spot. As I sat
    pondering how I might couple these two together I found these
    on D/X > http://www.dealextreme.com/details.dx/sku.33617
    and this > http://www.dealextreme.com/details.dx/sku.33616
    The first looks to be about the same size but ...hummmm....if only
    they showed the actual size of the reflector itself. The second one looks
    very interesting...a much sleeker profile but with a very good review.....hummmm..
    ..if only I had some deeper pockets.
    Anyway, FWIW...the beam pattern with the Aurora reflector I have is
    fantastic... Great throw...no artifacts...period.
    ( Note to DIY'ers...A duel SST-50 set-up would just blow your
    doors off if you use the right reflector )
    Got the RMA request from DX today, but will wait until some new drivers arrive which i have ordered!
    Also ordered an mce drop in module which should suit....
