Page 10 of 10 FirstFirst ... 678910
Results 451 to 488 of 488
  1. #451
    Reputation: djjeffa's Avatar
    I got a qestion for you guys that grab theses clones, do you think the one led or three led is better. Im guessing the one would would have a wider throw and better battery life whats your guys thoughts?
  2. #452
    Nov 2012
    Usually more LEDs mean more efficiency, 3XML clones are a good mix of flood & throw for a bar light and they have more lumens output than 1 XML clones.
  3. #453
    Re: New clone 3 x XML T-6 49.88 shipped
    Quote Originally Posted by MK96 View Post
    Thanks for the info, I fingered the 3 would be brighter but thought it would be a bigger draw and with the size of the reflector I thought the beam would be more narrow.
    Sent from my EVO LTE using Tapatalk 2
  4. #454
    Nov 2012
    Acutally 1 XM-L clone needs wide angle lens, to get more flood. 3 XM-L clone (this or Skyray S6) is just a nice mix of both flood/throw. 3 XM-L will draw more from battery (about 14-16W of power drawn from batteries), but it is a brighter light and you have the modes you can change - so you don't need to max it out everytime.
  5. #455
    I'm guessing the xlm clown don't have a real Cree led in so my question is has any of you guys try putting a better led in this setup?
  6. #456
    Nov 2012
    Yes, these clones have cree xm-l leds, but mostly with the cheapest tint/bin color. I am replacing my xm-l's with xm-l2 in my Skyray S6 light also with stronger 30W driver.
  7. #457
    Thanks for the info I'm trying to find the best set up for $50 so I don't know if I'm gonna get a 3 or one led cause I was thinking of getting a one with a flood lens and beefing up the led and driver.
  8. #458
    Ok, saw this one which has a reflector at the top of the light head. Seems like it would reflect more light down at the trail. Good idea. Anyone tried one like this or made their own reflector like this to enhance the light or does it not really work.
    4500LM 3X CREE XML T6 LED Cycling Front Head Bike Lamp Bicycle Light Headlamp H5 | eBay
    MB
  9. #459
    Quote Originally Posted by mb323323 View Post
    MB
    MB, there must at least 20 or more versions of Tri-clone floating around on the web. I've seen other versions of bike lamps with the shield. Could be useful for on the road. It needs to be pointed out that the lamp you linked to only looks to have two steady modes and one flash mode. Most tri-clones have 3 steady modes and one flash.
  10. #460
    Nov 2012
    Nope I didn't tried that. But I have seen it at lightmalls -this one and some other also. Anyway it is easy to try similar setup with some alloy foil on top of the lighthead. But this alloy reflector has to be smooth to reflect the light back down to the trail. There are zillions of 3 XMLs out just take a look 3LED Bike Light - 3T6 Bike Light - 3R5 LED Bike Light Worldwide Free Shipping!!!
  11. #461
    Thx
    I know there are loads of these out there, I was just curious if the shield really worked as it looks kinda interesting and seems like it would reflect more light at the ground thus acting like a light w/ more lumens.
    Hmmm, maybe I'll try some kind of mod and see what I can come up w/.
  12. #462
    To be honest I don't think its a reflector because its not shiny, I believe its to keep the light out of on oncoming peoples eyes.
  13. #463
    Nov 2012
    It is not shiny so you are right about blinding. But if you want more light on the trail you need to add a shiny shield to reflect the light down.
  14. #464
    Stepless XML2 U2
    I got one of these last week and did a little testing to see if it would have heat issues like steelhmr. I had a small fan blowing on it and it was approx 70F indoor temp. I put it on high and watched it with a thermal camera. It was a little slow to heat up and when the case temp hit 108F it throttled back to low. Once it dropped a few degrees it went back up to high until it hit 108F and dropped again. This was much lower than I was expecting so I opened it up to add some thermal paste. The inside looked just like the pics uploaded earlier with just the very thin (and poorly applied) white paste. I cleaned it off and tried to pull the retaining ring that holds the mounting plate for the leds to see if there was any paste between it and the case. I was unable to pull the ring but was able to determine that the plate is sitting on a lip that is about 3mm. I put new paste so that the plate would be better connected to the case and a fresh layer between the led and plate. Put it back together and ran the same test. Fired it up and at 112F it dropped back to low. I was disappointed until I noticed the red led on the back was blinking and thought maybe it changed to low due to that. Sure enough, plugged in a different battery and it ran all the way until I abandoned the test at 130F case temp. If you get this light, you must add thermal paste. But once that is done you shouldn't have any thermal shutdown issues.
    http://kaidomain.com/Product/Details.S021404
  15. #465
    Thanks for the info rob, I haven't ran mine yet because I'm still waiting for my flood lens bit I will be sure to add some paste.
  16. #466
    Quote Originally Posted by djjeffa View Post
    Where did you find a flood lens that fits?
  17. #467
    Amazon but wait till I get it before you order. Let me make sure it fits.
  18. #468
    If it's not 45mm in diameter it wont fit.
  19. #469
    Quote Originally Posted by robs31 View Post
    Great to hear that you had the same success with the thermal management issue that I did. Curious to hear your thoughts on the brightness, beam pattern, etc.
  20. #470
    I, too, am very curious about how this works out. I'd probably be more interested in changing the reflectors/cones. I just want to redirect the small hot spot into a wider flood (without sacrificing total lumens).
  21. #471
    I didn't bother measuring but it fits New clone 3 x XML T-6  49.88 shipped-uploadfromtaptalk1389051064262.jpg
  22. #472
    Please measure and provide a link to the lens you bought. Also a beamshot with and without would be greatly appreciated.
  23. #473
    http://www.amazon.com/gp/aw/d/B004WL..._M3T1_ST1_dp_1
    It is like 1.5 in about 38mm give or take.
    Ill post pics when I have time.
    Btw there beam shot on that page mine is just brighter.
  24. #474
    Bummer. That is the same size as the one I have for my 808 clone. Our 3X are different diameters and it is way to small for mine.
  25. #475
    May 2014
    Sorry to bring up an old thread, I have the manta ray stepless like steelhmr. I've noticed that I don't get much run time on it before the LED turns red. This even happens when I go to on a 10 min ride on max, let the bike sit outside at 45 degrees for an hour, then on the ride back it turns red after a minute. I think I ended up with a bad battery. Are there any suggestions for a good replacement battery?
  26. #476
    Nov 2012
    Action-led, hunk-lee (ebayer), DX - pannovo B-C04 case with 4 x 18650 protected cells. Bunch of options ...
  27. #477
    Quote Originally Posted by Folsom View Post
    I have the same lamp. The Manta Ray D003 draws a bit of battery power so it doesn't surprise me that the supplied battery isn't going to cut it. Cold weather only makes matters worse. A 4-cell battery using Panasonic cells is likely your best bet for better run times. Another way to go is to buy a 6-cell battery. Then again you might consider one of the 4-cell battery holders and buy the cells you want to provide the run time you need. The advantage of a cell holder is that you can remove the batteries ( on a ride ) and replace if needed ( if you have spares ). The holder should work with just two cells ( if need be ) so if you run out of juice on a ride all you should need are two extra cells for back up. If running just two cells you will need to run lower power levels though.
    While on the subject I should mention that the LED battery indicators on some of the cheaper Chinese lamps vary on how they work. I've seen the red indicator come on with one of my lamps and still had an hour of run time. Sometimes this just happens and temperature of the batteries has a lot to do with how the indicators work. Preferably you would like the red indicator to tell you when are almost out of battery power (10-15 minutes of run time left ) Unfortunately not all indicators are going to work the same. A lot depends on the quality/capacity of the cells and well as the ambient temperature of the cells. This is why it is imperative that you do a run time test with your lamp/battery so you know what to expect once you get out in the field. If you don't do this than it would be a good idea to carry something for back-up. Though I rarely need it myself, I always carry a small single cell XM-L torch on my bars. Better to have something and not need it than to need something and not have it.
    Likely nothing is wrong with your battery. It probably just doesn't have the needed capacity to supply your lamp with full power for anything more than 90 minutes or so ( @ 70F ). A high capacity battery ( > 6000mAh ) should get you over two hours on high with the lamp you are using. Personally I never run mine on high for more than a couple minutes at a time so the advice I'm giving you is based on theoretical numbers. As such, usually I'm not too far off the mark if I'm wrong. If I ever do an extended ride with mine I'll just carry a back up battery to stay on the safe side but for the most part I'm very good at milking the *battery to get the most run time out of it.. (*note; not the supplied battery, I have better batteries )
  28. #478
    May 2014
    I finally bought a pannovo B-C04, and I installed 4 2250mAh batteries in it. This pack is lasting much longer than the original battery pack. I've run it over an hour on high with a fan on it with the button staying green. The original pack only lasted about 10 minutes before the button turned red.
    I did some measurements with this light, and it draws 2A at high power. The button turns red around 6.6V-6.7V, and the light shuts off at 6.3V-6.4V.
  29. #479
    Jul 2015
    I've been looking for a good and cheap light for the past two days and I think I've just found it...
    I was looking for: Good thermal design (most chinese lights have shit internal thermal design and in case they do (Yinding) the outer heatsink is way too small - this one seems to provide good internal thermal design and a big heatsink); two or three XM-L2 LEDs; a not-shit UI - this one seems to have one of the best UIs.
    I just messaged kaidomain asking if I could buy these lights without the battery and charger since I plan on building my own 2S2P (or maybe 2S3P) battery out of Sanyo NCR18650BF batteries (sourced from the original Xiaomi 10000mAh power bank Original Xiaomi Pocket 10000mAh Mobile Power Bank Portable Charger for Samsung Galaxy iPad iPhone 6 Plus 6 5 5S 5C HTC ONE M9 Tablet etc.-12.55 and Free Shipping| GearBest.com - see [Reserved] New 10000mAh mobile power xiaomi dismantling: batteries too fast! - Mi Gadgets - Xiaomi MIUI Official Forum)
    In case you guys know where I could buy this light from without the included batteries and charger please let me know. Or maybe something new that comes close to this one? (I did not come across anything yet.)
    Also sorry for necroposting hehe.
  30. #480
    Jul 2015
    Second try posting.... (Edit: Kill me I didn't read the text after I've submitted my post)
    So, after searching for a cheap and well engineered light for the past few days I've came across this thread (and Cat-man-do's review) and contacted the seller (kaidomain) to see if I can buy two of these lights without the included batteries and charger.
    I will be using NCR18650BF sourced from the genuine Xiaomi 10000mAh powerbank: Original Xiaomi Pocket 10000mAh Mobile Power Bank Portable Charger for Samsung Galaxy iPad iPhone 6 Plus 6 5 5S 5C HTC ONE M9 Tablet etc.-12.55 and Free Shipping| GearBest.com - see [Reserved] New 10000mAh mobile power xiaomi dismantling: batteries too fast! - Mi Gadgets - Xiaomi MIUI Official Forum too.
    I was looking for 2x or 3x Cree XM-L2 lights which offer good heatsinking (most of these chinese lights have an awful thermal path inside the housing and some of them have a good internal thermal design but are way too small (Yinding) or both...)
    I was also looking for a good UI, and I think this light here probably has one of the best.
    So yeah, hopefully I will be able to buy them for cheap without the battery and all that crap. If you guys know any light that'd probably be better or can change my mind about my purchase please do so!
    (And sorry for necroposting)
  31. #481
    RAKC
    Reputation: tigris99's Avatar
    IM trying to find where that thing has actual sanyo cells, especially 4 of them for $12
    Anyway, there is alot of lights out now far better than this thing IMO. Nitefighter has 2 (bt40s and bt21) also solarstorm has the xt40 and x3 (x6 looked promising but its got crap for thermal path). This light head is now rather out dated, emitters and other designs have surpassed it by quite a bit now.
    That said, if you still want this light, check ebay, usually the best place to find light heads only. BUt like most chinese lights, it a total crap shoot as to what you get. Yinding, Nitefighters, solarstorm lights are al the current ones and reviews are done so we know exactly how they are built before spending money.
    The best part of the bicycle life doesn't begin till the sun goes down.
    www.rakcindustries.com
  32. #482
    I have two Xiaomi power banks on the way just for the same reason - use the good Sanyo cells in a 2S3P battery pack. Actualy I've started thread about some battery packs and there I had intention to describe how to use existing welded packs from laptop or powerbank. Actualy I've already used 6 old laptop 2900 Panasonics in a 2S3P version. I just need to publish it.
  33. #483
    Jul 2015
    @tigris99: That Xiaomi powerbank has three original Sanyo-Panasonic NCR18650BF, see the pictures in this thread: [Reserved] New 10000mAh mobile power xiaomi dismantling: batteries too fast! - Mi Gadgets - Xiaomi MIUI Official Forum
    I have one of the old 10400mAh powerbanks from Xiaomi with four LG LGABB41865 cells and two of these new powerbanks coming in the mail.
    Also the only good light out of these you've mentioned (in my opinion) is the Nitefighter BT40s, all the others have awful thermal design - either the emitters have barely any contact with the case (Solarstorm) or the case is too small to be a big enough heatsink on the highest mode (which are most of the time not even that high because of that).
    So yeah I might actually go for the BT40s, which sadly has a worse UI but maybe I can reflash the chip on there - since it seems like most of these lights use ATMegas and I have the equipment for these.
    Also nice thread ledoman! I'm looking for a good 2S3P or 2S2P pack to purchase myself, no need for protection etc. since the lights come with battery indicators nowadays and for charging I'm using a Intellicharger i4 anyways. (So removable batteries is a must)
    I've asked the seller if they are offering a lighthead only option for this light and they've said that they will contact their supplier.
    Seem like it's time to make this forum aware of the Xiaomi powerbanks.
    (From the thread on MIUI)
  34. #484
    Yup, I'm aware of it. I've just need to be shure so I haven't published it until I could check it myself.
    Here is my review of battery packs were the cells could be used as a DIY parts: Review: 4 (2S2P) and 6 cell (2S3P) hardshell waterproof bicycle battery packs from GB
  35. #485
    Reputation: garrybunk's Avatar
    Feb 2014
    Dang! Price jumped up on those power banks before I got two ordered! Well, at least $16.01 isn't so bad.
    -Garry
  36. #486
    Jul 2015
    I've got mine from here ( https://www.allbuy.com/detail/25023 ) actually, I've posted the gearbest link since people here seem to like it better :P
  37. #487
    Well yes, to bad. Will try to get some coupon from May. Previous price was on the "edge" she said.
  38. #488
    RAKC
    Dang, it wasn't a bad deal before and really still not since they are welded already.
