Results 1 to 14 of 14
    Need flashlight or bike light for the helmet w/replaceable 18650 battery.
    So, I have searched (amazon and others), but I'm having now luck.
    Criteria:
    1. Replaceable 18650 batteries
    2. 250-450 lumens on high/med or whatever setting
    3. Low profile cylindrical shape preferred.
    4. $75 or less (not including battery)
    5. Run time on the 250-450 lumens 2+ hrs.
    The Lenzyne Macro drive is almost what I want, but the battery cannot be swapped out. This will get a lot of commute use. So, wearing out the battery and not being able to replace it after 9 months seems a waste of $70 and a light. (the SuperDrive and Power have a mount tab in the way)
    Anyone have any recommendations?
    Lead by my Lefty............... right down the trail, no brakes.
    Reputation: Bearhunter's Avatar
    Mar 2014
    I just got the Yinding and am very happy with it. It was like $50 shipped. It comes with a sealed battery pack, but you can buy a separate battery case that allows you to remove the batteries and charge them for like $15
    Quote Originally Posted by Bearhunter View Post
    Thanks,
    I took a look and I'd like some water resistance. I usually don't ride when it rains, but my crystal ball telling me the weather has been stolen.
    If I did not want to use the "cheap" Chinese battery pack, what could I use that is $40 or so and 2 cells. I only want 2 cells because of the weight.
    Jun 2013
    I'm not a boy: https://www.youtube.com/watch?v=znNxuX-NmA0&index=2&list=UUHyRS8bRu6zPoymgKaIoDLA
    Reputation: socal_jack's Avatar
    Dec 2008
    Fenix BT20 LED Bike Light - Fenix-Store
    Just a bit over your price but close, the Fenix BT-20 bike light. Dual replaceable 18650 batteries in a sealed container.
    Mar 2014
    Quote Originally Posted by ziscwg View Post
    Sorry I can't help as I do not have any experience with two cell lights. As far as waterproofing, the "battery thread" has some pretty good info on a cell pack that you can order with screw/o-ring connectors (very inexpensive as well if I recall correctly). Here is how I currently have my 4 cell pack setup.
    Need flashlight or bike light for the helmet w/replaceable 18650 battery.-imageuploadedbytapatalk1399422843.764096.jpg
    The Yinding is also plenty bright. Very happy with it.
    Reputation: Wombat's Avatar
    Use the $23 2 cell magicshine battery that Action LED sells: Action-LED-Lights ? MJ-6008 2200mAh Waterproof Battery.
    Tim
    Thank you everyone. I'm not sure what I'm getting yet.
    Now, what is another thing to consider is that I found a video that shows how to disassmeble the micro and macro drive from Lezyne. Sure it voids the warranty, but I don't think I will kill the battery before the warranty goes out.
    ballbuster
    Reputation: pimpbot's Avatar
    What is the specific reason you're trying to fill with the replaceable battery? Is it runtime, to swap out the battery mid-ride if it runs low, or is it longevity. When the battery no longer holds a charge, you can replace it yourself?
    I gotta say, I'm pretty dang happy with my NiteRider Lumina 650. It looks like you can replace the battery yourself when it goes bad, but I wouldn't try it on the trail. There might be soldering involved.
    Nashbar has them for like $75 right now.
    Nov 2012
    Get the Powerdrive XL for around $70 on amazon. Replaceable battery, 400 lumens max.
    Amazon.com : Lezyne Power Drive Xl LED Front Light (Black) : Bike Lighting Parts And Accessories : Sports & Outdoors.
    Or the superdrive for around 80
    http://www.amazon.com/Lezyne-Super-D...dp/B008R5QLQC/
    Those macros are more of a be-seen commuter light. In my opinion, you need something a little more high power for mountain biking.
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    You might look at the Gemini XERA Flashlight. Up to 850 lumens and one interchangeable 18650.
    Jim Harger
    Action LED Lights
    www.action-led-lights.com
    Both the Power Drive and Super Drive have one thing I don't like, the mount. More specifically, the helmet mount. It makes the light stick up too much. A low branch bush has caught this once already. Also, in commuting with it on the helmet, it feels heavy up there.
    Quote Originally Posted by varider View Post
    Amazon.com : Lezyne Super Drive Xl LED Front Light (Black) : Bike Lighting Parts And Accessories : Sports & Outdoors
    I am going to go with the Macro Drive as I have found a way to replace the battery when needed. Or, I might replace the stock 2600 mah one with a 3400 mah for longer run time.
  1. Helmet mounted light w battery pack?
    By yooper1019 in forum Lights and Night Riding
    Last Post: 02-18-2014, 11:10 AM
  2. Lightweight helmet mounted light/battery recommendations
    By Casual Observer in forum Arizona
    Last Post: 08-21-2012, 10:05 PM
  3. LXP B4 4*XM-L U2, 6*18650, 3500lumens Bike light
    By Cat-man-do in forum Lights and Night Riding
    Last Post: 07-25-2012, 08:32 PM
  4. 18650 Helmet Mounted Flashlight - Big lumens small size
    By a1rports in forum Lights and Night Riding
    Last Post: 08-02-2011, 03:27 AM
  5. Light AND battery on helmet
    By xjbaylor in forum Lights and Night Riding
    Last Post: 01-04-2011, 04:26 PM
