Results 1 to 5 of 5
    Nov 2012
    multi-emitter 5 6 7 XMLs
    Has anyone tried these multi-emitter lights? There is a plenty of them on DX and KD with various set-ups (battery, modes, brands of course - nitefire, skyray, ultrafire, boruit and some short letter brands IP, LW, etc):
    7 XML T6
    7 XML2 U2
    skyray 6 XML T6
    5 XML T6
    I use the 3 up XML T-6. The battery is not enough to power it. I have been using an older GEO 6.0 battery to power it and get about 2 hrs on high. The light head has actually worked fine.
    There's no way the batteries are going to power any of these lights. And on the 5, 6 or 7's, that battery is gonna last about 15 minutes if it even powers it at all.
    You can get a good battery to power it tho for about 50 bucks I think.
    MB
    I agree with MB. I also have 3 xml light, and needed to upgrade the battery to get a decent run time. I have to think these 5-6-7 led lights are either going to have VERY short run times, or they are going to be under driven so they just aren't as bright. So 7 leds may not be any brighter then a nice 2 led unit.
    Only way around it is to use a much larger (heavier) battery.
    There's barely a noticeable difference on my light when I switch between 2 leds and 3 leds. So I actually only run it with 2 leds on for maximum run time.
    Personally, I doubt I'd ever buy a 6-7 (or higher) led light because of this. It would make more sense to buy two or three separate lights, each with just 2 leds.
    A 2 led unit (with some type of XML's) on the helmet with the battery in a hydration pack, and a 2 led unit on the handlebars with battery strapped to the frame is a LOT of light.
    Kir
    Kir is offline
    May 2013
    Nov 2012
    So there is nothing much about it Seems they are heavy overall.
  1. IR emitter knowledge?
    By Vancbiker in forum Lights DIY - Do It Yourself
    Last Post: 01-29-2013, 08:13 AM
  2. emitter reflow problem
    By adrenalnjunky in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2012, 02:53 PM
  3. P7 or XM-L emitter Identification
    By Fred Smedley in forum Lights DIY - Do It Yourself
    Last Post: 01-14-2012, 08:16 AM
  4. running 4 XMLs 2s2p from LFLEX on a 7.4v 2s LIPO
    By ballsofcottonwool in forum Lights DIY - Do It Yourself
    Last Post: 10-04-2011, 06:44 AM
  5. Ayups putting in XMLs
    By troutie-mtb in forum Lights DIY - Do It Yourself
    Last Post: 03-10-2011, 08:14 AM
