• 11-25-2012
    Mr.Grumpy
    5 Attachment(s)
    Mini CREE LED XML XM-L T6 LED 1600Lm - $38 Shipped
    Hello.
    I posted some of this information in another thread (http://forums.mtbr.com/lights-night-...-814616-7.html) but it was suggested I start a new one. So here it is!
    I purchased the following Mini Cree XML light from ebay.
    Mini CREE LED XML XM-L T6 LED 1600Lm Bicycle Light Bike Lamp HeadLight headLamp | eBay
    When the light arrived the first thing I did was run a charge and discharge cycle on the battery with my hobby charger. I was able to pull almost 3700 milliamps from the battery. So, the battery appears to be a 4400 milliamps pack, not a 6400 milliamp pack that the seller claims. This was expect and isn't the end of the world as you will soon see!
    Run times
    Low
    Amp Draw - 0.32
    10 Hours 17 Minutes, the light stays on, but the button changes to RED
    10 Hours 24 Minutes, OFF
    High
    Amp Draw - 0.64
    5 Hours 19 Minutes, the light stays on, but the button changes to RED
    5 Hours 25 Minutes, OFF
    Tests were run in my garage with a laptop and a fan. Approximate temperature was 12 C /54 F in the garage.
    I'm more than happy with these numbers!
    Now for some pictures!
    Canon SX10IS
    ISO 100
    4 Second Shutter
    F4.0 Aperture
    WB Daylight
    The bike is about 55 feet away.
    Reference
    Attachment 739771
    Low - Mini CREE LED XML XM-L T6 LED 1600Lm
    Attachment 739772
    High - Mini CREE LED XML XM-L T6 LED 1600Lm
    Attachment 739773
    Sizing
    Attachment 739774
    Attachment 739775
    This are some comparison beam shots to another ebay light here (3x Tri-Clone).
    http://forums.mtbr.com/9881218-post152.html
    If the light/battery lasts, I'll be happy.
    Enjoy!
  • 11-25-2012
    Cat-man-do
    Grumps....Glad you decided to start a new thread. :thumbsup:
    I'm surprised this lamp draws so little current ( amps ). Anyway, still looks pretty bright on high and you can't argue with the run times. Also glad to see that it has at least some LED warning before shut down.
    Question: Did you think to try the battery that came with the Mini on the 3 x XML Tri-clone to see if there is any difference in run time compared to the TRI-clone battery? As a side thought if you do just make sure both batteries are the same voltage before hooking it up. I'd hate to have someone ruin one of their lamps based on one of my suggestions.
  • 11-25-2012
    Mr.Grumpy
    I did run this battery this morning with the Tri-clone on medium. To my surprise, it was still going at the 2.5 hour mark when I left for my ride. So that's good news. The bad news, when I returned from my 3 hour ride the light was still on but very dim. Doh! So is the protection on this mini light in the head or the battery? I have no idea. Seems odd, but it's possible I guess. I'm charging the battery back up with my rc charger. Hopefully I didn't kill it!
  • 11-25-2012
    Mr.Grumpy
    Wasn't thinking when I posted this. I turned the Tri-clone off right away then turned it on again. It immediately turned off. I tested the battery with a volt meter and couldn't get anything. I then put it on my rc charger on a discharged and it failed with voltage to low. I then set the charger to charge and turned it on and let it run for a few seconds. Stopped and tested the battery again for voltage. Nothing! I put it back on the charger and that's where it remains. It's been charging for an hour, has put 1000 milliamperes in and the voltage is at 7.52 and slowly climbing. I'll let it run and see what happens.
  • 11-25-2012
    fightnut
    I'm also gald you started a thread on this light :thumbsup:
    It's a cool light, and warrents it's own discussion. Great photos showing the size and using batteries for comparison. I really like the small size.
    I'm most likely going to get one of these sooner or later. It'll be a great helmet light, and inexpensive enough to loan out to friends.
  • 11-25-2012
    Cat-man-do
    Wow-weeee! Good that it sounds like the battery is much better but definitely sounds like the protection ( if it has any ) didn't kick in. Next time you might want to be watching when it gets around the 1hr 45 min mark. If you notice the lamp is significantly dimming, that is a good time to stop the test.
  • 11-25-2012
    Mr.Grumpy
    Ya I didn't think anything of it since every other test run with these lights/batteries its always cut out. Ah well, hopefully the battery is okay. Pretty sure I'm done testing anyways. I have a pretty good idea on runtime. I do have two more batteries coming. I contacted both sellers, Mini and Tri-clone and told them their must be something wrong with the ones i got since they are nowhere near the claimed 6400 mah batteries. I'll just test those on a discharge cycle with the rc charger. Way easier and once I get the output, I'll have a good idea on run time from my other tests.
  • 11-25-2012
    Cat-man-do
    .... I do have two more batteries coming.
    Just curious, what batteries did you order??
  • 11-25-2012
    Mr.Grumpy
    They are the same batteries that came with each light. Both lights are advertised to come with a 6400 mah battery. The Tri-Clone I could only pull 2300 millamps and the Mini Cree I could pull 3700 milliamps. So both, aren't what was advertised. I contacted both sellers (they are different) and told them I must have gotten defective/the wrong batteries. So both sellers are sending me replacements at no charge. :)
  • 11-25-2012
    Mr.Grumpy
    Battery charged up. Took 4013 milliamperes. That's 300 more than I've put in before so the battery was very empty. It didn't explode or catch fire so that's good! Hopefully it's still good.
  • 11-25-2012
    Cat-man-do
    You said it. It definitely was drained. Sometimes when they get that low they can reach the point of no return. Glad to see that didn't happen.
    Dang, I was hoping that you were ordering new batteries from someplace else. I just hope the e-smay vendor doesn't send the SOS. Let us know how it works out.
  • 11-25-2012
    rideit
    I really am looking forwards to a 'real' lumen test (whatever that is!)
  • 11-26-2012
    bank5
    Mr. Grumpy, how big is the battery is and do you know how much it weighs? I'm thinking about picking up one of these over a trust fire tr-801.
  • 11-26-2012
    Mr.Grumpy
    The battery is the same size as all the other 4 cell 18650 battery packs. Weight, I'm not sure, but I'd say they are similar in size to a D cell battery, perhaps a touch bigger.
  • 11-26-2012
    mb323323
    Thx Grump for posting size picts. Looks to be 1/2 to 2/3 the size of a XML T6 clone. Actually looks like a nice package especially for 38 bucks delivered. I'm thinking it's a few less lumens than the regular size clone due to the longer run time. Would be nice to know tho.
    Maybe Coleen would be willing to test one.
    MB
  • 11-27-2012
    bobale
    Accoriding to Mr.Grumpys' measured amp draw it must be less bright because mine regular sized XM-L clone draws 1A on Hi.
  • 12-01-2012
    bank5
    My mini cree just arrived. It seems brighter and has better throw compared to my magic shine 900. The form factor and weight is better too. The tail light is super bright which is a nice plus. I'm definitely impressed as long as it lasts at least a season.
  • 12-03-2012
    PedroDank
    Mr.Grumpy, I just got my 1200lm bought from tomtop eBay seller, but i think there is something wrong with the battery as the light seams weak. Can you tell me how can i measure my battery? I do have a multimeter somewhere... I really want to measure it.
    I'm charging it again for the 2nd time and will then let it run for a couple hours in high outside as it is now 5C.
  • 12-03-2012
    bank5
    I just took my light out for the first time. One think that I don't like about it is that there's a bright ring of light around the outer edge of my vision. I find it distracting because it makes things bright in my peripheral vision. Has anyone else noticed this? I wonder if it's the same with all of them or if mine's a defect. I'm not sure if there's a way to fix it.
  • 12-03-2012
    tr6fan
    Mini Cree LED XMLT6
    Hey Mr. Grumpy
    Love the review, you are such a stud!
    Bought one based on your review alone.
    Pictures, current draw, and run time information are great!:thumbsup:
  • 12-03-2012
    FreeCoffee
    I have 3 of these, the mounts suck but nothing a few zip-ties can't fix. About 10 night rides or so on one of them without any issues.
  • 12-04-2012
    Mr.Grumpy
    For runtime tests I used a MacBook with a webcam and a fan to keep the light cool. I used photo booth in video mode to record the video. Reviewed the video and noted the run time.
  • 12-04-2012
    Mr.Grumpy
    Can you post a photo or highlight mine above to give us a better idea. I don't recall this being an issue for me.
  • 12-04-2012
    PedroDank
    Thank you Mr.Grumpy! Going to do almost exactly the same thing (with a macbook too) eheh in about 2 or 3 days.
    A friend of mine liked my "1200" lumen clone i got from eBay, but from the photos, it seems your is more powerful than mine, so i might tell him to get yours. Mine is a magic shine clone, so the wide angle from Action Led worked ok, but i'm not sure it will with this one. Will try to measure the lens...
    EDIT: It may not work as the wide angle lens is 39mm and eBay tells me yours is 35mm, although im not sure that is really the lens measurement; either way, it is smaller, so it probably wont work.
  • 12-10-2012
    MK96
    Well if we measure the current draw each of us uses different multimeters and power source. So there is a bit of uncertainity in all those measures. When I measure I write the voltage/amps/time to give more accurate report which can be further compared.
  • 12-10-2012
    bobale
    Totally valid point. It shoud be done that way.
  • 12-11-2012
    tr6fan
    Hey Grumps!
    Still say great job on the evaluation. You have milliamp battery capacity (twice), as well as initial current draw, voltage, charge times, and run times. Personally I don't need any more information than this. As my night rides are generally 2-3 hours the light will always be in the green zone for charging when I return from my ride. Although this light would probably do 2 rides, I recharge after every ride. One poster appeared to want time vs current vs voltage which doesn't matter much to me...... what does matter is how long I can see what crap is coming at me. If it is pitch black I am not turning off the light to save a battery pack if running one light. (I run 2 lights) This is a budget light with a big punch and if I have to replace a battery pack for $20 or less I am still way ahead of the game.
    Run times
    Low
    Amp Draw - 0.32
    High
    Amp Draw - 0.64
  • 12-11-2012
    MK96
    Only if you see the combination of voltage/amps/time you get a specification of the light and after that you know, what type of battery you should buy and how long will it last. In case you want to be correct, if not it is always an estimated specification ;)
    Originally Posted by tr6fan View Post
    Hey Grumps!
  • 12-11-2012
    red5jedi
    I would like to know how long the battery would last when ran on high till the switch turns red, then switch to low how long would the battery last after that?
  • 12-11-2012
    Tincup69
    I just picked one of these up, I will post my findings in a few weeks when it arrives.
  • 12-11-2012
    fast_monte`
    Mine arrived yesterday in the mail. The light is bright in the center with very little fill. On the trail it would make a great helmet spot light with a fill light on the bars.
    At rest the light uses 0.03 amps, on high it uses 0.67 amps, on low it uses 0.36 amps.
    The battery that came with it has a capacity of 4.0 Ah when tested at 2.0 amps, that is on par with the Geomangear replacement batteries.
    Here is the battery chart.
    bike light batteries by fbodyhappe, on Flickr
  • 12-11-2012
    PedroDank
    Thanks, fast_monte`. You say it is bright in the center...like MJ's 808, or is the 808 beam even narrower?
  • 12-12-2012
    fast_monte`
    I have the Magicshine 808 with the dimpled reflector, just the way it came from GeomanGear, and it has a better mix of fill and spot with a gentle gradient between the two. The mini CREE has a very sharp spot with less fill.
    I used the mini CREE on a road ride last night and I could not see as much off to the sides like with the 808. It is still a nice little light for cheap.
  • 12-12-2012
    PedroDank
    Ok, thank you for that! ;)
    Will probably get another clone but this time a U2 one. Will use a wide angle lens (already have one on a 808 clone) or even two of those to tet that 30x30 beam another user has been talking about...
    One wide angle lens pointed closer to the bike and the other U2 with two wide angle lens pointed a bit further to the ground should be all i need for road biking.
  • 12-14-2012
    dmcpeake
    I appreciate all the information here regarding this light and just received mine yesterday. Quite impressed with the results to $ ratio... I'm not that familiar with battery technology and what the proper procedures are to ensure long life. Is there a link to information on how to properly care for this battery that someone could point me to? Thanks in advance for any advice.
  • 12-18-2012
    roadrider1
    Ordered one and got it seven days later shipped to L.A. Going to machine up a custom bracket for mounting on my helmet and the battery fits into the shoulder strap pocket on my Osprey pack
  • 12-18-2012
    Tillers_Rule
    Bought one, super bright in my living room on a test. The battery would die within 30 seconds every time, completely. So I returned it.
    It was probably just a bad battery, but I was hesitant to order in the first place so this sealed the deal for me. Not the kit for me, unfortunately.
  • 12-19-2012
    Mr.Grumpy
    Which seller did you get your light from?
  • 12-19-2012
    rideit
    Yes, please share!
  • 12-26-2012
    NitroRC Ed
    I've been looking around but not had any luck yet. Does anyone know of a replacement optic that'll give this a little more flood?
    Honest - i did try and search :D
    And since i was in the office all day i decided to give it a test. Got batter fully charged and then fired it up with a fan and noted the time. Well after 4 hours I powered off the light...... Still seemed to be running great but was worried about killing the batteries. The indicator showed Green on the back still also..... No multi meter to test here though.
    Ed
  • 12-29-2012
    red5jedi
    So I got my light last week and topped off the charge. Yesterday I tested how long the light would last. On hi 5hr 50min then the button light turned from green to red - switched it to low and the light on the button turned green again. 10min later the button light turned red and 10min later it shut off.
  • 01-02-2013
    SoCalAl
    It sounds like this light would work well with a smaller 2 cell battery considering it's run time and the likeliness it would be helmet mounted. Would the batteries sold for Magicshines work with this light?
  • 01-03-2013
    fast_monte`
    The Magicshine batteries will work with this light. With two cells you could only expect the light to run for an hour and a half on high.
  • 01-15-2013
    Mr.Grumpy
    Another update.
    I finally received the no charge replacement battery from my vendor, CyberPort888.
    I was able to pull 3424 mah out of this battery.
    I have also received two additional Mini Cree lights for a friend that I ordered. I was able to pull the following out of each battery using my RC hobby charger.
    Battery 1 - 3920 mah
    Battery 2 - 3156 mah
    The kicker with these, the connectors are different than mine. The pin in the middle of the connector on the battery end is thick, just like my 3x XML and I believe MagicShines. Mine, is thin. See the comparison shot I took early of the Mini 1x XML plug beside the 3x XML.
    http://forums.mtbr.com/9881893-post153.html
    So far my original mini cree light and battery are going strong, it's been about two months since I got it and I've used it about once a week. Let's hope it keeps going!
  • 02-04-2013
    G_Mozz
    Received my one of these from the ebay seller.
    Current draw was measured as:
    High - 0.71amps (8.1v) ~5.75W
    Low - 0.38amps (8.15v) ~3.1W
    Battery capacity was measured at approx 4000mAh (5w load), so well short of the 6400mAh advertised.
    Connectors were 5.5x2.5mm plugs, not the 5.5x2.1mm ones it seems are used on most lights.
    Great light, just the helmet mount leaves alot to be desired so I'm looking for an alternate system of fixing it to the melon protector!
  • 02-06-2013
    PsyCro
    This little light has REALLY peaked my interest! I've been looking at 3x clones the last while, pretty much sold myself on one, and now this. It seems that for a little more money i can grab 2 of these, always have a backup, 2 chargers, and backup mounting equipment. And next to that, 2 of these seems to put out as much light as one of the 3x clones.. the big difference being that with one on the bars and one on the helmet, effectively i would have more use of it. Not to mention very nice run times :thumbsup:
    Now i just gotta figure out which wide angle lens to get for the bar lamp, and that should be that!! :D
    .. or is it ? :madman:
  • 02-06-2013
    spartacus001
    Great review. Thanks for taking the time to post.
    I love the long burn times. Must more efficient emitter/driver combination.
  • 02-06-2013
    the mayor
    Because of the price...I ordered one of these a few weeks ago.
    So I now have a 3X Xml ( great light! ) and a Hi-Max XML U2 ( Another great light).
    Waiting for the mini to get here....
  • 02-06-2013
    spartacus001
    Hey Mayor,
    It'd be great if you have some time to send us some side-by-side beam comparisons between the 3xXML and the Mini.:D
  • 02-06-2013
    the mayor
    Originally Posted by spartacus001 View Post
    Hey Mayor,
    It may be a while....
    I ordered the thing almost 4 weeks ago,,,same time I ordered the 3X ( which came in a week) and the U2 Hi Max ( which took 4 weeks). I emailed the vendor and got the " out of office for the Holiday" message. We'll see. I might put in a issue with Ebay/Paypal just to cover my butt on the 45 day deal.
    Edit: Mr Gumpy already posted pics....there's a link in the 1st post on this thread
  • 02-06-2013
    rideczech
    Great little lights for the money....can't go wrong really....:-)
  • 02-08-2013
    PsyCro
    Pro Mini CREE XM L T6 LED Bike Bicycle Head Light Headlamp Battery Charger D0081 | eBay
    hmmm, much cooler looking housing, aaand low-mid-high mode setup ...
  • 02-08-2013
    Mr.Grumpy
    Yup, doesn't look bad. But, you don't know the quality of the battery, though we never do! This battery (Pro model) looks to be only a 2 cell, not a 4 cell. So if you go this route, know that your run time will be estimated at half.
  • 02-08-2013
    the mayor
    Be aware that anything coming from China will be delayed because they are on holiday for a few weeks.
    Also...I bought this light which is much brighter....cost me around $44 on a non "buy it now" sale...
    Hi Max 1300LM CREE XML T6 U2 LED Headlamp Rechargeable Headlight Set | eBay
  • 02-08-2013
    PsyCro
    Good point Grumpy.. also, not many sold by that seller so no feedback. I'll probably stick with one of the other sellers who have sold maaaany mini's like the one you posted originally.. didn't see any poor feedback for them so should be good.
    edit.. @Mayor .. beam shots over in the XML U2 thread please !! :D
  • 08-05-2013
    PsyCro
    Just used mine yesterday on a big mountain ride right at sunset, and tomorrow a real night ride is up next.
    So far i'd say BRIGHT is the word as it reeeally has quite a bit of throw.. although i, am using mine with an Action LED wide angle lense which i grinded down a bit using a dremel tool. With the lense i'd say you get much more useable light. After tomorrow i'm probably ordering one more to use as a spot on my helmet for the big mountain rides while the modded light stays on the bars.
    That should be a great combo for some real downhilling.
    I'll have beam comparisom photos up in a day or two using and not using the wide angle lense for those who are interested.. ;)
  • 08-08-2013
    PsyCro
    Panasonic Lumix ZS3
    Semi-automatic
    F3.3
    1s
    ISO 400
    reference
    spot on helmet
    wide angle lense on bars
    both
    I guesstimate that the car in front of the volvo is max 30m away. Other than that, i'm thinking a do-over might be in order using less ISO. Now that the pics are on the comp i think i may have 'over done' them...
