Results 1 to 64 of 64
    Reputation: GTR2ebike's Avatar
    May 2010
    Magicshine Tail Light MJ-818 3W review w/ video
    I would like to thank Geoman for the excellent customer service, I ordered the light friday around 2:00pm, shortly after he put it on his site and got it at 12:30pm monday.
    First thing I noticed is the light has a dial around it which is the way to alternate modes, 120 degree turns change the mode. After realizing this I noticed that this means there is no button, which also means no battery gauge. Still the light is super bright from what I have seen so far and well worth the money.
    Obviously this is only a partial review because it's not dark out yet but I went in my basement and took a quick video to show the modes of the light
    Mode 1- Inner and outer lights flashing
    Mode 2- Inner and outer lights alternate flashing and strobe while they are on.
    Mode 3- Inner and outer lights on
    If you have any questions feel free to ask and FEEL FREE TO ADD YOUR OWN REVIEWS IN THIS THREAD!!!
    http://www.youtube.com/watch?v=h6daJlWPZUc
    How long is the wire to the battery by the pictues It seem to short I have my batterys for my m/s900s in my seat bag I was planing to put the light on my rack end on the fender
    and was hopeing that there was a long wire I do not know why they keep puting short wires on the lights
    May 2010
    Wire is about 1 foot, i'm not near the light so I can't give the exact length
    GeoMan
    Reputation: GEOMAN's Avatar
    The cable on the lighthead is 18 inches then you can add another 8 inches for the cable coming from the battery so you have 26 inches all up, it is compatible with the standard Magicshine 40 inch extension cable if you need more than the 26.
    Quote Originally Posted by stingray66
    GeoMan
    We Ride!
    www.geomangear.com
    GeoMan
    Nice job, thanks for the support
    Quote Originally Posted by GTR2ebike
    GeoMan
    We Ride!
    www.geomangear.com
    Thanks for the info this helps a lot
    Thanks for the video and review.
    Is it possible for you to take a few beam shot pictures 6+ feet away from a wall? A video would be awesome.
    It's difficult to gauge the brightness and spread of the light with it pointing directly into the camera.
    Cheers
    May 2010
    Yes I can do that sometime today
    May 2010
    I really like the no light up button design because that means the light doesn't draw any current while plugged in so no need to unplug it every time after use.
    I took the light in my basement to take the video and this light can be used as a flashlight if you don't mind the red tint. It is incredible how much light it produces.
    Here is the video, it is taken holding the camera and light 10 feet from the wall. The second mode I really don't care for because of how large the gaps are in the between the flashing strobes and when the outer rings light it up doesn't project nearly any light, that's why the gaps seem so big. Ideally this mode would have been best with a both inner and outer strobing (like the 4th mode on MS900's)
    The camera adjusts to the light in mode 3 so pause it right when it comes up that's how bright it really is. It makes it look duller the longer it's on the screen.
    Mar 2005
    Great job so far! How about some outside pictures? What would be really cool is to see it compared to a car's brake light from a real-world distance, like maybe 100 or more feet away...
    May 2010
    Quote Originally Posted by J_Hopper
    I can do that at some point but it's obviously only going to be the on mode. You want brake light or tail light, there is a difference
    May 2010
    It's mounted on my bike rack but haven't put the rack back on the bike yet. the light is tipped down because the rack on the bike sits at an angle. I'm going to run the wire under the rack and poke a hole in the bottom of my bag, so the battery and connection are in the bag.
    GeoMan
    Good job on all your work GTR, if you feel like another project keep count on your runtime, that 4 cell pack seems like it lasts forever on a single charge.
    GeoMan
    We Ride!
    www.geomangear.com
    Mar 2005
    I can do that at some point but it's obviously only going to be the on mode. You want brake light or tail light, there is a difference[/IMG]
    To be visible on the bike, I'm competing with both brake and tail lights. I know a DiNotte 140L competes favorably with a car's brake light. I'd like to see the MS compared to either a car's brake light (if not feasible, then a tail light) or a DiNotte 140L.
    I'm considering getting the MS tail light to add to my 140L, but I want to make sure it would be a valuable addition. I have a PBSF and it's virtually worthless next to the DiNotte.
    May 2010
    Quote Originally Posted by GEOMAN
    I plan too
    This is true but another inconsistency is what car I'm comparing the light to but I will do it sometime this week. I don't have a diNotte 140L or any good lights besides the 3 made by Magicshine . The 1400 hasn't even gotten used yet
    thank you for the effort of posting that video unfortunately it doesn't really show us much.
    perhaps if you have some time add a second light source. a 7-11 storefront, a car headlight or tail light
    this way we can compare the relative brightness
    thanks!
    Bike 1 - The black one with fat tires
    Bike 2 - The red and silver one with skinny tires
    May 2010
    Quote Originally Posted by martin_nj
    thanks!
    Thanks for the reiteration of something that I said I'm going to do.
    bah that's what i get for not reading the entire thread
    Jan 2009
    Lighthead only / new flash mode
    I have already asked Geoman if just the lighthead will be available if you already have a Magicshine headlight and Y cable (like I do). Hopefully he will respond here as well.
    I would also recommend a flash mode that keeps the smaller outer lights on all the time and flashes the bright center light. That would be like a Dinotte. Or blink the smaller lights a couple of times between bright flashes like a PB superflash. That way you don't dissapear into a black hole between bright flashes!
    Keep up the good work Geoman.
    Chuck
    GeoMan
    Thanks for the support, we have placed an order for tailights only for those folks who want to share their existing battery and extension cables, it could be a few weeks before we have those in stock, but it works nicely with a Y-cable and a 900/1400 sharing the battery.
    Quote Originally Posted by cbcmtb
    Chuck
    GeoMan
    We Ride!
    www.geomangear.com
    May 2010
    Chuck
    That is a great idea for a mode but I don't think they are going to change them since the light is already designed. Maybe if there is a V2 a few years down the road.
    Reputation: Tzvia's Avatar
    GTR2ebike-
    I too have a rack, but not a Topeak, mine's a Bontrager, and there is no ready place to mount a light with rubber o-ring mount like this. It looks like, in your case, you had a good horizontal spot and added a plastic piece of tubing to it to get it sized up. I had rigged up something similar, but as the mount was designed for a seatpost, (vertical), I grabbed the bike and bounced it a few times to simulate our wonderfully maintained Los Angeles roads, and the light rotated downward. You should test for this. I ended up using a hose clamp that has a screw that I positioned under the light, so it is stopped from rotating down.
    My solution is not as elegant and robust as I would like, so I am off to Home Depot to see what I can come up with. I may end up removing the mount on the lighthead and putting a different clamp on it; we shall see what HD has...
    The light itself is plenty bright, and I am currently using a Y cable and MS 900 up front with the 1400 battery tucked under the rack. Just got the whole combo (Thanks Geoman!) and I think it will work nicely on my commutes.
    Tzvia.
    May 2010
    Quote Originally Posted by Tzvia
    GTR2ebike-
    The rubber band is pretty tight on mine and it hasn't moved in the 22 miles i've put on it. Mine also goes around the piece of plastic you see behind the pvc pipe so that helps keep it a little tighter. But that is a good idea to stop it from rotating down, maybe i'll do that just incase because i have quite a few small hose clamps lying around lol.
    I was going to originally remove the mount from the light head and put a screw threw that into the pipe to have it extra secure but when i started looking at the light I noticed it has a notch for the mount which made me think that the mount is the back of the light and if you take it off the guts will be exposed. So i just didn't bother looking for a different solution.
    GeoMan
    You can unscrew the mount it's designed as a replaceable item in the event that the mount is damaged then we can just send you another to screw back on.
    GeoMan
    We Ride!
    www.geomangear.com
    May 2010
    Ahh I was wrong but that's a good thing, btw I just emailed you Geo
    Back from Home Depot...
    I knew I would need a section of pipe to use the band-mount on the taillight on my Bontrager rack, so first I bought a piece of PVC. Then I trekked over to electrical and got conduit clamps, #2 size. Followed that with some plastic-dip for the 900 battery.
    My rack had a piece of stamped U s haped metal under the rack for a reflector. It had already broken and had been removed, and would have been useless anyway. I decided to use the two conduit clamps, one attached to each side of where the reflector holder had been attached. Bridging them, a short piece of the PVC pipe. Ugly, but my commuter is a beater Fuji Newest 3.0 frame with a mix of MTB and road bits which would not win a beauty contest anyway. I don't want to dump the Bontrager rack because I otherwise like it, as it is lighter than the Topeak, and I have the cool QR trunk, and plan to buy the basket they make at some point.
    While looking at the smooth pipe and thinking of the best way to keep the light from rotating down, I thought- why not plastic-dip it to give the mount something to grip, and tied some thick string around it first, both to hang, and to create an extra bumpy rough spot for the lightmount to grab. Also dipped the two clamps.
    The light does not move on that plasticdip surface with the string bumps underneath. Yea! I then took the whole thing outside and turned it towards the sun, turned it on and stepped back. That is visible in daylight for sure! Now I know I will need two more heads and a Y for the sides, so I can get rid of those Sefras blinkies you see on the seatstays in my second pix. Well, I hope this helps others here who plan to use this light on their commute and don't have a chunk of visible seatpost. My only worry is of the PVC breaking, even though it is quite thick, but if it does, I'll use a piece of aluminum pipe. I may yet do that anyway.
    Tzvia.
    May 2010
    I put reflective tape on the piece of pvc pipe on my mount, that is plenty grippy.
    GeoMan
    We just received the individual tailight lightheads from the manufacturer, they are available on our site with y-cable and o'rings included.
    Chuck
    GeoMan
    We Ride!
    www.geomangear.com
    Geo: Is the length of the cord from the taillight along with the y-cable long enough to connect it to a 900 (old battery) that is mounted on the stem? I typically ride on the roads so I am particularly interested in this set-up for a standard size road bike. I would prefer not to add the 1 meter extension cable as that seems like it would be too much cable.
    Thanks in advance.
    May 2010
    Taillight head cable is 18 inches
    Y-cable is 12 inches
    Battery cable is 8-9 inches
    that's a total of 38 inches or 3 feet 2 inches
    GeoMan
    See GTR's response below he's got the correct numbers.
    Quote Originally Posted by punkaccountant
    Thanks in advance.
    GeoMan
    We Ride!
    www.geomangear.com
    May 2010
    Dual set-up. It's pretty sweet, I did this because I wanted to have the ability to run one on solid at night and one on strobe and both on strobe during the day.
    May 2010
    Pics from 40 feet away. couldn't really move back any further.
    MS > Taillights
    MS = Brakelights
    Reputation: MaximusHQ's Avatar
    Wow that is bright. I may have to get one of those as I already have a magicshine with battery. Nice job with the pics.
    GeoMan
    Agreed, something tells me cars shouldn't have any issue seeing you ahead
    Quote Originally Posted by MaximusHQ
    GeoMan
    We Ride!
    www.geomangear.com
    GTR2ebike: I just want to confirm that those pics were only one taillight...correct? It looks that way but your previous post showed a set-up with two lights so I just wanted to make sure.
    I will have to try this at night next to my cars brake lights
    Today is a cloudy and I just took this picture The top light is a mars 4 the botton one is the M/S bouth batterys are charged up My m/s tail light looks like the same as the mars 4 I hope my light is not bad out of the box because it is no brighter than the mars 4 " width="549">
    May 2010
    Yes that picture is one light on. I took pictures with two on also, it doesn't make much if any of a difference in pictures but in person it certainly does.
    May 2010
    To anyone else who made a bracket out of pipe and has a problem with the light head tilting down. I put a screw in the underside of the pipe just before the end of the ms mount, so now it no longer rotates down.
    How do they compare at night. When I first got my Lupine lights and tried them out in the daylight they were not as impressive as I thought they should be, but once it got dark and I took them out I was impressed. I just ordered the tail light just now so I will get a chance to test it out myself soon.
    May 2010
    They are pretty bright either way, first time I looked at my bike from the back(bright out)it hurt my eyes after 5 secs but at night any light will look brighter. When I look behind me (when riding at night) the road and trees are bright red. I'd recommend the light to anyone
    I wrote my question in the other MS taillight thread and thought i will try it here too
    Has anybody measured the current draw of the taillight?
    How long is the runtime with the standard magicshine battery@4,4Ah in steady mode?
    Reputation: ragnar.jensen's Avatar
    I use a piece of Tesa anti-slip tape on my plastic pipe.
    When it's 20 below freezing and the snow lays 10 inches deep, bicycle commuting kind of sucks.
    May 2010
    Quote Originally Posted by Whitedog1
    I don't think anyone on here knows but it was mentioned in another thread that Geoman ESTIMATED that a 900 taillight on high (180min runtime) and a taillight on steady would run for 160 mins. In theory if you break that down it takes 20 minutes off of the headlights runtime in 180 mins then it should last 180/20=9 x 180 =1620 mins(27 hours) again that is just in my head. I don't know how much sense it will make to someone that isn't in my head(which I hope non of you are)
    Thanks for your headwork
    But I think 27h is too much
    ragnar.jensen did a good job in the other MS thread
    It doesn't make any sense to me, but then I'm here at my desk and not in your head.
    I'm not sure who of us is the happiest for that
    EDIT: It does make sense now. Does that mean I'm in your head?
    Anyhow, my estimate after measuring the current pull of the MJ-818 at full blast is about 150 minutes together with a 900 running from one battery.
    That estimate is also based on real-time measurements of my three 900s, who all give me 195 minutes.
    I don't know why you guys buy these cheap lights from China when there are good American companies to support that produce quality lights. Take Dinotte for example. The 400 taillight is imo without peer. Buy American. German quality is also good. Anything but China. We had our chance in the 70's and 80't to buy American but people were too greedy and shortsighted. Today China just about owns us.
    Don't be a pawn. Don't get played. Buy American before your children are required to study Chinese in school.
    May 2010
    Quote Originally Posted by suba
    what other lights do you suggest? I'll gladly buy the dinotte, paypal me the difference and I'll support whoever you want.
    Reputation: BrianMc's Avatar
    Anyone using this for increased day visibility on the road?
    If so, are you game for a day and night videos of it riding away especially with something like the Planet Bike SF as a comparison, and posting them here?
    Anyone have lux/lumens measurements?
    May 2010
    Quote Originally Posted by BrianMc
    I am using it during the day.
    I have a planet bike SB also but I don;t use it since I got my MS taillight
    Agreed on PBSF day use. I have three. Many cyclists do, so they make good referrences.
    Even on fresh cells, PBSFs are almost useless in bright daylight (about 12.5 lumens once the NiMH cells settle to 1.2 V. They work in the shade of buildings, trees, or overcast days, but not very far.
    I have two Radbot1000s (24-25 lumens with NIMH at 1.2 volt), and two 1.5 watt DIYs 100 lumens each with 12 volt NiMH pack.
    So I have measured these lights' outputs but I also made videos:
    Daytime video of my lights here:
    http://www.candlepowerforums.com/vb/...3&postcount=46
    Night videos here:
    http://www.candlepowerforums.com/vb/...7&postcount=48
    Comparison to car brake lights here:
    http://www.candlepowerforums.com/vb/...&postcount=109
    I was wondering if one or two who have the MS tailight could do something similar?
    Jun 2010
    Nice job. Thanks for your efforts. I went overboard on lights: Exposure Toro/w red eye, Joystick w/red eye(helmet), MS900 and Dinotte 400 tailight. I know Edison would wet his pants if he saw this light show. I don't have capability to video. I spent all my money on lights. Nick
    Reputation: bpnic's Avatar
    Aug 2005
    Where was your Pugsley made? How about the clothes on your back? Just sayin.
    I'd hit it, but I bruise like a peach.
    ...and Dinotte makes those lights with parts made where? Do the letters SSC mean anything here? Remember, there are American people who also sell those same Chinese made light sets. The U.S. middle man gets to make a buck too. Besides, the Chinese aren't going to get rich selling us cheap electronics. If it was that much of a cash cow there would be more international competition. Damn, wish someone had taught me some Chinese when I was young, some of those Chinese chicks are hot.
    On a side note: Happy Independence Day...nice to be free to express yourself and to buy and live the way you want. Cheers...
    This has been a great review and helped me to make the decision to purchase this tail light as well. I've used it once so far and overall I think it is an excellent light, with a couple of significant issues. Just for the sake of information, I have used numerous tail lights in the past including the Niterider universal tail light which is a similar type of light.
    The Magicshine tail light is an excellent value. It comes with the first version of the magicshine battery along with the tail light. For the cost, it can't be beat. I also love the compatibility of the system. Right now I use the magicshine 900 helmet light with a battery in my pack and the tail light hooked up to its own battery, but all of the plugs are interchangeable, so I can use the cable extension, the y cable, the batteries all together. It's wonderful!
    Problem 1: As it has been noted before, the first version of the battery has mounting problems. It's just not that easy to mount. Not a huge deal, but it's annoying nonetheless
    Problem 2: The tail light has an identical mount to the headlights. I question the durability of the wire being so close to the O ring mount, but that's will only be determined through the use of the light. My issue is that the light direction is perpendicular to whatever it is mounted to. In most cases, this will be your seatpost, which is not vertical. This causes the light to hit the pavement about 15 feet behind the bike. There is still ample light for cars to see from far away, but to not be able to point the light directly behind you is a significant flaw. I ended up mounting an aluminum cylinder horizontally behind my saddle rails to attach the light. Problem solved.
    I also ordered this from Geoman. Needless to say, it was a smooth process.
    Pimpmobile
    For my MJ-818, i use a small pice of soft plastic about 1" X 1/8" X 1/16" wedged under the bottom edge of the seatpost mount... Pretty much aims the beam level and straight.
    Battery pack goes in a Topeak micro-wedge seat pack, fits perfectly with room for the extra cable.
    I use it on my road bike, and get plenty of respect from drivers!
    "Fear not the ob-stackles in your path"
    As I mentioned earlier as well as in another post, I was unhappy with the mount since I move this light on a daily basis to different bikes as well as a trailer and running stroller. I was very concerned about the durability of the light while swapping the o rings all the time since the o ring pushes against the cable.
    I decided to change the mount. With a quick modification, I mounted it the light to a reflector bracket and mounted the other part of the bracket to each vehicle I use. I then only have to turn a thumb screw to move it from vehicle to vehicle. I drilled a hole to support the rubber cable protector, so it's pretty safe in the mount.
    I also like that the tail light can now move on two axis instead of just one with the original mount. This has solved one of my main complaints of the light not pointing in the right direction.
    I'm glad I saved all of the reflector mounts over the years.
    Attached Thumbnails Attached Thumbnails Magicshine Tail Light MJ-818 3W review w/ video-sam_0016_mod.jpg
    Magicshine Tail Light MJ-818 3W review w/ video-sam_0017_mod.jpg
    Been using the MS taillight since I got mine about 2 weeks after they became available. So far, one person standing at a corner and 3 strangers in cars went out of their way to ask me about the light while I waited at a red light. All said they saw me from at least a block away (in the summer morning daylight) and one said he thought I was a motorcycle cop from down the block. The person standing at the corner mentioned he saw me over a block away coming towards him (MS900 on blink) then saw the rear light and commented on that-4PM summer. Two co-workers also have come up to me to mention my lights and said they saw me down the block as they approached in the morning light. Nobody ever commented on my AAA rear blinkies or my Stella 150 which is now my winter helmet light. And now that it is getting darker in the morning (I commute before the sunrise at this point) I am glad I bought the MS lights. I can't believe I went out last January at 6:15am with just a rear AAA blinkie and crappy AA front light ; I'm not doing that again.
    Tzvia.
    So I'd be interested to know or hear your opinion on the way i made my own rear light with a ms 900 headlight.
    Been riding with it for over a year and i know everybody gives me a wide berth.
    Basically put a piece of red automotive rear light repair tape and stuck it on the MS900.
    The MS 900 already puts out what, 600-700+ lumen, + the tape might decrease that some, so lets say now down to about 500-600 lumens.
    How does that relate to the 3W MS taillight and the Dinotte 140 or other high powered rear lights?
    Ps. ragnar.jensen i'm going to steal your method rear light mounting =
    "A plastic pipe, some zip ties and anti-slip tape..." ! )
    pss. yes i cross posted this to another ms rear light thread to get more responses-)
    Dec 2009
    How does this hold up in the rain. It is good and water tight?
    No it's not german made. So it wouldn't be goodentight.
    Does anyone know how to open this unit?
    I too k the mount off, and screwed it to my saddle bag, but I didn't do anything about the cable and the rubbing wore through the cable (surprisingly fast). Now I need to open it to sort the wire but cannot figure out how to open it yet...
    I used to agree with you.
    1st off: Not trying to pick a fight and this is way way off topic.
    2. That argument is really contrary to what freedom to choose is all about. I believe that if American companies made the best product for the money, then people wouldn't be encouraged to support mediocrity on the grounds of patriotism. I love my country, but to continue to purchase items which do not offer the best value (to me) is just a way to encourage mediocrity. Look at the car companies, GM and chrysler essentially became wards of the state based on about 40 years of inexcusable mediocrity.
    3. If you feel the dinotte or whatever gives you superior value, then more power to you. It's all good. My 150 lumen niterider minewt was about $125 when I bought it. I probably would have bought a magicshine had I heard about it or if it was on the market when I made my purchase.
    I think the niterider is a great light, and it may well be better than the MS, but to think of a sub-$100 light (the headlight) that puts out about 4-5 times the light of the minewt and then to know that and turn around and buy the nr on the grounds of patriotism is silly. Buying it on the grounds of better perceived value is a much better reason, imo. I hope both companies thrive profitably.
    To think of buying anything-but-chinese sounds a little, well....questionable. But maybe that belongs on another thread on another site.
    Reputation: Gharddog03's Avatar
    Sep 2013
    Old thread but I wanted to see if anyone else has purchased one recently. I just bought two I am impressed with the output. I wish they redesigned the way you switch modes. One light has a stiff dial and the other one is loose.
    Mj-818 - YouTube
