Results 1 to 3 of 3
    Dec 2010
    Magicshine HA111 switch repair help!
    Hi
    My Magicshine light has developed a fault. The "clicky" switch has become unreliable. It works for a while then stops working again. I think it is worse in cold weather. The switch is an intermittent contact single pole job so I think it is the circuitry behind it that is the issue. Any ideas which component might be failing?
    Mike
    I'd post this on the DIY forum, you might have more success there.
    Dec 2010
    switch
    Thanks, I'll try that
